This thread is privately moderated by ExperimentalAir, who may elect to delete unwanted replies.
Old Sep 22, 2012, 03:48 PM
achurin is offline
Find More Posts by achurin
Beginner RC Pilot
achurin's Avatar
United States, CO, Broomfield
Joined May 2012
Definitely tail heavy
Originally Posted by IAFoamie View Post
Hello
Nice plane achurin. I'm trying to decide if plane is tail heavy or it was the wind. Your motor looks light and battery under front of wing. Even with landing gear looks tail heavy to me? Where does it balance"thickest part of wing"?? What is the all up weight also. My wing is same but 56" long on AXON.
She was definitely tail heavy the first day. The second day she flew better and performed better after the extra weight I added with the landing gear. I have a build thread on my blog and I will be updating it shortly. My last outing the motor failed, and I had a bit of launch/crash incident. Putting a much bigger motor on there now. I have a Turningy D3536/6 ths has yet to see any flight time.
I will update the video footage then. It should add a bit of weight and power to it.
Thanks for watching and the suggestions/observations.
As a rookie, I appreciate all the advice I can get!
achurin is offline Find More Posts by achurin
Old Sep 23, 2012, 06:58 AM
jetcommander is offline
Find More Posts by jetcommander
jetcommander's Avatar
Joined Jan 2012
Do you have music on the video that has copyright? Unfortunately it canīt be seen here in Germany, You Tube link perhaps?
jetcommander is offline Find More Posts by jetcommander
Old Sep 23, 2012, 03:55 PM
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Yep, some people might call that music...
I turned the volume all the way down after the first few seconds.
Wingman26 is offline Find More Posts by Wingman26
Old Sep 23, 2012, 05:29 PM
aldalo is offline
Find More Posts by aldalo
It Flys Me
aldalo's Avatar
United States, PA, Washington
Joined Jun 2012
Tube Trainer
Just finished my newest plane , using Ed,s methods.
It's a trainer with about 5 degree dihedral wings.
Fuse is 30" long-5" cord , Wing is 39.5" , Elevator - 15" , Rudder -7.5" /
1.5" throws on all control surfaces.
AUW - 525g - 1300 mah battery
Motor 1000kv (Hope it's enough, I had it laying around)
I hope to maiden it tomorrow. I needed something a little tamer than my
Axon (It's a handful)
aldalo is offline Find More Posts by aldalo
Old Sep 23, 2012, 08:15 PM
rcnewbieoz is offline
Find More Posts by rcnewbieoz
Fan of experimetalairlines
Australia, NSW, Sydney
Joined Jan 2012
Looks nice! How did you do the undercarriage?
rcnewbieoz is offline Find More Posts by rcnewbieoz
Old Sep 23, 2012, 09:16 PM
speedactyl is offline
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
HI just abit of question how do you explain to people where best to use
EPO
EPP
Depron
EPS
thanks
speedactyl is offline Find More Posts by speedactyl
Old Sep 23, 2012, 09:47 PM
aldalo is offline
It Flys Me
aldalo's Avatar
Joined Jun 2012
I just bent some aluminum rod & epoxied in place ( Don't no if it will hold up)
Old Sep 23, 2012, 10:48 PM
CarbonFlite is offline
Find More Posts by CarbonFlite
Closed Account
Joined May 2012
The CarbonFlite Project Update #2 - Scratchbuild (4 min 24 sec)
Using an Armin wing. Thanks ED!
CarbonFlite is offline Find More Posts by CarbonFlite
Old Sep 24, 2012, 12:03 AM
Wingman26's Avatar
Oklahoma
Joined Aug 2008
adalo: In reference to the trainer above, a longer wingspan would make that more stable and easier to fly, also a longer fuselage would make it less sensitive in the pitch axis. With the short wing its probably going to be too sensitive in the roll axis to consider it a trainer, in addition it could probably use more wing area to lower the wing loading.
CarbonFlite: In the video immediately above, this makes a great demonstration of why its so important to set up your dual rates before the first flight!
Also, you mentioned polyhedral, I think you meant dihedral, in your case adding wingtips with dihedral would probably make the plane more stable, to add polyhedral would probably mean building a complete new wing, putting dihedral in the center of the wing, then adding more dihedral at the wingtips, to fit the proper definition of polyhedral.
You could add wingtips with dihedral to your existing wing to add stability.
Old Sep 24, 2012, 12:56 AM
Closed Account
Joined May 2012
Yes, I meant adding wing tips with dihedral. I am going to make a 90" wing and see how that works out. I am looking for slow flying plane with a decent payload capacity. I'll keep you guys updated.
Old Sep 24, 2012, 12:02 PM
Wingman26's Avatar
Oklahoma
Joined Aug 2008
90 inches! Very good!
Old Sep 24, 2012, 12:56 PM
syzygyQ is offline
Find More Posts by syzygyQ
Joined Oct 2011
So you know where I'm coming from, I've got all of my foam and parts in hand and am about to begin my first scratch built aero plane.
I've decided to go the hot wire foam cutter route. Studying here at FSU I've learned that you can probably get a "good enough" ready built cutter for less than $20-.
Would you please post [a] link[s] to [a] decent, cheap ready built cutter[s]?
Also, I've got a 306B which has a minimally documented foam cutter mode. Can you describe or post [a] link[s] to [a] simple, elegant, easy to make cutter[s], made from common scrap, built to be driven by the EPBuddy iCharger foam cutter mode?
Thanks!
Edit: and to answer my own question. There's a good plan here for an RC plane wing cutter requiring two woooden blocks two screw hooks, and a wire.
syzygyQ is offline Find More Posts by syzygyQ
Last edited by syzygyQ; Sep 24, 2012 at 02:40 PM. Reason: answering my own question
Old Sep 24, 2012, 02:05 PM
Gordosoar is offline
Find More Posts by Gordosoar
Sabre holic
Gordosoar's Avatar
Beverly Hills, Florida
Joined Nov 2006
Originally Posted by CarbonFlite View Post
http://www.youtube.com/watch?v=WJiZJeVvATM
Very nice build. Can you list the dimensions.
I've been away for a few days and just catching up on things.
Lot of nice planes being built out there.
I'm still flying the same old things but loving it.
If you have Double vision, land the bottom plane.
Gordosoar is offline Find More Posts by Gordosoar
Old Sep 24, 2012, 04:36 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
I am curious, would increasing the cord measure and the thickness also help lower the stall speed of the wing?
rimshotcopter is online now Find More Posts by rimshotcopter
Old Sep 24, 2012, 07:17 PM
Closed Account
Joined May 2012
Gordosoar-
Wingspan: 60"
Dowel booms: 14" long, 11.5" apart
Wing cord: 7" with 24"x 2" control surfaces
Maximum wing thickness: ~1.25"
Wing spar: 3/8" wooden dowel
Tail: 21" x 6"
Elevator: 2"x 11"
Stabilizers: 6" at bottom, 3" at top, 6" tall.
Body is a 2" x2.5" tube, 20" long
Rimshotcopter: In my experience: the thicker and larger cord the lower the stall speed, but you sacrifice efficiency, meaning short flight times. This is not always true, I plan on making a longer, skinny-er wing with a smaller thickness. This keeps weight down and will hopefully provide enough surface area to keep the model float-y even with extra weight.
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Foamies (Scratchbuilt) 72 Oct 30, 2015 02:23 PM
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Flying Wings 0 May 19, 2011 10:47 PM
Question So I have a sheet of $Tree foamboard... what to build? Bomb Dropper Foamies (Scratchbuilt) 15 Mar 23, 2011 03:49 PM
Discussion EDF/Motor for University Design Project uwpropulsionguy Electric Ducted Fan Jet Talk 0 Mar 06, 2011 04:24 PM
