Jun 13, 2012, 05:32 PM
Originally Posted by Lazygit
What's the difference? It seems Garolite is just a brand name.
Industrial grade fiberglass,is chopped up strands of fiberglass bonded together with epoxy, Garolite is made simular to what is used to make a fiberglass layup, useing a several layers fo fiberglass mat, that are orentaeted in different directions. Garolite I beleve is actually considerated to be a phenolic material. I did a simple test with both types of material, identical in width and thickness, I put the material in a vise, and useing a cresent wrench, bent the materials, once you reached a certan level of bending, with the industrial grade fiberglass you could hear the fiberdglass strands breaking, and once they started breaking, it was all downhill from there. The garolite withstood much more bending before it broke. When you watch videos of gyros flying (except Riche's gyros) you will see that about 50% of the time they tip over upon landing, and that is the major stress upon the blade mount. There are different grades of garolite, make sure that you select grade G10. Garolite is the material that they make circuit boards from. Also be aware that on some of the Garolite, sometimes you will notice that the tensel strength is different on the length verses the width of the material.
Gary
