Old Feb 03, 2012, 09:03 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Can LDS be done on a DLG or is top drive as close as we can get?
Guys,
I saw in the MultiTask F3X forum a discussion on LDS.
From what I can see it is nothing more than a top driven servo where instead of having a control horn and pushrod stick out the top, the horn is buried in the hinge and the pivot is along the opposite surface as the hinge. This is as far as I understand it.
Are the wings thick enough or are the servo arms small enough, etc. for us rto be able to do an LDS setup in a DLG?
http://www.rcgroups.com/forums/showt...&highlight=lds
example of LDS
http://www.skipmillermodels.com/Espadita_p/espadita.htm
http://www.rcgroups.com/forums/showthread.php?t=1239669
https://plus.google.com/photos/10826...945?banner=pwa
Frank
Fly2High is offline Find More Posts by Fly2High
Old Feb 03, 2012, 09:46 AM
Thermaln2 is offline
Find More Posts by Thermaln2
Transplant Chey WY from Reno
Thermaln2's Avatar
Reno Nevada
Joined Oct 2007
It looks no different that a servo horn that is more solidly held. The limitation to this is both the thickness of our wings as well as the thickness of the airfoil at the hingeline. IMHO, this is just fancier and weigh more. Otherwise, identical.
Thermaln2 is offline Find More Posts by Thermaln2
Old Feb 03, 2012, 09:54 AM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
I like the idea of nothing sticking up, like in an RDS setup. I think we could come up with a lighter weight version but if it is mechanically impossible, then why bother?
I figured the LDS would satisfy the guys looking for nothing sticking out of the wing, the guys who complain that RDS can be sloppy might be better pleased with this and it could offer alternatives when wing thickness is an issue.
Old Feb 03, 2012, 11:41 AM
DLGjunkyard is offline
Find More Posts by DLGjunkyard
DLGjunkyard's Avatar
Canada, ON, Morriston
Joined Apr 2010
ouch! Thats a lot of load concentrated on the flap/hingeline. Not so much with thicker wings though.How the heck is the pin removed at the rear end?
Looks like a headache to me
DLGjunkyard is offline Find More Posts by DLGjunkyard
Old Feb 03, 2012, 11:44 AM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
I think the control surface pin is slid in from the side of the surface when deflected.
Is that the pin you refer to?
Old Feb 03, 2012, 11:53 AM
Joined Apr 2010
Yes, thanks for that. SOO a two pc wing is a must?
Old Feb 03, 2012, 11:58 AM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
I think you can deflect the surface and then insert the pin
Old Feb 03, 2012, 12:13 PM
Joined Apr 2010
The physics annoy me. If the pins from front to rear are not aligned it will bind and if its not tight there will be slop. Very little gap though.
What happens to the hinge end of things if the servo end is at SDC [side dead centre. lol] and the flap gets knocked. ouch! It seems novel to me.
Im waiting for someone to come up with a spring loaded flap and some sort of cam to activate it but im not holding my breath. lol
I really like the Legends system by Sharper Dave for A RDS substitute
Old Feb 03, 2012, 12:17 PM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
I was thinking of a pull spring for flaps but how strong of a spring would you need and could it handle flutter?
I guess the regular pushrod (bottom or top) and RDS is the only available options......
Old Feb 03, 2012, 01:13 PM
Joined Apr 2010
My thinking is that the weight involved to incorporate the LDS system may very well be equal to the weight involved to install a spring and related reinforcements that could handle the flutter issues.
Thanks for the link , its interesting to ponder new methods.
Old Feb 03, 2012, 01:39 PM
olgol is offline
Find More Posts by olgol
Oleg Golovidov
olgol's Avatar
Raleigh, NC, USA
Joined Sep 2004
I agree with Chris and this comment from David:
Originally Posted by djklein21 View Post
On another note, Linear Drive System. Lame name. It's a conventional linkage with beefed up links and clevises. I bet it ... suffers the safe high shear loads on the output shaft and hinge line ...
I don't see why it deserves a special name, and "linear" definitely does not fit.
If we simply keep reducing the servo arm and the control horn, we will eventually be able to hide the control horn within the aileron thickness. The forces will proportionally increase. If the current control horn arm is about 8mm, to hide it within the aileron it has to be 4mm? So the loads on the servo shaft, the pushrod, and the hinge will double. More wear and tear, and even a little compliance in the servo shaft or hinge line will show up as a big slop in the aileron. If the components are strong enough, it is possible. For example, Sirius had aileron horns almost entirely within the depth of the aileron, because the ailerons were thicker than on Polaris or other wings.
olgol is offline Find More Posts by olgol
Old Feb 03, 2012, 02:42 PM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
Thanks Oleg. Now I can understand it is not a desired direction to take. Exactly what I was looking for.
I would guess then that the choices we have for control are the top or bottom drive, RDS and the way Shaper Dave does the Arrow/Legend planes.
Frank
Idea Lets see how many people we can get on at once! 100mph Chit Chat 5 May 26, 2011 12:45 AM
Sold G3+ add ons volume 1 as close to new as you can get 68Strat Aircraft - General - Miscellaneous (FS/W) 5 Jun 22, 2006 02:19 AM
Alert Dragonfly can be converted to Belt drive Tail ? Yes, Come on, we can do...? lostrider Micro Helis 35 Mar 24, 2005 07:55 AM
Combat Models F-18 or F-16, can it be done as an EDF or Pusher electric. Jackspt28 Electric Ducted Fan Jet Talk 3 Mar 07, 2005 06:31 PM
