Here is a simple tail mod TAIL MOD ASSEMBLY, pics and instructions by Lafayette.
I work with a whole bunch of kids, and this one too will be in their hands and hopefully our first FPV platform.
SO, make it strong!!!
ENJOY!
Got my plane from Readymaderc, best place, best price, quick shipping, and the best customer service I have experienced. Also it is V1 which has the control rods out of the fuse with the max space inside.
TAIL ASSEMBLY MOD:
-1 drill bit 9/64th
-1 drill bit3/8th
-1 drill bit 5/16th
NOTE: *the 9/64 drill bit is the exact size of the nylon bolt used, the 3/8 is the exact diameter to enlarge the tail well to accommodate the head of the nylon bolt.
The 5/16 is the exact size for the well nut to fit in the vertical stab.
I recommend using an assortment of bits, starting with smaller than needed to progressively drill the foam to the desired size and prevent taking out chunks of foam and allow for corrections to drill straight and true.
This type foam has a tendency to come out on little beads.
*If you want to, you may glue the tail surface to the fuse. However, I came up with a very easy solution. This will allow for a quick and secure way to put the tail together and take it apart for transport.
*The whole aircraft will fit in its convenient original box for transport. See Transport box mods later in this manual.
# 1- Look on the bottom of the fuselage, at the tail end. It looks like the "bump" was intended to mount a tail wheel or such. Look inside the well and you should see a small whole.
# 2- Look at the horizontal stabilizer. The point at which it will fit under the vertical stabilizer has a small mark, indentation. If not, no problem.
# 3- Place the vertical stab in the mounting slot on the tail, than insert the horizontal stab. Hold tail assembly tightly in place and squared to the fuselage. Take a small carbon rod or piano wire and insert it from the bottom of the fuse through the small whole and push to indent the bottom of the horizontal stab. Make sure to keep the carbon rod or piano wire square to the fuselage in both axis.
# 4- Remove the 2 stabs from the tail. Hold the two stabs as they would be mounted. Hold tightly.
# 5- Now note the spot where you made the indentation on the bottom center of the horizontal stabilizer. Slightly separate the 2 stabs to see where the indentation on the bottom would hit the vertical stab if the wire would be going through the vertical stab at 90 degrees square in both axis.
# 6- If you look carefully at the bottom of the vertical stab, you will notice "steps".
Right behind the front part of the vertical stab that inserts in the fuse you will notice 3 steps where the horizontal stab meets with the vertical stab.
What you are looking for is to see if the indentation made on the bottom of the horizontal. stab would match dead center on the second (middle step) of the bottom of the vertical stab.
# 7- When you are satisfied you will have a match, put the stabs back as they should be mounted on the fuse, making sure once more that the two stabs are held tight in position and squared to the fuselage.
Slowly drive the piano wire at 90 degrees, square on both axis, through the tail well and through the horizontal stab.
# 8- Remove the piano wire and check again where the hole on the top of the horizontal stab coincides on the tail. Again it should hit dead center on the middle step. I satisfied, reassemble the tail, hold firmly in place, squared to the fuselage, and push the carbon micro rod or piano wire until it penetrates the bottom of the vertical stab 1/2 inch max.
# 9- Take a small drill bit and insert it through the tail assembly gently turning in until it reaches through the tail of the fuse, the horizontal stab and finally in the vertical stab (1/2 inch max). Make sure to hold the tail assembly tightly as you proceed, and that the tail assembly is square to the fuselage. Repeat with larger drill bits until you finally use the 9/64 bit.
#10- Next step is to enlarge the hole in the "bump" of the fuselage's tail end to accommodate for the head of the nylon bolt. DO NOT GO THROUGH ALL THE WAY THROUGH THE FUSELAGE. If you look inside you should have already noticed that there is a certain thickness of the top part of the fuselage. Do not drill through that. this will be used to glue a plastic washer as a retainer for the nylon bolt. Work your way up to the 3/8 bit.
#11 Use the non threaded side of the 3/8 drill bit to smooth out the hole and create a flatter surface to glue the plastic washer inside of the fuselage tail well.
#12 dry fit the plastic washer inside the tail well using the smooth end if the 3/8 drill bit to position it. It should be fairly tight and flush.
#13 Remove the washer carefully by pushing it back from the top side of the fuse.
Insert the tip of the ca bottle in the hole and place some CA where the washer will sit in place. Use the smooth end of the drill bit to push the washer and set it in place firmly. Try not to have excess glue in the center opening of the washer.
Note: I did not use Gorilla glue as it expand 3x and would certainly find a way to get into the well nut and obstruct the threads and as well obstruct the opening in the washers.
#14 Let dry for quite a while before being tempted to insert the nylon bolt.
(CA LOVES PLASTIC!)
#15 While the CA on the washer sets and dries, enlarge the hole in the bottom of the vertical stab working your way up to the 5/16 bit. NO MORE THAN 1/2 INCH. Dry fit the well nut in the bottom of the vertical stab making sure it rests squared on the 2nd step. Assemble the tail assembly in place when the washer is completely dry. Insert the nylon bolt through the tail horizontal stab and screw into the well nut in the vertical stab it should fit perfect. Remove the nylon bolt and disassemble the tail surfaces. Remove the well nut.
NOTE: the bottom of the well nut is not fitted in the foam, as to act as a compression washer and secure the assembly, as well as providing a bit of a shock absorber!
#16 use rubbing alcohol to clean the well nut on the outside and dry. Apply some CA on the well nut, all around, but not too much on the end as it could pool in the threads.
Carefully insert the well nut, and use tape to keep it tightly secured in place. Let dry completely.
DONE!
YOU NOW HAVE A VERY SECURE
EASY TO TAKE APART TAIL ASSEMBLY.
(Iwill redo better pics for the complete manual).
