Old Feb 02, 2012, 10:55 AM
Aerosheik is offline
Find More Posts by Aerosheik
Joined May 2011
New Losi 2.4GHz Brushless 1/24 Micro SCT and Rally announced!
Just wanted to get this info out there:
http://losi.com/Products/Default.aspx?ProdID=LOSB0242
http://losi.com/Products/Default.aspx?ProdID=LOSB0243
Looks like they are still using the 5-wire servo on these guys. However, this seems to answer all my micro desires. I was wanting a micro but I knew I'd have to do the upgrading myself to the 2.4GHz and the brushless.
Now if they'd only do this for the 1/36 scale models.
Aerosheik is offline Find More Posts by Aerosheik
Old Feb 05, 2012, 12:02 PM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
Is the micro BL SCT any good? Is it worth it compared to the traxxas E-revo VXL in terms of speed, fun and durability?
SS
starscream4002 is offline Find More Posts by starscream4002
Old Feb 05, 2012, 06:55 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
It's WAY smaller than a mini e-revo, probably half the size.
It'll be much slower and won't handle nearly as rough of terrain, all due to size.
wparsons is offline Find More Posts by wparsons
Old Feb 06, 2012, 06:36 AM
Tabriz, Iran
Joined Sep 2008
How does it compare to other losi products such as the 1/36 models and the original 1/24 SCT?
SS
Old Feb 06, 2012, 10:27 AM
Joined May 2011
Considering price points, I'd say the newest one is the one to grab. you'd easily spend more than the 40~ dollar difference between the original 1/24 SCT and the updated (brushless/2.4GHz) model just trying to upgrade the original/older model.
As far as 1/24 vs 1/36, it all depends.
1/36 : 2 wheel drive, which wheelies easier, and is the smaller of the two. Good for indoor use unless you've got a smooth drive way.
1/24: 4 wheel drive, oil filled shocks, no C-clips on the wheels, which most everyone wants on a hobby grade RC Car. This one also has a bit larger turning radius, but I don't think that's a huge complaint considering there are ways to improve that. This one may handle a little more terrain.
Old Feb 09, 2012, 07:38 PM
gertman is offline
Find More Posts by gertman
Joined Jan 2012
I have both these cars. I have upgraded the 1/36 truck to bearings, brushless motor, and LiPo. The 1/24 I have only upgraded to LiPo.
I run them both on my RCP track. The 1/36th scale is almost undrivable it is soo fast. I also did upgrade the axles so I could use wheel nuts!!! What I really need to do is upgrade to oil filled shocks and then hopefully it will more drive-able. If I gun it right now it will actually do tumble-sots!!! I have broken a few parts nothing too expensive (that is the best part the ENTIRE transmission complete with diff is around 10bucks!!!). It's not even worth taking it apart to put bearings in.
The 1/24 scale already has bearings AND is really really awesome for the money!! It may not be as fast BUT is soo easy to drive that it is sooo much easier to do laps around my track and with the LiPo is preaty fast. I would think this new one with the brushless motor would run amazing!!! My only concern is that my car with the LiPo gets very warm (motor is kind of berried) and I would imagine this one would have the same issue.
Also, the 1/24 cars are bullet proof BUT you generally need to add oil to the shocks when you get them. Also, they are VERY loud when new because of the metal gears in the front and rear diffs. They do quite down after some driving BUT have HUGE drive-train drag.
My last comment is the get the rally car body!! Why, don't for it's looks BUT because it will actually roll over a lot better than the truck. The truck is very flat along the top.
gertman is offline Find More Posts by gertman
Old Aug 18, 2012, 08:47 AM
wishawhunk is offline
Find More Posts by wishawhunk
scotland uk
Joined Jan 2005
Are these 2 the same? Only difference is the shells and wheels on the sct?
wishawhunk is offline Find More Posts by wishawhunk
Old Aug 18, 2012, 10:01 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Between the rally and SCT, yep.
Old Aug 18, 2012, 10:16 AM
scotland uk
Joined Jan 2005
Just the wheels different w?
Old Aug 19, 2012, 06:50 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Wheels and body for sure, maybe the body mounts too.
Old Aug 20, 2012, 02:37 PM
Joined May 2011
From my understanding there is some stand-off plastic for the side impact plastic for the Rally/SCT, so the Truggy body may bulge a little on a brushless chassis. From my understanding you can get a body shell and the wheels and you'd be good to go. If you stop by a local hobby store you could probably see it for yourself before you bought the parts.
Old Aug 20, 2012, 03:17 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
The truggy is only brushed, so the differences between it and the brushless rally/sct are much bigger. The chassis is the same, but you're right about the nerf bars.
Discussion The Losi 1/24-scale 4WD Micro SCT and Rally Car Bowerz Micro Cars 1029 Jul 08, 2016 08:06 AM
For Sale BRUSHLESS Losi ReadyLift Mini SCT BND w/Spektrum 2.4gHz RX ONLY 1 PACK THROUGH IT Z06 Tony Cars - Trucks and Parts (FS/W) 3 Jan 28, 2012 08:17 AM
Sold Losi mini t, losi micro t, losi 1/24 rally pics now 190$ for all 3 custom t Cars - Cars and Parts (FS/W) 5 Dec 11, 2011 04:49 PM
Discussion Losi 1/24 sct rally main board ho50ca Micro Cars 5 Nov 29, 2011 03:38 PM
Discussion 1/24 Scale 4WD Micro Rally with 2.4Ghz and Brushless Upgrades Plus Steering Gyro EQMOD Micro Cars 8 Mar 12, 2011 06:38 PM
