| Thread Tools |
| This thread is privately moderated by RCPtero, who may elect to delete unwanted replies. |
A lot of progress on the second and third sets this weekend. I got the side sheeting almost complete. I did rake some photos to show how I'm doing the sheeting. I'll upload them when I get a chance in the next few days.
I picked some spar urethane today to seal the wood. Think I'm just going to seal them, but no color. If the recipients want color they can paint as they see fit. I like the natural wood, and this second grade balsa has a lot of character to it. -- Tom |
Photos as promised...
-- Tom
Okay, sanding is done. It's amazing how fast 120 grit sandpaper on a random orbital sander cuts through balsa!!
First coat of varnish is also applied. I hand rubbed this first coat and will do the next couple to get a thin seal on the wood so the varnish won't soak into the foam and eat it. We'll see tomorrow evening if it was light enough. -- Tom |
Put the first coat on the bottoms tonight. I think tomorrow I'm going to start brushing on the coats and get them sealed well. Before final sanding, they weighed in at about 15 oz each. After sanding and varnishing, I'm hoping they'll still be real close to 16 or 17 oz.
I also started measuring for the rear landing gear tonight. Per one of the links I posted above, I need the leading edge about 5/8" higher than the trailing when compared to the top of the floats. That gives positive wing angle to help lift up onto the step. Based on my measurements, if I build gear just like the front gear, that will work out about right. So, tomorrow, I start bending metal as well. Who knows, I might have her on floats before the end of the weekend!! Then all that will be left is the water rudder. And I already know how I plan to do that and have picked up the supplies. -- Tom |
| Thread Tools | |
| For Sale Sig Rascal 110 | g wheeler | Aircraft - Fuel - Airplanes (FS/W) | 1 | May 29, 2012 03:05 PM |
| Discussion Sig Rascal 40 on Floats | Kyler1 | Waterplanes | 4 | Sep 24, 2011 10:23 PM |
| Wanted Rascal 110 floats | BrianSmith | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jun 22, 2011 05:11 PM |
| Wanted Sig floats for the Rascal 110 | BrianSmith | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jan 09, 2009 08:36 AM |
| Cool WANTED! Sig Rascal 40 and 110 for my G2 Sim | fujimo | Simulators | 0 | Nov 22, 2004 09:22 AM |
