This thread is privately moderated by RCPtero, who may elect to delete unwanted replies.
Old Feb 01, 2012, 02:48 PM
RCPtero is offline
Find More Posts by RCPtero
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Build Log
Floats for my SIG Rascal 110
Okay, I started posting this in the forums, but have decided to pull the info together into a build log so it's all together.
RCPtero is offline Find More Posts by RCPtero
Old Feb 01, 2012, 02:55 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
For anyone interested in building floats, here are a couple of good references:
http://www.rcmplans.com/issues/reque...-071991-1.html
http://www.rcflyer.org/float.html
Tom
Old Feb 05, 2012, 09:43 AM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Okay, here are the photos to date...
(I got wordy on some of the descriptions and RCG chopped them off. I think the meaning comes across. If not, feel free to ask.)
Old Feb 05, 2012, 08:03 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
Floats are looking good, Tom!
IFLYOS is offline Find More Posts by IFLYOS
Latest blog entry: Intro..a few years to late!
Old Feb 07, 2012, 07:45 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Fine Job on the floats!!
Diggs
Diggs is offline Find More Posts by Diggs
Old Feb 12, 2012, 09:52 AM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Glue is cured and I've sanded the tops again. I've now started attaching the balsa skins.
Using Tightbond III, I understand that after I'm done, I can come back with an iron and heat it up and the glue will polymerize similar to epoxy and make a really strong bond.
This is also about the only use I've found for that carton of diet Cheerwine I picked up by accident! The tape is holding down the edges, but I realized I needed weight in the middle to hold the center of the wood down.
Oh, and to make it work around the bow curve, I wet down the balsa before I started. I'm not doing the 1/4" flat on the front yet. That was to sharp of a bend, so it will be a separate piece.
Tom
Old Feb 13, 2012, 08:42 AM
IFLYOS is offline
IFLYOS's Avatar
Joined Feb 2001
Tom, I have heard the same about TiteBound III.
Those are shaping up to be some really nice floats! Any idea on the weight so far?
Old Feb 13, 2012, 12:31 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Not yet. I'll see if I can get a ballpark tonight.
I'm working three projects actively at the moment; Power pod for the Bird of Time, these floats, and a head transplant for the Pterodactyl. Should be a fun SEFF!
Old Feb 13, 2012, 06:58 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Right now, with the balsa to cover the rest, they're right at 15 ounces. Figure with the hardware they'll probably be about 20. That's about 2.5 lbs per pair. Think that's light enought to still work?
Old Feb 13, 2012, 07:00 PM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
But then still need to seal the wood. So figure all up, probably still under 3 lbs.
Old Feb 13, 2012, 07:07 PM
IFLYOS is offline
IFLYOS's Avatar
Joined Feb 2001
Thar should be fine, Tom. I think an extra 3 pounds will be noticeable, but wont detract from the nature of the Rascal.
Old Feb 16, 2012, 06:05 AM
RCPtero is offline
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Glued on the bottom back half of my first set last night. Using watered down wood glue takes longer than I had expected. The water soaks into the wood and takes a long time to dry up and harden. At least all but the bottom fronts are flat and makes it easier to use weight to make sure I get good contact throughout. The tape tends to make the center bow away from the foam, so weight is needed to hold it flat.
Think I'll do a bunch Friday night and let them set all weekend. Should be pretty much caught up on the other two sets by Monday night.
Tom
Old Feb 19, 2012, 12:06 PM
annarelli is offline
Find More Posts by annarelli
Grampa Tony
annarelli's Avatar
Lawrenceville, GA - Northeast Atlanta
Joined Jan 2009
Are you going to taper these, or will the sides be square as they are now?
Grampa Tony
annarelli is offline Find More Posts by annarelli
For Sale Sig Rascal 110 g wheeler Aircraft - Fuel - Airplanes (FS/W) 1 May 29, 2012 03:05 PM
Discussion Sig Rascal 40 on Floats Kyler1 Waterplanes 4 Sep 24, 2011 10:23 PM
Wanted Rascal 110 floats BrianSmith Aircraft - Fuel - Airplanes (FS/W) 0 Jun 22, 2011 05:11 PM
Wanted Sig floats for the Rascal 110 BrianSmith Aircraft - Fuel - Airplanes (FS/W) 0 Jan 09, 2009 08:36 AM
Cool WANTED! Sig Rascal 40 and 110 for my G2 Sim fujimo Simulators 0 Nov 22, 2004 09:22 AM
