Old Jan 29, 2013, 06:43 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by indoorheli View Post
If you are going to get a digi you might as well get one that does everything
https://www.rcdepothobbies.com/Produ...ctCode=40002RC
There is another model though for less than half price that only does single axis pitch
https://www.rcdepothobbies.com/Produ...de=RCL-40001RC
I don't know any other use than single axis pitch.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jan 29, 2013, 10:29 AM
emeraldc is offline
Find More Posts by emeraldc
west coast flyer
emeraldc's Avatar
Joined May 2012
A couple of good reviews for this one, so I ordered it, after wasting $6. on a manual gauge. Did not get it on sale though
emeraldc is offline Find More Posts by emeraldc
Old Jan 29, 2013, 11:41 AM
poiyt is offline
Find More Posts by poiyt
United States, GA, Newnan
Joined Aug 2010
Ebay CF Blades (from China)
Anybody try these?
http://www.ebay.com/itm/Carbon-Blade...item1e632c47c3
$17.88 shipped...The ad said they're "300% CF" ...dang, that's a lot of carbon
poiyt is offline Find More Posts by poiyt
Old Jan 29, 2013, 11:45 AM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by poiyt View Post
Anybody try these?
ooo... white!!! Nice for visibility. I put a white and red stripe on my black ones to I could see the blade disk. Also for tracking and balance, but white would be nice!
erkq is offline Find More Posts by erkq
Old Jan 29, 2013, 12:16 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Swash, tail blades and if you loose your levels, you can lay a brick wall, hang pictures or put a 3 dimensional object in place and make sure it is perfectly vertical.
indoorheli is offline Find More Posts by indoorheli
Old Jan 30, 2013, 07:41 AM
poiyt is offline
Joined Aug 2010
Yep same here...I can't see 690mm black blades, MUCH less the smaller ones!!!!
So I found these on ebay and was wondering if anybody else had too and maybe tried them
Or knows of any other white CF blades?
Old Jan 30, 2013, 07:53 AM
You down with EPP?
Houston, Tx
Joined May 2009
Gotcha, thanks.
Old Jan 30, 2013, 10:49 AM
erkq is offline
Joined Dec 2010
Didn't I hear that the SR blades work on the 300? If they do, here's a set of whites right from HH! http://www.horizonhobby.com/products...-sr-MHESR088CF
Old Jan 30, 2013, 11:06 AM
clearprop88 is offline
Find More Posts by clearprop88
Joined Apr 2011
I have a severe vibration problem in the tail. I'm going to replace the tail shaft, even though it doesn't look like it's bent.
I bought this heli. used, and the owner told me about the problem.
Is there anything else that would cause the problem?
It occurs at about 40% throttle, and up.
clearprop88 is offline Find More Posts by clearprop88
Old Jan 30, 2013, 11:19 AM
indoorheli's Avatar
Joined Sep 2007
How it the tail belt tension?
Is it binding anywhere?
Video?
Old Jan 30, 2013, 02:11 PM
Pen is online now
Pen
Find More Posts by Pen
Pen
FPWhat?
Pen's Avatar
United States, AL, Huntsville
Joined Sep 2008
I had a bad tail vibe out of the box and fixed it by adding tape to one tail blade. I weighed the tail blades on a gram scale first and they were near exact weight but I had to add several pieces of tape to one blade to minimize tail vibes and eliminate the right drift induced by vibes.
Pen is online now Find More Posts by Pen
Old Jan 30, 2013, 08:36 PM
poiyt is offline
Joined Aug 2010
thanks, but dang...can't find the length on these anywhere?? anybody know?
Old Jan 30, 2013, 09:15 PM
Joined Apr 2011
Video?
The belt tension looks OK.
Don't see any binding.
If it is still vibrating after I replace the tail shaft I'll post a video.
Old Jan 30, 2013, 09:16 PM
Joined Apr 2011
How did you determine which blade needed the weight?
Old Jan 30, 2013, 09:21 PM
indoorheli's Avatar
Joined Sep 2007
On binding did you disconnect the tail linkage and manually move the arm?
You have a 50% chance of getting the right one on your first attempt
If the vibes get worse you guessed wrong.
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
