Old Jan 27, 2013, 06:39 PM
HeliStyle is offline
Find More Posts by HeliStyle
hmmm...
Joined Sep 2008
If I were to damage a stock servo does the beastx have to be reprogrammed to find centers and such?
HeliStyle is offline Find More Posts by HeliStyle
Old Jan 27, 2013, 06:45 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
I have rebuilt the cyclic servos on my 450X twice and didn't need to touch the BX. It flies as well as before I repaired it.
J_skaggs is offline Find More Posts by J_skaggs
Old Jan 27, 2013, 07:34 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by Billz_01 View Post
First of all, thankyou for the responses.
I realise that there would be many different setup tweaks for different flying styles, and it makes sense that a different pitch range would be one of them. I was under the impression that an appropriate setup change would be made digitally though, via adjusting the travel on the transmitter. Is 0 pitch on the heli with centred servos not a normal adjustment that should be made on every heli? Just like on my fixed wing ships, my aileron and elevators are all centred, and throw is adjusted on the transmitter via rates and expo? Is this not the norm? Although I do understand the CG changes, but they still should fall within a range of a formulae yeah? (I don't know it, would have to google it, but I know there is a formula for locating CG on fixed wing, something like 1/3 chord divided by something, measured from the root, making a magical range/location that seems to work (depending on the wing design)).
And I can't take credit for that video, I am simply just relaying it. That one I believe to be created by Indoorheli, and in saying that, thankyou to Indoorheli for the training
Would checking blade tip distance actually give you pitch range? I understand that it would give you overall pitch throw, but how do you work out which is + and - pitch? it might give you an overall of 24deg throw, but that might include 10- and 14+ yeah?!
Definitely going to be picking up a digital gauge, it seems to be a very valuable tool in this hobby.
Thankyou everyone for the information, it definitely makes learning this sport much easier having smart people to ask!!...
Yes, zero pitch at center stick with a level swash is the norm for a CP bird, and collective & cyclic pitch ranges are adjusted via the tx. I use my pitch-gauge to check the pitch ranges. My 300X, as it was set up pretty well out of the box, so I didn't need to change anything right-off. I had to chase a bit of vibration & eventually ended up switching to the aluminum center-block & FBL following arms. Then I spent more time getting everything just right. Regarding fixed-wing CG placement - it depends entirely upon the particular airframe design, the flight-conditions, and one's flying style. Many 3D pilots like their planes a bit tail-heavy, while pattern pilots like a neutral or slightly forward CG. Sport & scale pilots typically prefer a more forward CG. Those who fly in windy conditions also usually prefer a more forward CG. Some airframes have extremely wide flyable CG ranges, and can be set up quite tail-heavy, while others have very narrow flyable CG ranges. Most scale g/a planes & warbirds fly very poorly with an aft CG, and some will only fly once. Many unlimited aerobatic ships are happy anywhere from goofy tail-heavy to moderately nose-heavy, which covers everything from wild 3D to sport-flying.
Joel
turboparker is offline Find More Posts by turboparker
Old Jan 27, 2013, 07:42 PM
Tim Wolff is offline
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Originally Posted by turboparker View Post
+1!
The most logical reason for a price-drop is simply to spur some interest & increase sales.
Joel
Mission accomplished
Researching the 130x convinced me that the 300x would be my next heli. The price drop got me to pull the trigger.
Stupid mSR.
Tim Wolff is offline Find More Posts by Tim Wolff
Old Jan 27, 2013, 09:40 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Yes, you are measuring the distance from 0 pitch (50% throttle). if you put the blades back towards the tail like the mcpx vid you can measure max/min and anything in between. If you go to a linear pitch curve (0-100) you can measure full positive and full negative pitch. You just push the throttle all the way 100% and measure then lower the throttle to 0 and measure. Of course doing this you need to also verify your servo travel for pitch is not limited and verify you have 0 pitch at center.
You can even measure mid pitch points such as 6 degrees for beastx setup. I setup my 500x with a 12 inch ruler, though it will be nice to get that dual axis gauge
I would suggest doing so, it is under menu G and it is very easy to center the new servo horn.
indoorheli is offline Find More Posts by indoorheli
Old Jan 27, 2013, 10:24 PM
Billz_01 is offline
Find More Posts by Billz_01
Billy
Australia, NSW, Newcastle
Joined Jun 2012
Thankyou Turboparker and Indoorheli, as usual you guys are very informative.
I will have to play around a bit more with the CG on my micro foamy (polecat), figure out what I like. I haven't changed it much from where the book told me it should be, as I'm very very new to fixed wing flying.
Billz_01 is offline Find More Posts by Billz_01
Old Jan 28, 2013, 06:34 AM
Joined Jul 2009
You're welcome! Always happy to help where I can. BTW - if you're new to fixed-wing, you may find my flight-trimming guide useful.
Joel
Old Jan 28, 2013, 07:08 AM
Billz_01 is offline
Billy
Joined Jun 2012
Will do, always happy to learn new things.
I haven't flown mine in a while, we've got a cyclone ATM and have had poor weather for some time, plus I usually take my heli's out on the first sign of good weather as the 300 can handle the wind.
Old Jan 28, 2013, 10:31 AM
clearprop88 is online now
Find More Posts by clearprop88
Joined Apr 2011
I'm in the process of setting up my used, recently purchased 300X.
Since the BX is upside down, and not too accessible for setup. Can I lay it on it's side to do the setup then place it on it's skids to adjust pitch range, and other swash adjustments?
What's the best way to do the BX setup?
clearprop88 is online now Find More Posts by clearprop88
Old Jan 28, 2013, 11:56 AM
indoorheli's Avatar
Joined Sep 2007
glad i can help
Love these forums, without them I would have a been a wreck and so would all my heli's...
yes you can, but did you buy a new ar7200bx or is it a 300x ar7200bx?
If it is a beastx that came with the 300 you can do a factory reset and only adjust maximum pitch, 6 degrees and servo center/swash leveling.
If it is a new ar7200bx purchased separately it has different default settings so you need to set it up from completely from scratch.
When i am setting up a beastx that is upside down, instead of constantly flipping it around I get the beastx cheat sheet for both menus and grab a mirror so i can see the colors of the lights.
If you dont have a pitch gauge, measuring from tip to tip:
6 is 51.2mm
10 is 85.1mm
11 is 93.5mm
12 is 101.9mm
measuring with blades facing front or back like this
Old Jan 28, 2013, 03:41 PM
Joined Apr 2011
[QUOTE=indoorheli;QUOTE]
It's a new BX, so I have to set it up from scratch.
The mirror sounds like a good way to do it.
The last time I used a mirror like that it was when I did an engine overhaul on my sailboat. I put the mirror under the engine, and did the rebuild by looking in the mirror.
Compared to that this should be a piece of cake.
Thanks for the help.
Old Jan 28, 2013, 05:21 PM
hmmm...
Joined Sep 2008
I'm confused on the pitch setup, the measurements you are giving from tip to tip I'm assuming are what you want at full throttle? and I'm assuming if you want 0 degrees would be both tips equal at mid stick?
thanks for all the help
Old Jan 28, 2013, 05:25 PM
stevebarrow is offline
Find More Posts by stevebarrow
Heli Mad
stevebarrow's Avatar
Australia, VIC, Elsternwick
Joined Feb 2002
Yes at mid stick 0 pitch the blades will be level.
stevebarrow is offline Find More Posts by stevebarrow
Old Jan 28, 2013, 11:06 PM
Dan137 is offline
Find More Posts by Dan137
Dan137's Avatar
Australia, VIC, Mount Evelyn
Joined May 2012
[QUOTE=Dan137;23912921]the paint is "Pactra rc car paint lacquer racing finish". made by Testor corporation.
I have to apologise; after flying tonight, and having several crash tests, the paint flaked off the skids really easily. I am guessing that after drying properly it goes hard and becomes less flexible. It was fluro yellow on the skids and competition orange for the tail fin. I have repainted the skids orange to see if this colour is more durable.
It looks great on the tail fin, and that part does not flex. But the skids do get some wear and abuse. If you always land softly and have planned landings, I reckon you will be fine with it.
For some reason I cannot upload any photos.
The link below popped up on the 130x forum. seems better than my spray paint. I tried the orange paint, and it holds up great on the tail fin, but not so well on the skids as they flex heaps on crashes.
http://www.helifreak.com/showpost.ph...01&postcount=1
Dan.
Dan137 is offline Find More Posts by Dan137
Old Jan 29, 2013, 02:52 AM
emeraldc is online now
Find More Posts by emeraldc
west coast flyer
emeraldc's Avatar
Joined May 2012
I have to say I'm super happy with this purchase Got to maiden it Sat. & it went very well For only being into FP Heli's 5 weeks, I'm pretty happy to be able to fly this thing around the field without crashing Unfortunately I got ahead of myself & maidened my Thunder Tiger the next day, and had a stupid little crash!
Lots of practicing to do still....so back to the ncpx & 130x, then I'll think about putting the CF blades on this thing.
Blade 300x maiden flight (2 min 51 sec)
emeraldc is online now Find More Posts by emeraldc
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
