+1 on the Tri-Flow!
I use Tri-Flow on my helis & ground-pounders. Excellent stuff. As Rcflyair noted, it's plastic-safe. It attracts a lot less dirt than the other lubes I've used, and it also leaves a Teflon film behind - which means that I don't have to re-lube as often. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Instead of picking up a new 300 motor, get the 300x motor from Dylan http://astroid-designs.myshopify.com...rushless-motor
Oh just noticed it is out of stock, but can be had here http://donsrc.com/cart/index.php?_a=...&product_id=52 or just sell the 300 and buy a 500x...that'll fix your issues ![]() ![]()
Still in the box. Sorry, I meant Main Shaft (not motor shaft). So what do I expect with the new HH new/re-designed Main shaft? Nice flight with that 500X. Looks like you're loving it than your micros... |
HeliFreak has a thread dedicated to the pitching right problem http://www.helifreak.com/showthread.php?t=474391
Joined Dec 2010
www.con.com/Labelle.html |
I'm reading it now, and it seemed to be not new. Some had experienced the same thing. So that's a big help regarding the link you just shared. Sounds like mechanical according to one of the posts (FBL follower arms). Thanks, - Spyro |
Second is the motor's bearing, which needs to be loctited, or it could also cause some vibe affecting the gyro. 3rd, is the weak (original design) main shaft. So it should be easy fix. Thanks, - spyro |
| Thread Tools | |
| For Sale Trex 700E FBL BeastX BNF 1600$ Shipped | trevjonez | Aircraft - Electric - Helis (FS/W) | 1 | Aug 15, 2011 08:04 PM |
| For Sale Outrage 550 FBL W/BeastX BNF | KenM | Aircraft - Electric - Helis (FS/W) | 2 | Jul 09, 2011 07:20 AM |
| Found BeastX FBL controller | Hellsiege | Aircraft - Electric - Helis (FS/W) | 0 | Jan 28, 2011 02:24 PM |
| Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head | NovaCX12 | Aircraft - Electric - Helis (FS/W) | 1 | Jan 22, 2011 08:07 AM |
| Sold Microbeast BeastX FBL unit NEW never used | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Dec 07, 2010 05:23 PM |
