Old Nov 18, 2012, 02:35 PM
stevebarrow is offline
Find More Posts by stevebarrow
Heli Mad
stevebarrow's Avatar
Australia, VIC, Elsternwick
Joined Feb 2002
Originally Posted by quadracer111 View Post
Redid the 7200 setup again and it seems better. Get wag at 100% in idle up though. I'm thinking vibes from my tracking being out a bit. Will have to play with that.
Do you have cf blades? If not max throttle is 75%
stevebarrow is offline Find More Posts by stevebarrow
Old Nov 18, 2012, 04:53 PM
quadracer111 is offline
Find More Posts by quadracer111
Is getting old...
quadracer111's Avatar
Canada, Saskatchewan, Saskatoon
Yup.
quadracer111 is offline Find More Posts by quadracer111
Old Nov 24, 2012, 03:48 PM
scamair is offline
Find More Posts by scamair
Sniffing the glue
scamair's Avatar
United States, WA, Bellingham
Joined Aug 2010
Help
Just crashed mine after about the 10th flight. The status LEDs are just cycling back and fourth. The throttle still works but no servos move! WTH!
scamair is offline Find More Posts by scamair
Old Nov 24, 2012, 05:16 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
Sorry to hear that. I crashed mine a couple weeks ago. Usually it is just stripped servo gears. you can get a rebuild kit from HH or the LHS for $4.00. I rebuilt two of the servos and am back in the air today.
J_skaggs is offline Find More Posts by J_skaggs
Old Nov 30, 2012, 04:59 PM
Geoff2005 is online now
Find More Posts by Geoff2005
Geoff2005's Avatar
Perth, Western Australia
Joined Jul 2006
Hi,
I'm a noob heli pilot and took my new 300x out for a spin today. It has bad tail shake, I've reduced the gyro gain on the tx to 40% but it is still present. From one pack and two short flights it is hard to say if reducing the gain had an effect.
Should I be looking at any of the tail mechanicals or adjusting the pots on the rx?
How much can the gyro gain be reduced on the tx before it is unflyable?
My only other heli experience is mCPx/mSRx. Tx is JR DSX 9.
regards
Geoff
Geoff2005 is online now Find More Posts by Geoff2005
Old Nov 30, 2012, 06:01 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
Originally Posted by Geoff2005 View Post
Hi,
regards
Geoff
Is your problem a slow side to side movement or vibration you can see in the vertical fin? If it is vibration, it could be your main rotor blades are unbalanced. This happened with my 450X so I changed out the OEM blades for Align blades and heli flew smooth as silk.
Old Nov 30, 2012, 06:09 PM
Geoff2005's Avatar
Joined Jul 2006
Definately not slow oscillation, would be at least a few cycles per second.
Old Nov 30, 2012, 07:09 PM
Heli Mad
Joined Feb 2002
Remember on jr radios the gyro is set on channel 5
Old Nov 30, 2012, 07:10 PM
Heli Mad
Joined Feb 2002
Change ch 5 to 70 and see if that helps. Also check the gear switch position matches the end you set.
Old Nov 30, 2012, 07:11 PM
Heli Mad
Joined Feb 2002
That's in the travel adjust menu.
Old Nov 30, 2012, 09:05 PM
Geoff2005's Avatar
Joined Jul 2006
Oh, by the look of the travel adjust screen the gyro menu I have played with is adressing channel 7 as that line is blanked out. Channel 5 still sais "Gear" so I have adjusted that to plus 70% and -0% so in the monitor screen channel 5 is either 70% or 50% depending on the position of the gear switch.
So in theory I could have had 100% or 0% percent gain depending on the position of the gear switch on the first outing.
I also dropped into the LHS and picked up some CF blades which I installed before getting back to the PC
Old Nov 30, 2012, 09:14 PM
Heli Mad
Joined Feb 2002
You don't want 100% gain that will lead to a fast wag
Old Nov 30, 2012, 09:55 PM
Geoff2005's Avatar
Joined Jul 2006
That is what I appear to have had. Anyway just had another go with channel 5 at 70% and it performed as it should without any shuddering as per first attempt. I also tried flipping the gear switch in flight so channel 5 was changed to the centre position, not sure if that is zero or 50% gain but it wasn't good as the body instantly started rotating. Puting the gear switch back in high position resolved it though.
Old Nov 30, 2012, 10:07 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
I just use the governor screen to setup my gyro with the jr9503. That uses the correct channel.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 30, 2012, 10:10 PM
Heli Mad
Joined Feb 2002
Good to hear it is fixed. Set both ends the same and if you a accidentally change the switch it won't matter.
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
