Old Oct 04, 2012, 10:47 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by PKM_Heliman View Post
I think he was asking "where do you buy the carbon fiber main blades"
Oh... right...
Originally Posted by JustPlaneChris View Post
Other than those, you can use any blade that fits the Gaui X2. BUT, you will need to use shim washers at the root because they are thinner than stock.
You can also use any blades for the 120sr, but again, you need shims. I bought Microheli's from HH for $26.
erkq is online now Find More Posts by erkq
Old Oct 04, 2012, 10:52 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Carbon blades choices for the 300X are very limited right now. The only blades that fit without using shims are the ones offered by Blade themselves:
http://www.horizonhobby.com/products...x-bsr-BLH4501C
I'm flying a set of blades designed for the Gaui X2, purchased from clubheli.com. I like them very much, but unfortunately they are out of stock:
http://www.clubheli.com/255mm-Carbon...55_p_3783.html
Edge makes X2 blades:
http://www.readyheli.com/LE-253-EDGE...s_p_40624.html
As does SAB:
http://helidirect.com/sab-redwhitebl...ht-p-21188.hdx
Until the aftermarket catches up with the 300X, we are basically stuck paying too much for Blade brand CF blades, using the stock woodies, or searching for Gaui X2 blades.
Chris
I am waiting for the Edge blades. I hate all black blades.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Oct 04, 2012, 11:31 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
No, not 120-SR blades - that's a fixed pitch helicopter.
http://www.horizonhobby.com/products...sr-rtf-BLH3100
Blade SR blades are the ones you want - but there is a difference between the Blade SR wood blades and the 300X ones - the 300X blades have a metal bushing in the grip. The Blade SR CF blades are the same as the 300X CF blades.
http://www.horizonhobby.com/products...-heli-EFLH1500
jasmine2501 is offline Find More Posts by jasmine2501
Old Oct 04, 2012, 11:38 AM
erkq is online now
Joined Dec 2010
Quite right. You meant what I knew. Thanks for the correction. I don't know how the "120" slipped into my post.
Old Oct 04, 2012, 12:10 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
As do I, but I fixed that with a couple of stripes of white self-adhesive Monokote trim.
Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Oct 04, 2012, 12:22 PM
erkq is online now
Joined Dec 2010
Chris
Make sure you balance the Monokote! I'm not kidding... every little bit of balancing helps.
Yeah... I found the black ones more difficult to keep orientation. I was kind bummed too because the pic on HH's web site shows white blades for the Microheli product. They look cool anyway... but my next CF's will be white for sure.
Old Oct 04, 2012, 03:03 PM
Austin, TX
Joined Sep 2005
These blades were perfectly matched for CG and weight, which was nice. I used the full width of the trim (about 5") and did a complete wrap of the blade,and I made sure to put it exactly the same distance out on each side, of course. CG and weight were still matched after the trim was applied.
I will also be experimenting with vacuum-bagging epoxy/fiberglass over the stock blades (after removing the shrink wrap of course) to see if they can be made stiff enough for aggressive flying. Honestly, they aren't too bad as-is, especially if you re-shrink the covering before flying them.
Chris
Old Oct 05, 2012, 09:42 AM
PKM_Heliman is offline
Find More Posts by PKM_Heliman
United States, TX, Belton
Joined Sep 2009
I have the mSR, NcpX, McpX, 130X, T-rex 250 (that I can't get operating correctly) and the Blade 400 3D. I LOVE the 130X the most...I want to buy either another 130X or the 300X. Which would you guys recommend, and why?
PKM_Heliman is offline Find More Posts by PKM_Heliman
Old Oct 05, 2012, 10:29 AM
Blackanthem is offline
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
Just replaced my Tail Servo, and wanted to show you all the melted one.
Description:
I did as you all suggested with the BeastX, and she fly's great.
Thanks again for all of your help.
Blackanthem is offline Find More Posts by Blackanthem
Old Oct 05, 2012, 11:05 AM
BuzzBomber is offline
Find More Posts by BuzzBomber
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
Mmmm, crispy!
BuzzBomber is offline Find More Posts by BuzzBomber
Old Oct 05, 2012, 12:19 PM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Kind of depends on how big your flying field is. If you have a lot of room go for the 300x. If your flying field is on the small side, go for another 130x.
wavekatcher is offline Find More Posts by wavekatcher
Old Oct 05, 2012, 12:45 PM
Joined Aug 2011
If anyone has been looking for a swash tool.
http://www.rakonheli.com/rkh/index.p...d=282&Itemid=1
RKH CNC Swash Leveler (Red) - Blade 300X
Old Oct 08, 2012, 06:05 PM
You down with EPP?
Houston, Tx
Joined May 2009
I was looking for one of those
Well, I gave up tweaking this heli at a 100% head speed. Tail blow outs, serious bogging......
I turned it down to 85%, no problems, and I really can't tell the difference in power. This is with CF blades.....
Only thing I can figure is my blade pitch isn't spot on. It's a pain on a heli this size, but I have a digital gauge on its way.
Old Oct 08, 2012, 06:17 PM
Joined Aug 2011
Waiting to get the swash tool, and then I am going to tare the 300 down, from top to bottom.
I have a vibration somewhere, that is causing the helicopter to do a dip / tilt to the right. Not all the time, and not uncontrollable ,but just enough that when taking off or landing... its in the back of your mind.
Old Oct 09, 2012, 01:58 AM
DanBo3D is offline
Find More Posts by DanBo3D
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
Just a heads up guys.... I recently relocated the AR7200BX to the top mount like the 450X using 3M 4010 double sided tape.
Apparently I messed up the setup so when I went to try and test fly/hover all it would do is tip over left (no damage) and then tip over right (no damage). Upon inspection after a few tip overs I noticed it had lost collective pitch, the swash would just move about an 1/8". I tried everything to no avail. So I called HH & got right thru, customer service rep was very helpful but we couldn't figure it out and he told me the main guy was on another call and he would call me back. 5 minutes later he calls and says do a "reset" followed the procedure on page 9 while still on the phone and BAM! All the collective travel was back! The reset wipes out previous setup values of course. Taking my time and just following the manual I totally redid it and changed the settings for the relocation of the unit and it hovered perfectly.
I still have no idea why the swash travel got lost but one good thing from this is I can now setup an AR7200BX from scratch. It's really relatively easy once you do it. Now that the BX is on top it's the way I thought it should have been from the start, it bothered the heck out of me where it was. Any setup changes are just so much easier now and the boot up & status is very convienent to see as it should be.
DanBo3D is offline Find More Posts by DanBo3D
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
