Old Oct 03, 2012, 12:23 PM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
Yeah, it's a smaller heli with less mass, less power, and a higher disc loading. It's never going to fly like the 450X unless you stretch it to run longer blades and add more power. But then.... well, you may as well fly the 450X.
Chris
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Oct 03, 2012, 10:52 PM
Robbi is offline
Find More Posts by Robbi
Joined Sep 2012
Hi! I want to buy 300x. Say tail Servais he needs to change? if so, on what?
Robbi is offline Find More Posts by Robbi
Old Oct 03, 2012, 11:16 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Can you re-state? This makes no sense.
erkq is offline Find More Posts by erkq
Old Oct 03, 2012, 11:38 PM
Robbi is offline
Joined Sep 2012
Requires replacement of the tail servo, or not?
Old Oct 03, 2012, 11:40 PM
Robbi is offline
Joined Sep 2012
Why not make sense?
Old Oct 03, 2012, 11:52 PM
erkq is offline
Joined Dec 2010
Why not make sense?
Really? You want an answer to this? OK. What's a "Servais" and why is it capitalized? And who is "he"? And who "Say" it? "on what"?? what does that mean?
My apologies if English is not your first language for sure!
In any case I'm flying it fine on the stock servo. I think many others are OK too. It seems you can do better speed-wise (accuracy too?) and this heli is good enough to have it make a difference. But like anything else it's a matter of degree. I read where one guy had it melt! That's a little worrisome, hoping that was just a malfunction.
Old Oct 04, 2012, 12:08 AM
Robbi is offline
Joined Sep 2012
Servos tail replaced?
Yes. My English is very bad. But I need to know.
pardon me
Old Oct 04, 2012, 12:15 AM
erkq is offline
Joined Dec 2010
pardon me
Very sorry for giving you a bad time.
You can replace it later if you want. It is very flyable with the stock servo. The tail stays locked in for me. I'm sure others will chime in.
Old Oct 04, 2012, 12:20 AM
Robbi is offline
Joined Sep 2012
Do you like this helicopter?
Replace with what?
Tell me more.
Thank you!
Old Oct 04, 2012, 12:22 AM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Replace with what?
Tell me more.
Thank you!
Robbi,
I have only been flying the 300X for a short while, less than 10 flights, but I VERY MUCH like this helicopter. The only thing I have done is replace the main blades with Carbon Fibre blades. It flies great, and the tail holds VERY well in the mild 3D and normal flying I put the helicopter through.
Good luck,
Marlin
Fish99 is offline Find More Posts by Fish99
Old Oct 04, 2012, 12:30 AM
erkq is offline
Joined Dec 2010
Replace with what?
Tell me more.
Thank you!
I like it very much. But I don't push it hard. It's a stable enough machine that I have never crashed it, not even a hard landing. I'd say don't worry about the tail servo right away. Go ahead and fly it stock. And, like Fish says, get the CF blades. This is a better upgrade than the servo. It really smooths things out. If you do want to upgrade the tail servo, here's a digital someone has used: http://helidirect.com/align-ds425m-d...01-p-26780.hdx
Old Oct 04, 2012, 12:33 AM
Robbi is offline
Joined Sep 2012
erkq, thank you very much! Where to buy the blades? I would appreciate it!
Old Oct 04, 2012, 01:25 AM
erkq is offline
Joined Dec 2010
I got a great deal at a little store in Salem, OR when I was visiting my in-laws. $320, no tax, no shipping, but you have to go to Salem! I don't know where others are buying theirs.
Old Oct 04, 2012, 03:18 AM
PKM_Heliman is offline
Find More Posts by PKM_Heliman
United States, TX, Belton
Joined Sep 2009
I think he was asking "where do you buy the carbon fiber main blades"
PKM_Heliman is offline Find More Posts by PKM_Heliman
Old Oct 04, 2012, 08:34 AM
Austin, TX
Joined Sep 2005
Carbon blades choices for the 300X are very limited right now. The only blades that fit without using shims are the ones offered by Blade themselves:
http://www.horizonhobby.com/products...x-bsr-BLH4501C
Other than those, you can use any blade that fits the Gaui X2. BUT, you will need to use shim washers at the root because they are thinner than stock.
I'm flying a set of blades designed for the Gaui X2, purchased from clubheli.com. I like them very much, but unfortunately they are out of stock:
http://www.clubheli.com/255mm-Carbon...55_p_3783.html
Edge makes X2 blades:
http://www.readyheli.com/LE-253-EDGE...s_p_40624.html
As does SAB:
http://helidirect.com/sab-redwhitebl...ht-p-21188.hdx
Until the aftermarket catches up with the 300X, we are basically stuck paying too much for Blade brand CF blades, using the stock woodies, or searching for Gaui X2 blades.
Chris
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
