Old Oct 03, 2012, 06:58 AM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Originally Posted by quadracer111 View Post
Trying to decide if I want the 300x or a 450x.. I hear crash costs on the 300x is just as much as a 450.. Flying space isn't an issue, don't really want to go bigger than a 450 atm, thoughts? I looked at the 300x today at the lhs and it's darn cute! Erhm, I mean.. *most masculine voice*, It's a very nice rig.
450x all the way!!! I have both, not sure why I have the 300x?
450 has a ton more power.
I did just buy a 10T pinion for my 300x, hoping that it flies more like my 450 now....
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Oct 03, 2012, 09:00 AM
pmerritt is online now
Find More Posts by pmerritt
Joined Oct 2010
I would think you can probably fly the 300x in a slightly smaller area than the 450x also, i find that it's relaxing to fly a less powerful heli when you just want to do basic stuff.
pmerritt is online now Find More Posts by pmerritt
Old Oct 03, 2012, 09:05 AM
You down with EPP?
Houston, Tx
Joined May 2009
They both falli in the category "too big to fly in the hood"
So it doesn't make much of a difference. The 300x is more tame for sure though. I would fly it in the street before my 450. Head Speed is a huge difference between the two. That accounts for noise and scare factor.
Old Oct 03, 2012, 09:33 AM
JustPlaneChris is offline
Find More Posts by JustPlaneChris
JustPlaneChris's Avatar
Austin, TX
Joined Sep 2005
And that is exactly why I bought one.
As has been pointed out though, the 450X is just as cheap to crash (possibly cheaper, considering the low price of 325mm blades) and does have more power. I guess it just depends on what you want. Me? I already have a "450" size heli (MSH Mini Protos with 6S power, stretched tail boom and 350mm blades) so the 450X would have been redundant. The 300X was just.... err.... cute.
I've installed a 10T pinion, an ESC with a governor (Castle Phoenix 25) and carbon blades. Running a governed 3200 rpm headspeed and +/- 14 degrees of collective woke it right up!
Chris
Blade 300X on a breezy Sunday (5 min 57 sec)
JustPlaneChris is offline Find More Posts by JustPlaneChris
Old Oct 03, 2012, 09:36 AM
Blackanthem is online now
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
I went from the 120SR to the 300X and totally dig the 300X. I have a 450X as well, and now that I am waiting for a tail servo for the 300X, I am getting more flight time with the 450X. The scare factor is slowly becoming less and less.
Nice flying in the Vid. I was just about to take my Sim learning, into real life when the tail servo went.
Blackanthem is online now Find More Posts by Blackanthem
Old Oct 03, 2012, 09:42 AM
You down with EPP?
Houston, Tx
Joined May 2009
Chris
http://www.youtube.com/watch?v=8yTrXFzRgO0
I just picked up a 10T pinion for my 300x. Do you suggest changing ESC's? I really don't have much experience with logging Heli data.
I just want to be sure that the motor and ESC can handle the 10T pinion.
Old Oct 03, 2012, 09:43 AM
Austin, TX
Joined Sep 2005
Thanks!
That's what I'm trying to do with the 300X as well. I do things on the sim that I'm just too chicken to try with my nicer helis.
The only reason I went for the 10T pinion is because I needed the "overhead" in the gearing in order for the governor mode to work properly. If you have the stock ESC, the 9T pinion at 100% will give you the same basic power level you see in that video. In fact, here's someone else flying with the stock 9T at 100%, and as you can see it works very well. I'd say try it at 100% with carbon blades, and just increase your collective range a bit before you go to the 10T.
Blade 300X 3D flight in field / Carbon fiber blades (4 min 41 sec)
Chris
Old Oct 03, 2012, 10:21 AM
You down with EPP?
Houston, Tx
Joined May 2009
Thanks!
http://www.youtube.com/watch?v=H6RtgGw9VpY
Chris
No motor bogging issues with 14 degrees of pitch at 100% (Stock pinion) ??
Old Oct 03, 2012, 10:42 AM
Austin, TX
Joined Sep 2005
Well sure, you can bog it!
You really only hit the high pitch ranges for quick starts and stops, and if you lean into it you will bog for sure.
When you run a high collective pitch range you have to use good collective management, but it does give the heli a more lively personality.
Chris
Old Oct 03, 2012, 10:44 AM
You down with EPP?
Houston, Tx
Joined May 2009
Chris
I will try some different things with it. Thanks. It's more of a backup for my 450, but I am trying to pep it up a bit.
Old Oct 03, 2012, 10:51 AM
Austin, TX
Joined Sep 2005
The biggest change I made was just going to CF blades, running 100% throttle (with the stock ESC) and upping the collective range from stock. Woke it right up!
I only changed to the 10T / Castle ESC because I'm spoiled to governor mode in all my other helis.
Chris
Old Oct 03, 2012, 11:40 AM
You down with EPP?
Houston, Tx
Joined May 2009
Chris
Already have the CF blades, Throttle is already at 100%, I need more...
I'm just used to my 450X.
It's like going to your MCPX after a while of flying real Heli's. Uh.... is something wrong with this thing?
Old Oct 03, 2012, 11:43 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Sounds like something is wrong... mine is very punchy, and I have a whole mile less air to work with. I'm not even running the 100% flat curve and it's pretty punchy.
jasmine2501 is offline Find More Posts by jasmine2501
Old Oct 03, 2012, 11:57 AM
You down with EPP?
Houston, Tx
Joined May 2009
I am comparing it's full pitch pull out, and vertical lines
Anyone know of a good alternative motor? Mine is a lot louder now than it used to be. I might need a motor soon.
Old Oct 03, 2012, 12:06 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Well you cant compare it to a 450 since it doesnt have near the same power as one. I had to try to do nice tic tocs and such with the 300x but my 450 is effortless
Still it is decent stock but if you want more ummph change pinions
indoorheli is offline Find More Posts by indoorheli
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
