Good luck! Larry |
I'm loving mine. It flies really big - more like the 500-class birds I've flown in the sim - yet it is the perfect size for my yard. It also handles a lot of wind. I plan to mount a camera so I can play around with on-board video. Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
I would love to see that video when you shoot it, look forward to your posting it on your YouTube channel. Going to have to get a set of CF blades for this bird, as I really want to get the throttle curve up to 100%. That said, with stock settings it seemed to have plenty of power for mild 3D. (Not that I am brave enough yet to do more than a quick flip.) Talk to you Joel, Marlin |
I'll definitely post the video if it turns out. BTW - I'm running Eflite's CF blades & they're great. The bird is smooth as butter in IU with a flat 100% throttle 'curve', and it is very responsive. ![]() I flew a bunch of flights in my open north yard today. Next, I'm going to try flying in my backyard right from my deck like I do with the 130X. Happy flying! Joel |
I am pretty disappointed on HH on this one. I got my heli back last week that I had sent in with a tail servo that died midflight and the main issue the elevator servo arm rubbing against the bell. The rub caused other issues like the stripped gear in the elevator servo. I got it back and all they did was replace a gear set and took the tail servo and didn’t replace it. They told me they test flew it and did not see any issues at all and sent me my heli back. When I got the heli back I noticed the servo link that was half way worn through still!
So little irritated I called them again and they told me to keep an eye on it and watch for more wear but they test flew it and it showed no signs of any more wear and that product design would call me and discuss it..why or what they could do I don’t know but they never called. I then called back a few days later and talked to a very nice rep and he sent me call tags to send it back and couldn’t understand why it came back to me like it did. But I decided before I sent it back I should fly it one more time see how it went as I do love this little heli when it is airworthy. So I bound it and noticed I had to do major adjustment on the elevator servo link since it was way out and had to do major adjustment on the pitch links to get zero pitch at center again. I shortened the links and then switched the elevator link around so the half eaten link was on the swash and the perfect one was on the servo arm, then I did a 30-40 second flight with about 6-8 mild flips and landed. When I pulled off the canopy the crispy clean link now showed a slight cut in it were it had come in contact with the motor bell….. So I am not too sure if they really did test fly it as I noticed rub right away and the elevator and pitch links being so far off… But anyhow thanks to the nice rep I talked to it will be shipped back off to them today with a note of my extreme disappointment on how they first handled this situation. I really do not feel safe flying this thing as is as obviously there is something wrong with it |
And, I've never seen a helicopter that didn't have "tail problems" - some of it is due to poor adjustment of things, but a good amount of it is due to people complaining about things that are perfectly normal. This happens with every new helicopter, regardless of who makes it. Go and look at the new release threads over on Helifreak - you won't find a single one where somebody doesn't complain about the tail. |
But all in all they have good products, not top of the line but good none the less. I have had many good eflite planes and only one issue with a servo that didn’t want to reverse. It happened over a year after I owned it still not sure why it won’t reverse but HH sent me out a micro servo reverser for it even though the product is discontinued. I have also had many blade heli's that have worked as advertised. I think my heli is just a random bad heli and has flex..and the cs i received the first go around was less than stellar and I am disappointed it wasn’t fixed on the first attempt. My last 450pro V2 came with bad tail bearings and i had no other choice then to go buy a new set. If it was Blade I would call HH and they would send me new ones out. I was a little irritated about such an expensive Align kit having issues and it doesnt come with any support. Not only that but the tail geometry is still out of whack (they knew it was long ago) and i had to adjust the tail during build to compensate. |
| Thread Tools | |
| For Sale Trex 700E FBL BeastX BNF 1600$ Shipped | trevjonez | Aircraft - Electric - Helis (FS/W) | 1 | Aug 15, 2011 08:04 PM |
| For Sale Outrage 550 FBL W/BeastX BNF | KenM | Aircraft - Electric - Helis (FS/W) | 2 | Jul 09, 2011 07:20 AM |
| Found BeastX FBL controller | Hellsiege | Aircraft - Electric - Helis (FS/W) | 0 | Jan 28, 2011 02:24 PM |
| Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head | NovaCX12 | Aircraft - Electric - Helis (FS/W) | 1 | Jan 22, 2011 08:07 AM |
| Sold Microbeast BeastX FBL unit NEW never used | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 0 | Dec 07, 2010 05:23 PM |
