Old Sep 05, 2012, 11:00 PM
BuzzBomber is offline
Find More Posts by BuzzBomber
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
Well, add me to the list of 300X owners with a snapped main shaft. I've got <10 flights on the heli, and took it to the club field for the first time today. I was sport flying in IU @ 75% , a couple flips and full pitch climbouts and lazy funnels, when the timer went off I brought it in close in a stable hover about to descend from 5' or so, and it pitched left and started dropping all of a sudden-headspeed dropping. It wasn't responding to the right cyclic and pos. collective I put in but the tail still had control. Next thing I know it was in the weeds next to the safety fence. Busted main shaft, no other apparent damage.
Guess it's time to call Horizon and let them know another one bit the dust...
BuzzBomber is offline Find More Posts by BuzzBomber
Old Sep 07, 2012, 12:49 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
indoorheli is offline Find More Posts by indoorheli
Old Sep 07, 2012, 04:42 PM
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
A followup, FWIW. I just got off the phone with Horizon. I explained that I was calling to report a broken mainshaft and told the rep what happened as best I could explain. I was informed that there have been a few reported failures, and for my troubles I was offered a new main shaft, which I did not expect but accepted gratefully. Hopefully, the new shaft lasts longer, and Kudos to Horizon product support for standing behind the product.
Old Sep 08, 2012, 05:58 AM
Hexperience is offline
Find More Posts by Hexperience
devIAtion..one TX to bind them
Hexperience's Avatar
Canada, ON, Georgina
Joined Aug 2011
I got mine a couple days ago, is the main shaft completely hollow? It shouldn't be long before an aftermarket shaft is around but I hope horizon fixes the problem one way or another.
Hexperience is offline Find More Posts by Hexperience
Old Sep 09, 2012, 07:22 PM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
Anyone have trouble with a loose main gear? Mine rotates a few degrees on the mainshaft. I found that the hole in the mainshaft is larger than the shoulder bolt. It did not start out that way. Could this be a precursor to shaft failure? Hmmm....
Joel
turboparker is offline Find More Posts by turboparker
Old Sep 09, 2012, 08:18 PM
DanBo3D is offline
Find More Posts by DanBo3D
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
Joel
Joel, from the couple that I own and a few others I checked while all brand new never run, they all move. You can hold the mail gear and the head will rotate back and forth. I thought it was strange on my new 300x but when I checked a couple of other new ones they were all the same. Sooooo it is normal and nothing to worry about from what I've seen on 3 brand new helis....
Concerning main shaft breakage, frame flex and vibes could break a shaft.
But a hardened shaft should not be so brittle it snaps. I think Blade must of got the tempering very wrong on the shafts or they were not tempered at all and are just too brittle for this heli. Usually a main shaft will bend in a crash and hardly break. Because they were hard enough but not so brittle they snapped.
My thought is just a poorly heat treated & tempered steel is the main problem.
DanBo3D is offline Find More Posts by DanBo3D
Old Sep 10, 2012, 06:08 AM
TurboRacer is online now
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
Joel
Yes, that is one of the design flaws with this heli. I wish HH would wake up and start making the main shaft holes the proper dimension.
TurboRacer is online now Find More Posts by TurboRacer
Old Sep 10, 2012, 10:44 AM
Joined Jul 2009
Thanks, guys. Since I only have one 300X & none of my flying buds have one, I had no reference point. I might fill the hole with JB weld & re-drill it, as some have done.
BTW - while I had the head torn down, I installed the aluminum head block & FBL follower arms. With two shims, the plastic grips were a bit draggy on the metal head block. I removed one shim on each side, which solved the problem. Also, the supplied head button screw bottomed-out on the feathering shaft before the button was tight. Spooling up, I noticed that the swash gyrates slightly as the head rotates. The mainshaft must be a bit off. I assume it's been that way since day-one, given that I have never crashed the bird or even had a blade-strike. Looks like I found the source of the slight main rotor vibration I feel when spooling the bird up in my hand without main blades. It may also be the source of the main gear runout. Guess I'll pick up a pair of mainshafts while I'm at my LHS today.
Aside from a few minor issues - I'm loving my 300X!
Joel
Old Sep 10, 2012, 11:01 AM
lkagan is offline
Find More Posts by lkagan
lkagan's Avatar
United States, FL, Boynton Beach
Joined Aug 2011
Has anyone tried a 10t pinion yet?
lkagan is offline Find More Posts by lkagan
Old Sep 11, 2012, 03:56 AM
RacingSOUL is offline
Find More Posts by RacingSOUL
Joined Sep 2012
Hello everyone! I'm planning to buy 300x, what batteries do you recommend and what flight times to expect with mild 3D flying?
RacingSOUL is offline Find More Posts by RacingSOUL
Old Sep 11, 2012, 05:47 AM
lkagan is offline
lkagan's Avatar
Joined Aug 2011
SkyLipo 30c 1300. Light and plenty powerful. The come down only slightly warm. Stock lipos are terrible, really weak. Nanotechs are a bit bulky.
Old Sep 11, 2012, 06:56 AM
Joined Sep 2012
Thank you, Ikagan!
Old Sep 11, 2012, 09:17 AM
Joined Jul 2009
Joel
Update:
Disassembled the head & checked the mainshaft on a straightedge. Sure enough, it was slightly bowed - even though I have never crashed the bird or even had a blade-strike. I checked the new shafts, and one of them was also slightly bowed. I also checked the slop in the main gear mounting hole of the new shafts. It was the same as the original - so it appears that no wear has occurred in that area. I installed the straight shaft & spooled her up in my hand without main blades. The main rotor was so smooth that I could feel a slight imbalance in the tail. I balanced the tail rotor & the bird now feels smooth when I spool her up in my hand.
The test-flight confirmed that everything is functioning as expected. Plus, the new mainshaft reduced the main gear runout to the point where it is no longer audible in flight.
Joel
Old Sep 12, 2012, 11:42 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Well, new 300X owner this week! I have been thinking about moving up to a bigger heli from the mCPX for a while and was not sure where to go. Didn't want to go old tech with the SR, but find the 450 size birds a bit pricy and intimidating. This one was perfect.
Maiden flight went great, just some hovering and FFF in what turned into a pretty good wind. No issues though, the bird handles wind quite well.
Took it out tonight on the 3rd flight and managed to do my first flip to inverted and flip back. WOW, even with the stock wooden blades and only 75% throttle speed this heli is great to fly. Tail was rock solid and such a pleasure after all the blow outs on the mCPX unless you are dead perfect and working on a fresh lipo!
I can see this one will be more than enough heli to challenge me and learn on for a while.
Great thread as well, TONS of interesting and informative information.
Marlin
Fish99 is offline Find More Posts by Fish99
Old Sep 13, 2012, 05:43 AM
stevebarrow is offline
Find More Posts by stevebarrow
Heli Mad
stevebarrow's Avatar
Australia, VIC, Elsternwick
Joined Feb 2002
anyone experienced this? after 5 flawless flights my 300X has started twitching the cyclic controls - that is I am hovering and without any control input it banks hard right (and only ever right). It does this now and then (4-5 times in a 4 min flight) and it quite annoying.
The only time I seem to stop the twitch is when I fly with the canopy off...
stevebarrow is offline Find More Posts by stevebarrow
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
