Old Aug 29, 2012, 02:09 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
So no one is willing to push a button on the beastx and find out what parameter B and D is set to for out of the box 300x?
indoorheli is offline Find More Posts by indoorheli
Old Aug 29, 2012, 02:57 PM
Alan Hahn is offline
Find More Posts by Alan Hahn
Chicago 'burbs
Joined May 2006
It's no secret, it's in the 300X manual--- page 12
Parameter B is transmitter mode (blue solid), D is "medium" (red solid).
These are the defaults, and what you will get when you hit the reset on an AR7200BX that comes with a 300X. Not what you get when you purchase the AR7200BX by itself.
Alan Hahn is offline Find More Posts by Alan Hahn
Old Aug 29, 2012, 03:36 PM
indoorheli's Avatar
Joined Sep 2007
Dont have the manual anymore for the 300x anymore only the beastx. I would have checked this myself via the beastx if i had gotten it back from HH yet..but they are taking their time. I still wonder what they say about the frame flex in mine as there is no vibes or damage to my heli and it started happening after a few mild flights.
Interesting that it has a different factory reset/default than stock of the shelf ar7200bx's -thanks
Old Aug 29, 2012, 03:57 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Is that even possible? Where's the Horizon official report saying that?
jasmine2501 is offline Find More Posts by jasmine2501
Old Aug 29, 2012, 04:13 PM
indoorheli's Avatar
Joined Sep 2007
I would imagine HH can really do anything the like to make it easy and less complaints from users. After seeing that they do really it makes quite a bit of sense for the BNF people who dont like or dont know how to setup a heli from scratch to make it easy for them to get back to stock settings. Also I am sure it would make it a lot faster setting up a whole bunch of 300x's off the line
I guess the manual for the 300x states factory defaults and resets for parameter B as blue solid (TX expo and rate control)
My brand new AR7200BX in my 450pro has a factory default of sport (red flashing) for parameter B
Old Aug 29, 2012, 04:21 PM
Rocket Programmer
Joined Jul 2007
Interesting. I have one of the receivers for my 500 but I haven't opened it, still waiting on other parts. Will have to check this out.
Old Aug 29, 2012, 04:43 PM
indoorheli's Avatar
Joined Sep 2007
Actually now knowing the 300x ar7200bx factory default settings are in the manual and pulling it up online, lots of factory defaults are different from the off the shelf model.
Old Aug 29, 2012, 04:59 PM
Rocket Programmer
Joined Jul 2007
Yeah that's what I was going to check. I wonder if we can flash it ourselves somehow. If you can, then what I would do is find out my settings, and flash it to that as the default, so if I accidentally messed something up I could just reset it.
Old Aug 30, 2012, 08:34 PM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
OK, NOW I AM SERIOUSLY PISSED OFF.... This is the second drive shaft that has snapped under little or no stress. I was literally hovering at 100% headspeed with the HorizonHobby carbon fiber blades and the shaft just snapped. I was only 5 feet off of the ground and no damage to the blades or anything else but it is a PITA to keep changing shafts. I don't have confidence to do 3D and not experience a failure.
Horizon Hobby needs a very fast engineering response to this issue.
thekubiaks is offline Find More Posts by thekubiaks
Old Aug 30, 2012, 09:00 PM
leafs04 is offline
Find More Posts by leafs04
leafs04's Avatar
Canada, AB, Edmonton
Joined Aug 2009
Make sure you call them....happened to me 2. But my carbon blades did not make it They told me less then 1% of shafts reported broken( so its not a issue)
My broke after I changed the shaft after 80 flights with the stock shaft.......I put back the stock shaft to scared to use the other shaft in the bag
leafs04 is offline Find More Posts by leafs04
Old Aug 31, 2012, 03:59 PM
Joined Aug 2010
Some more info on this problem. Both times the main shaft snapped at a head speed of 100%, never when running at 80 - 90%. Both times, broke teeth in the DS76 servos, with no hard impact, just a sick sounding flutter to the ground after the shafts broke. Glad the DS76 gear sets are < $3, I'm getting quite good at replacing the gears And, for bonus points, the plastic frame cracked right by the main tail drive gear...
I can't imagine how much damage will occur if I bang it in, probably shatter.
Old Aug 31, 2012, 06:39 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
The fact that the shaft breaks in mid air 1% of the time is too much. That is incredible. I guess I will turn down my head speed to 85%
I will definitely need to dial in more negative pitch now.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Sep 02, 2012, 05:46 AM
aerotony is offline
Find More Posts by aerotony
Australia, NSW, Harrington Park
Joined Apr 2008
Originally Posted by TurboRacer View Post
My tail servo died in flight the other day. About 25 packs through it.. HH is sending a new one but backordered till 9/20!
I didn't care because it's junk anyway. Put in a Savox SH-0262MG and test hovered it. Flew fine, felt real quick and solid. I'll know after a flight at a field tomorrow.
Hi TurboRacer,
Any further information on the Savox servos?
Tony
aerotony is offline Find More Posts by aerotony
Old Sep 02, 2012, 07:32 AM
TurboRacer is offline
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
Originally Posted by aerotony View Post
Hi TurboRacer,
Tony
Works great! Feels good, quick and crisp. Much better than the stocker.
Had to reverse it on my TX and change sensor direction in BeastX menu then all was good.
TurboRacer is offline Find More Posts by TurboRacer
Old Sep 02, 2012, 02:57 PM
malcolxl is offline
Find More Posts by malcolxl
DX6i,DX7..low on model memory!
malcolxl's Avatar
SUFFOLK, ENGLAND
Hi if i want to use other than stock servos on cyclics but keep the stock servo on the tail, what do i have to do to the beast unit? what are a good alternative servo to the stock units, as I can't get them here in england.
Colin.
malcolxl is offline Find More Posts by malcolxl
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 09:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 08:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 03:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 09:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 06:23 PM
