Aug 22, 2012, 12:00 PM
Chicago 'burbs
Joined May 2006
Originally Posted by thekubiaks
My 300X has some slop in the tail blades. I can pull and push the tail blades inward and outward from the center shaft about 1mm. I immediately thought the screws holding the tail blade grips on had worked themselves loose.
After dis-assembly, everything is tight and loctited but I can still pull and push the tail blades. Maybe I need to add some shims? Is this by design? Does your 300X have this slop? Thanks.
The slop you are talking about will be completely taken out when the heli spools up. The main issue, IMHO, e.g. it that the slop is symmetrical, both blades move out the same amount. Otherwise the tail won't be balanced.
On my 300X, I have the same slop (and at first also thought the bolts weren't tight, but obviously they were. On the other hand, my 300X is really vibration free.
