Old Jul 16, 2012, 04:14 PM
dkfuji is offline
Find More Posts by dkfuji
RC Helis: My Healthy Obsession
The OC, California
Joined Feb 2007
I got a chance to have Manny really bang my new 300X around yesterday at the field and it was awesome. Aside from a slight vibration from those awful woodies (CF mains is the next upgrade), it did everything straight out of the box. I made sure that I added loctite to the feathering shaft screws to keep the blades on her during the flight. So far, I am really happy I bought this one. Really didn't need much in pre-flight except balancing the tail and main blades and a dab of loctite. Oh, I also went into the Rx to adjust the +/- pitch limits. It had a little more negative than positive out of the box with my JR9303 Tx (running +/-13*).
dkfuji is offline Find More Posts by dkfuji
Old Jul 16, 2012, 04:52 PM
wlee1017 is offline
Find More Posts by wlee1017
wlee1017's Avatar
Joined Jul 2011
yes, the stock wood blades are not vey good and out of balance. I am looking for 245mm cf blades or compatible replacement. HH 300X cf blades on pre-order only.
wlee1017 is offline Find More Posts by wlee1017
Old Jul 17, 2012, 08:15 AM
jimmiedac is offline
Find More Posts by jimmiedac
jimmiedac's Avatar
United States, MI, Shelby Township
Joined Mar 2011
WOOHOOO!!! I got notification Ampdraw has shipped my 300X !!! It should be here by Friday! Guess I need to get those EC3 connectors installed on my extra batteries!!! Wohooo!
Regards,
J
jimmiedac is offline Find More Posts by jimmiedac
Old Jul 17, 2012, 10:22 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Hehe... I'm totally stopping by the hobby shop tonight whether they call me or not. Sometimes they forget to call me about important stuff like this
jasmine2501 is offline Find More Posts by jasmine2501
Old Jul 17, 2012, 10:53 AM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
I wonder how much tweaking there will need on the beastx. I haven't really worked with this rx and all the settings. I know it is pre loaded for the 300, but just not sure how much settings will need to be changed.
J
jabsten is offline Find More Posts by jabsten
Old Jul 17, 2012, 11:13 AM
Rocket Programmer
Joined Jul 2007
J
It will only need to be changed if you don't like it. Most people are seeming to like the stock settings. Things like flying at high altitude may require small changes, I'll let you know
Old Jul 17, 2012, 11:16 AM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
Thanks Jasmine Mine should be here by next week.
J
Old Jul 17, 2012, 03:21 PM
Roblister is offline
Find More Posts by Roblister
North West UK
Joined Nov 2010
The defaults are very good and well thought out. Mine flew straight out of the box. The BeastX has been set to take throttle and pitch curves rather than its own settings. The suggested transmitter settings in the manual seem to work well for me. I am not up to 3D standard by any stretch of the imagination.
Roblister is offline Find More Posts by Roblister
Old Jul 17, 2012, 04:07 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
I heard not to go past 75 in idle up...it causes vibrations. Can someone who has this heli have any experience going past this?
J
Old Jul 17, 2012, 04:44 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
J
It's not a matter of "just hearing it". The addendum that ships with the bird clearly says not to go above 75% with the stock blades when running a flat throttle curve. It also shows a recommended V-curve for the woodies. Why tempt fate? I'm not cranking-up the HS on mine until I install the c/f blades.
Joel
turboparker is offline Find More Posts by turboparker
Old Jul 17, 2012, 04:46 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Joel
Are you guys referring to travel adjustment for the pitch servo??
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Jul 17, 2012, 04:47 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
indoorheli is offline Find More Posts by indoorheli
Old Jul 17, 2012, 04:51 PM
jabsten is offline
Can't get enough
jabsten's Avatar
Joined May 2010
Joel
I wasn't going to tempt fate....I don't have it yet and was going by the manual. Didn't see or read the sheet in there.
J
Old Jul 17, 2012, 05:07 PM
Blackanthem is offline
Find More Posts by Blackanthem
Blackanthem's Avatar
United States, TX, Houston
Joined Aug 2011
Search and search I did. I still have not see a real good answer on what Lipo, will fit the 300X. Or maybe I have, and I am just a little dense.
What would be a good Lipo? I don't mind spending a few bucks more, for Quality stuff.
TIA
Blackanthem is offline Find More Posts by Blackanthem
Old Jul 17, 2012, 05:11 PM
sertav is offline
Find More Posts by sertav
Joined Apr 2012
You're getting a 300 X? Awesome and can't wait for your review! My 300 X is on hold now that I got a working 130 X.
sertav is offline Find More Posts by sertav
Reply With Quote  (Disabled)
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
