Old Feb 13, 2013, 10:54 PM
barnstorm100 is offline
Find More Posts by barnstorm100
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Originally Posted by Sailmac1 View Post
Is anyone using any other size battery than the 1350mah that comes with it? I have a 1000 and can get the 1300 nano tech from hobbyking for a lot less than the $30 price tag on the stock battery. I also have 2 1300 packs from horizon hobby, but they are only 15c and the one it comes with is 30c. Thanks for any info
I flew a 1000mah 30c yesterday and got 3.mins with plenty left over
barnstorm100 is offline Find More Posts by barnstorm100
Old Feb 14, 2013, 12:50 AM
Sailmac1 is offline
Find More Posts by Sailmac1
Mac
United States, DE, Seaford
Joined May 2012
Originally Posted by barnstorm100 View Post
The 300x on Phoenix is more difficult than the real one.
That's great to hear. I've gotten pretty good with the one on phoenix
So I can't wait! Should be here today
Sailmac1 is offline Find More Posts by Sailmac1
Old Feb 14, 2013, 12:51 PM
malcolxl is offline
Find More Posts by malcolxl
DX6i,DX7..low on model memory!
malcolxl's Avatar
SUFFOLK, ENGLAND
Thanks jasmine.
Colin.
malcolxl is offline Find More Posts by malcolxl
Old Feb 14, 2013, 01:07 PM
nforbesrc99 is offline
Find More Posts by nforbesrc99
Jet guy w/ no money to buy jet
nforbesrc99's Avatar
United States, GA
Joined Jul 2012
Can you guys explain the throttle tail, and pitch curves to me?
nforbesrc99 is offline Find More Posts by nforbesrc99
Old Feb 14, 2013, 01:18 PM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
http://www.helifreak.com/showthread.php?t=41692 has a world of info on setting up helis, go to pitch and throttle curves 101. And look at all the other videos!
KeithK is offline Find More Posts by KeithK
Old Feb 14, 2013, 06:55 PM
Hexperience is offline
Find More Posts by Hexperience
devIAtion..one TX to bind them
Hexperience's Avatar
Canada, ON, Georgina
Joined Aug 2011
Well, I've now tried the ar7200bx with a known good 5v 3amp bec and it's still dropping throttle and sometimes it seems like I also loose roll control for a moment.
I don't know if I want to switch the BEC to 6v and take a chance on those eflite servos.
I have a ticket open with HH, I just hope I will only have to ship back the ar7200bx, otherwise the shipping cost is going to be pretty high.
Hexperience is offline Find More Posts by Hexperience
Old Feb 15, 2013, 08:57 PM
HeliStyle is offline
Find More Posts by HeliStyle
hmmm...
Joined Sep 2008
could someone explain the brownout problem known with the ar7200bx and how it can be fixed?
Is it a simple fix of needing a better bec ?
HeliStyle is offline Find More Posts by HeliStyle
Old Feb 15, 2013, 09:08 PM
Joined Jan 2011
I flew 7 packs today @4mins each. So that's about 25 flights now and no problem. Not very hard on it though.
Hey, how do these Android frame braces attach to the frame? Does anybody else even use them
Thanks.
Old Feb 15, 2013, 09:16 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
All digital receivers have a minimum operating voltage. If the input power drops below that voltage, the receiver must re-boot. Spektrum receivers re-boot fairly quickly, but first you have to wait for the power to come back up, and then if the receiver was off for too long, it has to re-acquire the transmitter signal - this can take significant time. Most of the time with a helicopter you have crashed long before any of that happens and when you walk up to your bird everything will be "working fine"
The supposed "Spektrum brown-out" problem is not unique to Spektrum, but their receivers are a little more sensitive to brief voltage dips, and they have done nothing over the years to fix the problem. YOU can fix the problem though, and I maintain that the "problem" isn't really with the receiver itself, although there are improvements they could make so it would be less sensitive. The preferred way of avoiding the issue is to use a good BEC, but there are also other methods such as a capacitor across the power pins (I forget what size, sorry).
Since the AR7200BX is a digital receiver, it is vulnerable to this problem. Note - I have also experienced this problem (power reset lockout) with a 72MHz digital receiver as well, and it sometimes happens with other 2.4GHz brands. One guy at our club who uses Futaba had a brown-out and he was so upset he wanted his membership dues refunded - said there must be some kind of problem with our field. I spent an hour explaining that to him on the phone, he fixed the problem, he's had a great time at our club ever since.
My point is, you need to use a good BEC, whether it's built in to the ESC or otherwise, and it doesn't matter if you're using Spektrum or any other brand of receiver, if it's digital, you can have power reset lockouts. The knock-off Spek stuff is equally as sensitive as the genuine article.
jasmine2501 is offline Find More Posts by jasmine2501
Old Feb 15, 2013, 11:11 PM
Joined Aug 2011
I was running a bec off a seporate battery and it still cut out theottle on me and also loses cyclic control intermittantly. for now my 300x is running a walkera 2702 if horizion replace or repair it i will put it in one of my other helis.
Old Feb 15, 2013, 11:39 PM
Rocket Programmer
Joined Jul 2007
Well, any mass produced product can be defective, so maybe you got a bad one, but maybe you have a sketchy BEC too?
Old Feb 16, 2013, 10:57 AM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Thanks.
I am thinking you have to glue them on.
indoorheli is offline Find More Posts by indoorheli
Old Feb 16, 2013, 02:52 PM
johnnyrocco123 is online now
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
So Horizon says that I am the first call of a broken main shaft with the carbon blades. Anyone else?
They replaced my shaft. I am upgrading to Align Digital servos so I am eager to see how that goes.
johnnyrocco123 is online now Find More Posts by johnnyrocco123
Old Feb 16, 2013, 03:01 PM
Sailmac1 is offline
Mac
Joined May 2012
Anybody using a JR X9303 with this? I am not sure what settings to use to set up gyro gain. From what I've read it's assigned to channel 5 but I can't seem to figure it out. Thanks for any help
Old Feb 16, 2013, 08:32 PM
Joined Jan 2011
I was trying to test hover my new 600 in the backyard and this is what happened.
aller anfang ist schwer! (9 min 50 sec)
But really, after flying 4 batts in the 300x with no cooling in between flights, the motor stopped for about 1/4 of a second. Lucky I was high enough for it to recover. Guess it time to install the 30a esc I got from hobbypartz
For Sale Trex 700E FBL BeastX BNF 1600$ Shipped trevjonez Aircraft - Electric - Helis (FS/W) 1 Aug 15, 2011 08:04 PM
For Sale Outrage 550 FBL W/BeastX BNF KenM Aircraft - Electric - Helis (FS/W) 2 Jul 09, 2011 07:20 AM
Found BeastX FBL controller Hellsiege Aircraft - Electric - Helis (FS/W) 0 Jan 28, 2011 02:24 PM
Sold BeastX, Spektrum Satellite, BeastX Satellite Adapter, 450 Sport FBL Head NovaCX12 Aircraft - Electric - Helis (FS/W) 1 Jan 22, 2011 08:07 AM
Sold Microbeast BeastX FBL unit NEW never used Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Dec 07, 2010 05:23 PM
