Old Feb 01, 2012, 10:51 AM
ask21! is offline
Find More Posts by ask21!
Be here now!
ask21!'s Avatar
Rome,Ciampino
Help!
TWM 1/4 Super Cub
Good morning from Italy!
While waiting for better days to continue the building of my autogyro,
I bought the plane i was dreaming of from a while, it's a super cub 1/4 from The Wings Maker wich is a brand of The World Models.
The plane is almost to land at my home (I had to buy it in UK, I live in Italy) and in the while I feel seriously in trouble trying to choose the right engine.
First engine was the asp160ft, but it is too much expensive.
Second one would be a gas engine, but what is the right cc? I was thinking of a 26cc. Someone told me a 30cc would be better. I never had a gas engine, so I don't know...can you suggest one please?
And about servos(hitec or futaba...)? Never had a so large plane...
Thanks for the help i will receive.
Stefano
PS I will post some photoes when it'll arrive.
I Forgot to say that i will try to reproduce a bush plane, i think we should keep this in mind to chose the right engine.
ask21! is offline Find More Posts by ask21!
Old Feb 02, 2012, 08:09 PM
fastflyer300 is offline
Find More Posts by fastflyer300
fastflyer300's Avatar
United States, CA, Oceanside
Joined Jan 2012
High thrust would be a good thing to look at, I would get a 30cc. Great acceleration rate and easyer tuning with a gasser! Zenoah engins are great from what I have experianced
fastflyer300 is offline Find More Posts by fastflyer300
Old Feb 03, 2012, 12:49 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
DLE 30 springs to mind
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Feb 03, 2012, 02:38 AM
ask21! is offline
Be here now!
ask21!'s Avatar
Rome,Ciampino
So you would go for a 30cc and have a power ratio higer than 1:1...
I thought i was the only who wanted to do this
Probably I will take a mintor 33cc as it is a real piece of art, at the same price of a dle30, italian product, and maybe a bit lighter than the other.
About servos instead, I decided for standard bearing servo for aileron and flaps and high torque for rudder and elevator.
Battery will be 2cell life. Even for the ignition (i will use a regulator).
Old Feb 03, 2012, 08:22 AM
ask21! is offline
Be here now!
ask21!'s Avatar
Rome,Ciampino
Finally at home!
The snow storm couldn't stop her!
Bush plane are the best!
Sorry if I cutted my head off
Those wheel are big, but I need BIGGER ones!
Old Feb 03, 2012, 10:18 PM
jjkupinski is offline
Find More Posts by jjkupinski
TigreJohn
United States, CA, Corona
Joined Aug 2008
First for Bush tires, look at DuBro inflatables. they are made up to 6" (152cm) dia. and look like the ones in your bush plane picture.
As to servos, look at Hitec's 485HB (or similar). Ball bearing, stronger than standard gears, more torque than recommended for the plane, and reasonably priced.
Engines: The minimum recommendation for the plane is a nitro .90 2 stroke or a 120 4 stroke. You are going to pay a premium for a multi cylinder engine. For a 4 stroke, consider the ASP 1.20 or 1.80. Or for a 2 stroke, consider the ASP 1.20 or a Super Tigre G2300 if you think a 90 is not enough.
For the possible expense involved, I would not consider a petrol engine as first choice for this airframe unless you first have a bit of experience with them.
jjkupinski is offline Find More Posts by jjkupinski
Old Feb 04, 2012, 03:52 AM
ask21! is offline
Be here now!
ask21!'s Avatar
Rome,Ciampino
Dear jj,
I was thinking about putting a dle20 into this plane.
It's rated for almost 13lb of thrust (or trust!? sorry)
Why don't you recomand it to me?! At my field there are a lot of people flying gas engine. They could help me in case I need.
About glow, I know best choise would be in the middle betwin 120 and 180 (single cylinder). But I will never pay so much to buy an OS or a Saito.
I agree with you about servos choise!
Thank you a lot!
Stefano
Old Feb 04, 2012, 02:52 PM
Mrj3cub is offline
Find More Posts by Mrj3cub
Mrj3cub's Avatar
Joined Nov 2011
More pictures of this cub
Mrj3cub is offline Find More Posts by Mrj3cub
Old Feb 04, 2012, 03:19 PM
ask21! is offline
Be here now!
ask21!'s Avatar
Rome,Ciampino
I will post soon,
It has snow a lot here and there are other prioritys now...like playing at snow-balls Last time with snow in Rome was 27 years ago!
As the situation will become normal, i will post a lot of pics!
Old Feb 06, 2012, 07:43 PM
scaleman57 is offline
Find More Posts by scaleman57
United States, NJ, Upper Pittsgrove
Joined Mar 2011
Iv been flying this plane for a year do not over power I put a DLE 20 in mine its perfect its off the ground in 30 feet climbs like a rocket, then I fly it at less than half throttle . This bird will fly for an hour with 14 ouncefuel tank I wouldgo that route.I did not have to add weight to the nose it balanced right on.
scaleman57 is offline Find More Posts by scaleman57
Old Feb 06, 2012, 08:01 PM
Captainhook1 is offline
Find More Posts by Captainhook1
Captainhook1's Avatar
Swartz Creek, MI
Joined Aug 2008
Couldn't agree more. I Think a 30cc would be way too much power. Cub looks good. Looking forward to more pics.
Captainhook1 is offline Find More Posts by Captainhook1
Old Feb 06, 2012, 11:34 PM
ska2000 is offline
Find More Posts by ska2000
Mount Juliet, TN
Joined Feb 2008
Another idea... Gas engines vibrate a lot. I prefer metal geard servos on gasoline engined aiplanes.
ska2000 is offline Find More Posts by ska2000
Old Feb 07, 2012, 04:17 AM
ask21! is offline
Be here now!
ask21!'s Avatar
Rome,Ciampino
I will go for DLE20 (Yes, i also think 30cc will be too much power for this cub) an Hs485hb.
Do you guys think i should look for some metal geared servos?
What is similar to hs485 but metal geared? Got an HS 625mg for the rudder...i think it's too much for ailerons and flaps.
I'm going to post some photos in te noon may be
Old Feb 07, 2012, 04:48 AM
Joined Jul 2004
It really comes down to what you want to do with the model, for nearly the same money you can have 33% more power for say something like glider towing...... if you wish but you also have this thing called a throttle and as to the weight, your going to need it to balance your cub! As to servos, this is not a very big plane any good 3.5kg servo will be fine.
Old Feb 07, 2012, 05:00 AM
Mrj3cub is offline
Mrj3cub's Avatar
Joined Nov 2011
Go for the Asp 120 four stroke. With a 16x6 prop it will give you nice thrust and it will flie verry scalelike. The Sounds is just awesome.
I have this engine in my clipped cub 1/4 and it is a true winner! Cheap also! Order it from China, and you will be a happy man!
Wanted Hanger 9 1/4 scale super cub chicks45840 Aircraft - Fuel - Airplanes (FS/W) 1 Sep 28, 2011 05:39 PM
Wanted 1/4 scale Cub or Super Cub wings sewoodruff Aircraft - Fuel - Airplanes (FS/W) 1 Jun 19, 2011 04:16 PM
Found 1/3 or 1/4 scale cub,super cub ,etc zeus3313 Aircraft - Fuel - Airplanes (FS/W) 1 Apr 04, 2011 08:03 PM
For Sale (2) FM Super Cub Radios, (4) Parkzone Super Cub Servos and (1) Reciever/ESC iflyer Aircraft - General - Radio Equipment (FS/W) 3 Sep 21, 2009 09:24 AM
Wanted Looking for 1/4 or 1/3 Scale Cub, Champ or Super Cub yaha-tinda Aircraft - Fuel - Airplanes (FS/W) 2 Jul 09, 2006 11:52 PM
