Externally the DX7s/DX8 switches were named according to default function, but internally they are A, B, C, etc. They are just as assignable, although the current DX7s/DX8 menus do provide some limitation on assignments that are appropriate for a step-up radio (for users moving up from DX6i). Quote:
They also both include Channel Input screens to allow assignment of any input (switch or analog) to any aux channel. The guys internally who use it on their JR planes have used the mapping function to get things the same way they had them in their old radios. Quote:
But it would still be missing stuff, as the DX18 is much more than just a DX10t in new clothes.The DX18 does provide combo switch inputs for mixes, allowing AND/OR activation of mixes from multiple sources (including the position of sliders and sticks). The flight mode (a logical switch of up to 10 positions) can be used to activate anything where you would put a physical switch or analog input acting as a switch. That means you can have a mix that is activated in any combination of flight modes you desire. Or you can activate it by a combination of a flight mode and a stick position, or a switch and a slider, or two switches, or a slider and a stick, etc. Quote:
Andy |
Futaba 's "AFR" function stands for: Adjustable Function Rate. Not to confuse with 'ATV' function!
Short explanation: http://www.rcuniverse.com/forum/m_87...tm.htm#8726799 |
Everybody has a method which works best for them-
The DX8 and as I understand it -the 18 has a more user friendly approach You select pairs first and then you can fiddle with them after they are paired Example: The "wing type " pairs (groups) surfaces -if desired - then you tweak as needed. OR do a mix if you want the pairs in different slots on the rx. |
variable mix
On my Futaba I can set up a mix, lets say elevator to flapperon so my flaps go down as my elevator moves up. I can then set one of the variable knobs to control the amount of mix. Then I go fly and play with the amount of mix while my plane is in the air and get the mix just right by turning the knob on the Tx. I can't do that on my DX8 - I have to set, say a 50% mix on the ground then fly and try it - then land to adjust the mix, then go fly . . . . . can't adjust the mix while the plane's in the air. Will I be able to do this with the DX18? If so I'm having one. |
USA, FL, Rockledge
Joined Jul 2005
Andy,
Thank you very much for your response (post 767) to my many questions and request to see the DX18 manual. I read every one of your answers for content, including the ones where you indicated that my statements were incorrect which, after more research, I fully agree with your position. I was wrong. For me, your posts on this forum are the most valued information available for the DX18 and I really appreciate you taking the time and having the patience to deal with us grown up kids. Thanks. I will read, once again, the DX10 manual but, what I am waiting on is the dX18 manual. The Futaba AFR (Adjustable Function Rate) screen is where you can add DR, or Exponential, or simply adjust the function curve (linear, point to point, smoothed, 17 point throttle curve, etc) to fit your needs for every flight control function without using any mixes. It can be turned on or off via switches, sticks, flight modes, boolean logic and so forth. ![]() Howard |
Dallas, TX
Joined Jan 2010
The answer was 'No' for the DX18 http://www.rcgroups.com/forums/showp...ostcount=15080 |
Latest blog entry: Get Help by posting your SPM File
You are apparantly flying gliders? |
| Thread Tools | |
| Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users | aeajr | Sailplane Talk | 25 | May 29, 2012 03:14 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Dec 20, 2011 05:12 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 4 | Dec 14, 2011 07:30 PM |
| For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 | zaptherio | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 15, 2011 05:14 PM |
| Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Oct 19, 2011 04:59 AM |
