Old Jan 04, 2013, 05:32 PM
ghoffman is offline
Find More Posts by ghoffman
USA, NH, Bedford
Joined Oct 2009
Originally Posted by freechip View Post
You take the models you are going to be flying first or sooner and transfer them manualy, then later when you have time you transfer the others.
Programming your new radio will have a positive affect, you will learn more about it.
Yea I know, I am glad I don't have an Ultra Stick 120 anymore. It was a tough 9303 program with flaps, crow, half and full ailerons, flap to elevator mix, rudder to elevator mix, whew! The Horizon guys were great and basically talked me through it, awesome service!
ghoffman is offline Find More Posts by ghoffman
Old Jan 04, 2013, 07:49 PM
GBRellic is offline
Find More Posts by GBRellic
GBRellic's Avatar
Canada, BC, Vernon
Joined Mar 2009
GBRellic is offline Find More Posts by GBRellic
Old Jan 04, 2013, 09:16 PM
kevinrc is offline
Find More Posts by kevinrc
Happy Habu Hustler
Joined May 2012
What a lot of twaddle!
Programming the first model or two I learned about the radio, the other two dozen were pure drudgery.
I'd have been delighted to have a utility to take the things that stay the same and change them to the DX18 format. That would have allowed me to focus on the things that DO change.
kevinrc is offline Find More Posts by kevinrc
Old Jan 04, 2013, 09:27 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Create one model with the things that don't change and copy them to the next model and so on and so on.
Then edit each copied model for the things that are different. Kinda like creating a shortcut.
freechip is offline Find More Posts by freechip
Old Jan 04, 2013, 09:46 PM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Originally Posted by JohnathanSwift View Post
Please substitute "Fuh, Tah, Bah," for "badges:"
Don't be a hater Mr Swift, life is too short. Embrace the good in all.
Fig Jam is offline Find More Posts by Fig Jam
Old Jan 04, 2013, 10:45 PM
Hostage-46 is offline
Find More Posts by Hostage-46
Hit my smoke....
Hostage-46's Avatar
United States, TX, Highland Village
Joined Jan 2003
Back cover access
Uh is there a trick to opening this thing up? I pushed one of the tension adjustment covers though and into the case. I'd like to off the back but something is holding this thing together
Hostage-46 is offline Find More Posts by Hostage-46
Old Jan 04, 2013, 10:47 PM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Did you take off the rubber grips? I believe that is in the manual.
davidmc36 is offline Find More Posts by davidmc36
Old Jan 04, 2013, 10:53 PM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
I did I'll RTFM
Old Jan 04, 2013, 10:58 PM
PropsnWings is offline
Find More Posts by PropsnWings
Scale Aerobatic Pilot
PropsnWings's Avatar
Joined Jun 2011
Make sure you remove the SD card... it will hold the back on , if it is still inserted... something I feel the manual should have listed, but I figured out when I had the similar issue.
PropsnWings is offline Find More Posts by PropsnWings
Old Jan 04, 2013, 11:08 PM
Fig Jam is offline
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
And unplug the battery.
Old Jan 05, 2013, 12:45 AM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Yep that was it.
While I had it open I did my little "sailplane pilot mod" . Ever see guys with a rubber band looped over the flap lever to hold it forward? I put mine internal which holds the throttle lever forward. Really helps for precise flap control in the landing pattern. These little rubber bands fit nicely, provide a nice consistent pull and last for years.
Old Jan 05, 2013, 12:48 AM
Joined Jun 2011
Yep that was it.
awesome !
Old Jan 05, 2013, 01:27 AM
Hit my smoke....
Hostage-46's Avatar
Joined Jan 2003
Ok guys, I'm going in...
Using Sherman's guide and template I've changed mode switches a bit. Not using a landing mode. I'm looking at setup for trim of flaps and aileron. Mix 4 R trim to trim ailerons. When I select the box via the roller, I cannot change from Inhibit to Active.
Any ideas?
Old Jan 05, 2013, 08:37 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Got a picture?
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jan 05, 2013, 08:51 AM
sirzeppu is offline
Find More Posts by sirzeppu
sirzeppu's Avatar
United States, TX, Kilgore
Joined Aug 2011
Just did that same setup on a scratch built stik...only took about 2 hours on the 18. This thing is amazingly easy to program. I added 3 different 3D modes as well as a panic switch to shut it all off...LOVE this radio!
sirzeppu is offline Find More Posts by sirzeppu
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
