Old Jan 02, 2013, 09:09 PM
mejmea is offline
Find More Posts by mejmea
Always trying to learn
mejmea's Avatar
United States, IL, Batavia
Joined Feb 2011
Originally Posted by jsallade View Post
Snip
I may just start starting/stopping my Telemetry this way in any case.
@Andy
This raises another related question if I may:
If one turns on the radio and/or changes to a new model with the throttle hold engaged (switch H forward) you get "yelled at" by the radio and it won't boot until you turn it off/flip it to the back. If one is using this switch to trigger the telemetry and/or timer, at what point after that will the radio recognize that the switch is off and thus start the timer/telemety? In other words, how long do I have to flip it forward again? Is it ok to do this at any point during the remaining "boot" sequence?
In playing around with this for the timer, it appears that if you don't flip it forward again the timer starts counting within a second or two after the boot is completed and that as long as you remember to flip it forward before that point things are fine. Obviously losing a second or two off of the timer if you are slow to flip it isn't a big deal. On the other hand, if the point with using that switch for the telemetry is to minimize the file fragments created by a switching method such as throttle stick position then I'd rather not create even one spurious fragment. Do the timer logic and telemetry logic start "thinking" at the same time?
I hope this question makes sense...
Edit: I should clarify that the radio only "yells" about the position of the throttle hold switch when using a heli model type (which maybe you could explain to me also, see my post just below freechips).
mejmea is offline Find More Posts by mejmea
Old Jan 02, 2013, 09:13 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Don't have the radio with me right now but why not change the warning switch position.
freechip is offline Find More Posts by freechip
Old Jan 02, 2013, 10:01 PM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
freechip,
Not sure if that was in response to my question or not but if so I do not understand what you are saying. Is there a way to change whether or not the radio is happy or unhappy about switch positions during boot up? It is unhappy if the throttle hold is on or if the flight mode switch is not in the rearmost position. I should clarify, however, that these are true only for a heli model type, not for acro. (Which, now that I think about it, and it is consistent with my Dx6i, I don't understand why the radio would be unhappy about having throttle hold on even for a heli? Not wanting to be in "idle up" I get, but not wanting throttle hold on?)
Old Jan 02, 2013, 10:14 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
@ mejmea - Yes it was a response to you and for you.
Access the System Setup List, scroll down to Warnings. Select and change the Hold: alarm position from 1 to 0 or off completely.
Selecting 0 will cause the radio to alarm you if you DON'T have your Hold switch triggered.
Enjoy and Happy New Year.
Old Jan 03, 2013, 06:03 AM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
Arrgghh, how did I not know that? Too many things to learn/remember, not enough storage space. As written on a T-shirt my father once owned, "In my next life I'm going to have more memory installed."
Thanks, and Happy New Year to you!
@Andy, I still am curious why the default for a heli is to alarm when the throttle hold is on? I'm sure there is a good/historical reason but don't understand what it is. Also, as a suggestion, perhaps adding an alarm option for throttle hold for acro (and even sailplane) could go on the list given the prevalence of electric models. I know there is already one for throttle position and airplanes don't use "idle up" like helis, but it would still be nice to have the option and because throttle sticks can get bumped accidentally. Thanks
Old Jan 03, 2013, 06:04 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by mejmea View Post
The short answer is "no".
The program referenced by David allows viewing but I'm not sure that you can actually create, edit, and transfer. I believe the author of the program was recently (November-ish) trying to find someone else to take over future development because he was too busy to continue.
https://sites.google.com/site/txprofilemanager/
I was just playing around and did some editing on the computer with the Tx Profile Manager.
Took a look at the .spm file in wordpad after and it saved the editing.
Problem was when I went to load it back into the radio it gave a Telemetry Section error and would not load in. Line 17xx something.
I suppose you could do some copying and pasting to fix that error but kinda defeats the purpose though eh?
Wish I was a programmer. It looks like a nice start to the program but certainly not functional in its current state.
davidmc36 is offline Find More Posts by davidmc36
Old Jan 03, 2013, 10:18 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
This was debated 2+ years ago too, I'm sure you can find info probably in the DX8 thread.
I'm not a heli guy. The folks who are, who specified the defaults, had their reasons that I'm sure are valid. I defer to their expertise.
I guess in one way you could say it worked -- it forced you to investigate your radio a little
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jan 03, 2013, 10:31 AM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
Andy
LOL, very true. Even after owning it for several months I have yet to find the time to just sit and go through everything menu by menu (and even if I do find the time I won't retain it until I actually use it, I'm just not a good memorizer). Thank the Lord for forums, helpful, patient people, and JITL (Just In Time Learning)
Old Jan 03, 2013, 10:49 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If I remember correctly it had to do with making sure you toggle it to hold after the radio was powered on and not taking for granted it's already on or something like that. Don't quote me on that one.
Old Jan 03, 2013, 10:55 AM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
That make sense and certainly that's how my radios have been trying to train me to this point (Pavlov's dog, right?). Even if I leave it at the default I realized that I get around the "problem" that I was concerned about (the timer or telemetry starting because I forgot to flip the switch to hold) because I use the preflight checklist. Nothing starts until you are done with that and I also have "Throttle hold on" in each of my checklists.
Thanks for the insight though, I'll search, I'm just curious about the history now.
Old Jan 03, 2013, 12:47 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
jrb is offline Find More Posts by jrb
Old Jan 03, 2013, 12:49 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Doesn't seem to run on my XP based notebook?
Old Jan 03, 2013, 12:51 PM
mejmea is offline
mejmea's Avatar
Joined Feb 2011
Thanks; doesn't seem to run on my XP based notebook?
Hmmmm, I've only ever tried it on my Windows 7 laptop so I don't know, although it would surprise me if it doesn't work on XP. I have an XP machine at home I can try it on tonight.
Old Jan 03, 2013, 12:55 PM
PropsnWings is offline
Find More Posts by PropsnWings
Scale Aerobatic Pilot
PropsnWings's Avatar
Joined Jun 2011
time to upgrade
PropsnWings is offline Find More Posts by PropsnWings
Old Jan 03, 2013, 03:32 PM
delateurj is offline
Find More Posts by delateurj
United States, CA, Sunnyvale
Joined Oct 2001
If I use a dx18 with a JR 921 receiver will I be able to get 2048 resolution on elev, rudder, aileron?
Did some searching and just couldn't figure out if statements like "2048 resolution with 12 channel receivers" meant you wouldn't get it with 9 channel receivers on at least some of the channels.
Joe.
delateurj is offline Find More Posts by delateurj
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
