Old Jan 01, 2013, 05:19 AM
mejmea is online now
Find More Posts by mejmea
Always trying to learn
mejmea's Avatar
United States, IL, Batavia
Joined Feb 2011
Originally Posted by ghoffman View Post
Is there a way I can look at for example, a temperature probe after I land and see the temperature versus time for the flight (histogram)?
Not on the radio itself. You can with the STi device/app.
mejmea is online now Find More Posts by mejmea
Old Jan 01, 2013, 07:10 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
The STi app has replay, you would be able to view the entire flight. If you are monitoring temps then you could see where and when temps rise and or lower.
With every update the STi app gets better and better.
freechip is offline Find More Posts by freechip
Old Jan 01, 2013, 07:29 AM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Or u can get the app from the log file format thread and use it to view graphs and stuff
davidmc36 is online now Find More Posts by davidmc36
Old Jan 01, 2013, 09:18 AM
ghoffman is offline
Find More Posts by ghoffman
USA, NH, Bedford
Joined Oct 2009
Nice! That is something I can really use.
ghoffman is offline Find More Posts by ghoffman
Old Jan 01, 2013, 09:30 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by davidmc36 View Post
So if I just put it to say OVER 1%, then it would only have one or two little files, which are the segment markers, and one actual telemetry file.?
Yes. 1% is probably a bit low, unless you use Throttle Cut as your switch (which is what I've started doing myself, since I use T.C. on all my planes).
We put everything into one file on the card because it's much faster to open an existing file than to create a new one.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jan 02, 2013, 05:23 AM
albireo is offline
Find More Posts by albireo
From Earth to the Moon!
albireo's Avatar
Sacramento, Ca.
Joined Jul 2003
D/R & Expo = LOST! Help!
I can't for the life of me figure out how to work the D/R switch like I did on my DX8. If I assign a switch I can see the usual 0,1,2 positions, but if I try assigning values it either doesn't make a difference what position the switch is in or just goes to inhibit. I've gotten it to show the values I want with the curves several times, but when I get out of the menus and back in position 0 is back to INH!
VERY frustrating, especially since the manual has one paragraph and doesn't even mention the curve black/white boxes.
Please help!
Joe
albireo is offline Find More Posts by albireo
Old Jan 02, 2013, 05:36 AM
rcpaintfx is online now
Find More Posts by rcpaintfx
Kev Waite
Plymouth UK
Joined Nov 2005
You have to make sure the box is black for position "0" then adjust that, then make postion "1" box black then adjust and so on with "2". Very odd way of doing things as in heli mode it works like on the DX8!!
rcpaintfx is online now Find More Posts by rcpaintfx
Old Jan 02, 2013, 01:06 PM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Hi Gents!
Thinking seriously about the 18 .
Probably missed it, hoping it can be done -- can you set up model configs on a PC and then transfer them to the DX18?
TIA,
Jim
jrb is offline Find More Posts by jrb
Old Jan 02, 2013, 01:16 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by jrb View Post
Hi Gents!
TIA,
Jim
Somebody was working on a third party program. Not sure how well it works. Look for Tx Profile Manager.
Some of have done some hand editiing.
But there is nothing "official" for PC
sirzeppu is online now
Find More Posts by sirzeppu
sirzeppu's Avatar
United States, TX, Kilgore
Joined Aug 2011
Hi Gents!
TIA,
Jim
I think a 3rd party or 2 might be working on one. It would be a sweet ability...however doing it on the tx is so fluid and easy I am not sure there would be much time saved or ease-of-use added. I just used all 16 mixes on a fairly complicated wing set up and the entire process only took 2 hours from clean bind to all features working. That's pretty amazing to me. I have heard stories of much simpler set ups taking longer on other brands.
sirzeppu is online now Find More Posts by sirzeppu
Old Jan 02, 2013, 01:18 PM
mejmea's Avatar
Joined Feb 2011
Hi Gents!
TIA,
Jim
The short answer is "no".
The program referenced by David allows viewing but I'm not sure that you can actually create, edit, and transfer. I believe the author of the program was recently (November-ish) trying to find someone else to take over future development because he was too busy to continue.
https://sites.google.com/site/txprofilemanager/
Old Jan 02, 2013, 03:48 PM
Bugbitten is online now
Find More Posts by Bugbitten
United States, KY, Madisonville
Joined Mar 2011
Anyone tested the AR9020 that comes with the DX18 to see if it works with one or no satellite? I have access to one without sats.
Bugbitten is online now Find More Posts by Bugbitten
Old Jan 02, 2013, 03:55 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
No, it needs both remote receivers.
Andy
Site Sponsor
Old Jan 02, 2013, 04:54 PM
Joined Mar 2011
deleted - found relevent posts.
Old Jan 02, 2013, 08:28 PM
jsallade is offline
Find More Posts by jsallade
Joined Sep 2007
Andy. It's not apparent to me how I would get an equal function to what I had with the DX-8 with the one time past a particular throttle setting turning on the log. I set it to 25% and that way it only turns on after motor start and stays on even if I go to 0/idle. As far as I know with this setting the log only ends when I turn off the airplane and radio. With the DX18, if I set it to 25% it shuts off every time I drop under that. Is there an option I am not understanding?
Also just want to say that I'm loving both the DX8 and the 18. Using the throttle cut switch is an excellent idea as well... I ALWAYS have a cut set up. Sometimes using the actual TCut function and sometimes using a throttle curve (all my electrics are done that way). Always on the same switch too so all planes use the same "safe" switch. I may just start starting/stopping my Telemetry this way in any case.
jsallade is offline Find More Posts by jsallade
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
