Old Oct 16, 2012, 05:34 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Do you have the latest Airware (1.03), which came out some days ago ? There were binding issues resolved. If you still have issues, move your TX 1-2m away during binding.
Mukenukem is offline Find More Posts by Mukenukem
Old Oct 16, 2012, 05:48 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Very simple:
When you release the button makes no difference. One the transmitter enters bind mode ("Binding") then the button is ignored. The manual is being updated and improved - that's why the difference.
Did you notice that your orange LED is off? That means that the RF deck is not transmitting. When you installed version 1.03 did you have any problems? What happens if you install it again? If re-installing 1.03 does not correct this, you will need to return your radio for service.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 18, 2012, 12:02 PM
wfield0455 is online now
Find More Posts by wfield0455
United States, MA, Holliston
Joined Aug 2008
Originally Posted by AndyKunz View Post
It's on the list, and I have worked on it. It is neither simple nor complete. And the fix will come out for all radios at the same time, since it's the same everywhere (now, since we changed the DX7s/DX8 to be more like the DX10t/DX18).
Andy
I haven't read this entire (very long) thread so if this has already been discussed then I apologize.
Does the DX18 support using raw stick input to a mix, similar to JR #ELE which bypasses dual rates, etc. I'm setting up a jet on a DX18 and for the brake control I want to use down elevator to apply brakes, only when the landing gear is extended. My brake controller is connected to X+1 on a 12 channel receiver.
I've tried the following:
Elevator -> X+1, controlled by gear switch (A). This works but is affected by dual rates / flight mode which isn't acceptable.
I have connected elevator to X+1 in channel assignment and set travel to 100% on the down elevator side and 0 on up elevator side. This give the correct control regardless of dual rates but can't be disabled when the landing gear is raised.
I also assigning elevator to X+8 in channel assignment and left X+1 inhibited. I then created a mix of x+8 -> x+1 and controlled it with the gear switch (A).. This works but I'm wondering if doing this has reduced the resolution of my brake control or added latency, etc. Not a big deal if it does as the brake control doesn't require a high degree of precision but curious just the same.
I'm still running V1.0 of the software and since I'm setting this jet up for a friend, who hasn't registered the radio yet I've been reluctant to update the software. Is this issue solved in any of the software upgrades? Is there a better way to get the function I need than what I have tried so far?
Wayne
wfield0455 is online now Find More Posts by wfield0455
Old Oct 18, 2012, 01:00 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes, start up updating the radio to the latest version! There are RF improvements which are essential, see the PDF for details.
You got most of what you need there. In Channel Assign screen, set the X-Plus Input to ELE for X+8. This will use the raw elevator stick in X+8. Set X+1's input to INH.
Now mix X+8 > X+1 at the appropriate rates. Set the switch to your gear switch (A).
Done.
Andy
Site Sponsor
Old Oct 18, 2012, 04:23 PM
Gambler71 is offline
Find More Posts by Gambler71
United Kingdom, England, Cheltenham
Joined Apr 2007
Database?
Andy, I've seen " the database" mentioned where you record requests for dx18 software changes, is that viewable online by customers? Also how do I send in requests?
Dave
Gambler71 is offline Find More Posts by Gambler71
Old Oct 18, 2012, 04:49 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
You can PM me, or put on a forum, or send me an e-mail. No, we don't need to help our competitors any, so it's not viewable. Only the dev team and marketing people see it.
Andy
Site Sponsor
Old Oct 18, 2012, 05:19 PM
Joined Aug 2008
Done.
Andy
I have that working but I consider it a bit of a "work around". Hoping that at some point there will be an option the mix menu to bypass dual rates for functions such as ELE -> BRAKE mixes. It is pretty common to want to bypass dual rates for a mixing input and most high end radios support this function. Hopefully the DX18 will directly support this as well in the future.
Wayne
Old Oct 19, 2012, 11:12 PM
rockarruda is offline
Find More Posts by rockarruda
Joined Mar 2012
Originally Posted by nemo_uk View Post
Can anyone help ?? Printed manual says for Binding Using the Receiver and Receiver Battery ...
5. Release the Bind button after the receiver has stopped flashing rapidly, once the receiver's LED stays illuminated; this indicates the receiver is bound to the transmitter. The screen also provides binding information.
Online manual says ...
5. Release the Bind button when the transmitter screen displays “Binding”. Binding is complete when the orange transmitter and receiver LEDs are on solid.
I have tried both with my DX18 (firmware 1.03) with AR6200, AR6255 and AR9020 all fail to bind but bind to my DX7 no problems. Have tried various distances no luck
Dull video showing DX18 fail and DX7 working
http://www.youtube.com/watch?v=--2aI7TpL60&hd=1
Yours is doing the same thing mine did after upgrading.. The orange light comes on, flashes quickly then goes out and no bind happens. It also doesn't control anything that was bound. Like Andy said the light not being on means it is not transmitting RF. I had to send mine in.
rockarruda is offline Find More Posts by rockarruda
Old Oct 20, 2012, 04:17 PM
Linou is offline
Find More Posts by Linou
Geneva
Joined Dec 2009
I have a small issue with the aileron stick: when i go right, I can use the 100% of the sick move (after travel adjust of the servo) and wen a go left, I reach the 100% of the servo move at already 80% of the stick move...
Does anyone experience the same issue and is there any solution for it ?
Al.
Linou is offline Find More Posts by Linou
Old Oct 20, 2012, 04:52 PM
freechip is online now
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
Export spm file directly here so we can have a look to see what's going on.
Are the sticks calibrated, what does the servo monitor show and what happens when using a blank model file??
freechip is online now Find More Posts by freechip
Old Oct 20, 2012, 05:30 PM
Snowflake6515 is online now
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
Unequal Left/Right Issue?
The SPM file will help, but a quick question: do you have sub-trim and/or trim set to other than zero?
Michael
Snowflake6515 is online now Find More Posts by Snowflake6515
Old Oct 20, 2012, 06:13 PM
gww528 is online now
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
Al.
This is a know bug. It happens when the Aileron is being used in Heli Mode and is Reversed.
At lease you found the work around for now.
gww528 is online now Find More Posts by gww528
Old Oct 20, 2012, 07:52 PM
Linou is offline
Geneva
Joined Dec 2009
Thanks for you very quick answers ! Really impressed
Sub trim: 0
Calibrate: done
Travel adjust: 80% both side
Monitor: End positions exactly at the same level
I can fly but I'll be happy when the bug will be fixed.
Regards,
Al.
Old Oct 22, 2012, 05:30 PM
AIRBUSA800 is offline
Find More Posts by AIRBUSA800
France, IdF, Paris
Joined May 2007
SPECTRUM AR6200 DSM2 good or not good for dx18
AIRBUSA800 is offline Find More Posts by AIRBUSA800
Old Oct 22, 2012, 06:03 PM
gww528's Avatar
Joined Mar 2008
Originally Posted by airbusa800 View Post
spectrum ar6200 dsm 2 good or not good for dx18
good
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 04:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 06:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 08:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 06:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 05:59 AM
