Espritmodel.com Heli Air
Old Oct 05, 2012, 04:18 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
1) I don't drink. Offering me booze goes against you :O
2) I don't make the decision as to what goes in or not.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Oct 05, 2012, 04:19 PM
Fly for fun
7oneWo1f's Avatar
Joined Nov 2011
I'd read the if/when as it will happen but they don't want to commit just in case the firmware guys discover something that prevents the feature from being implemented.
7oneWo1f is offline Find More Posts by 7oneWo1f
Latest blog entry: Powerpoles explained by Oz
Old Oct 05, 2012, 09:33 PM
You are a "go" for reentry
High Orbit.....
Joined Jun 2009
Originally Posted by AndyKunz View Post
I was suggesting an alternative for the interim until if/when it would operate like you want.
Sorry if you think it was blunt. It's on the list - that's all I can tell you.
Andy
No worries Andy. Feelin the love....
But honestly I was really trying to see if/how a third timer would be useful to the point of it being necessary.
Its being asked for but the only way I could think it would be useful is a prop powered glider. Without telem, they would want to time motor use via throttle, RX activity timed to safe limit, because they may be aloft with the motor off and the TX time.
But that's really already covered since the TX time isn't really necessary and that timer is what counts down the RX. So still kinda two timers.
As long as one of the timers have multiple assignable timed chimes or sound bits the user can create the appropriate prompts as they wish.
Well we'll keep looking for the updates.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Oct 08, 2012, 12:59 PM
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
OK, started moving my models from my DX6i and DX8 to my DX18. The helis went over without a problem, but I hit a snag with my first plane, a Crack Pitts. I'm using a CSRC-RX3000e DSM2 receiver. When I bind it to the DX18, all the control surfaces go to max deflection and for some reason, the ailerons are tied to the throttle as is the speed control. Very bizarre. I rebound it to my DX8, and everything is fine. I did the bind process several times with the same result. Is there something I'm doing wrong here or is this receiver not compatible with a DX18, which is odd given it works fine with the DX8? I'm still on version 1.0 on the DX18, if that helps explain things.
Jboy90277 is offline Find More Posts by Jboy90277
Old Oct 08, 2012, 01:05 PM
Kirkland Washington
Joined Feb 2002
Did you bind to a blank template? Did you possibly bind to a another model or Heli?
Sherman
duworm is offline Find More Posts by duworm
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
I had a HH orange 6ch rx that would do that with my DX8, I got rid of it and got a OEM rx.
freechip is offline Find More Posts by freechip
Old Oct 08, 2012, 01:11 PM
Joined Dec 2011
Sherman
I manually copied all the settings from my DX8 to my DX18 (from scratch), so there should be no mixes in play. When it started going funny, I put the settings to the defaults and still no luck.
My helis start at 30 and i was binding to the first slot. So, there is no chance of binding to the wrong model - this is the first plane.
Old Oct 08, 2012, 01:17 PM
Joined Dec 2011
I'll probably do that if nothing else works. It would be good to know what the difference is between the DX8 and DX18 with regard to DSM2 (if there is a difference).
Old Oct 08, 2012, 05:09 PM
Plymouth UK
Joined Nov 2005
New Airware version 1.03 now available
Kevin
rcpaintfx is offline Find More Posts by rcpaintfx
Old Oct 08, 2012, 05:14 PM
Joined Mar 2012
Yeah I just did it and now my radio says this:
System Fault:
Your system has a hardware fault which prevents safe operation!
Please return it for service.
T-Code: 00000000h
I-Code: 05200004h
Sequence 0
sequence 1 -> I-Code: 85200011h
I was just using it 2 min before I did the update. What checks does this firmware do while updating that it found fault with?
rockarruda is offline Find More Posts by rockarruda
Old Oct 08, 2012, 05:18 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Use a new SD card, re-download, and try again.
DON'T touch the switches or roller while this is going on!
Andy
Site Sponsor
Old Oct 08, 2012, 05:34 PM
Joined Mar 2012
Yeah i didn't
This radio is only a week old, and I do have the screen glitch. I figured it was possibly testing the screen display controller.
I used the same card to update it to 1.02 as the radio came with 1.00. I will try my other laptop and see how it goes. I believe I used the other when I downloaded 1.00.
Old Oct 08, 2012, 06:57 PM
Joined Mar 2012
Andy
I just tried a different laptop and SDcard.. same message as I posted above.
YAY!!
Old Oct 08, 2012, 07:01 PM
United States, ME, Wells
Joined May 2008
Update Problem
Don't forget to "eject" the SD card after the copy operation. That seems to have helped others who had a similar problem with earlier updates. I run Windoz7, so, theoretically, I do not have to do that, but I still do as a force of habit and after reading about others having incomplete file transfer (to SD card) causing similar problems as you describe.
Michael
YAY!!
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Oct 08, 2012, 07:10 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
YAY!!
Sounds like you'll need to send it in then.
Andy
Site Sponsor
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
