Joined Jun 2006
Thinking through the user/pilot experience I'd say utilizing a non-throttle initiated timer would be the best to way to accumulate airtime hours on an integrated timer. Basically I want to know my time from wheels up, to wheels down, similiar to a real airplane. I suppose in a (partially) perfect world the integrated timer would look at the elevation sensor of the airplane and kick the timer on and off. Not sure how that would handle hovering tail touches though
STi update now available with support for GPS and map layout.
Latest blog entry: Get Help by posting your SPM File
His time for FAA purposes is from the time he walks out to the plane until he shuts the master power off, plus some mandatory extra time per flight (pre- and post-). Andy |
Joined Jun 2006
So is that why the integrated model timer is counting anytime the model is selected? Suppose your commercial buddy walked to the plane, taxied, then relized he had an electrical issue with the jet. All the subsequent time it took to fix the issue would still be construed as airtime hours on the airframe utilizing the current dx18 setup. Not sure if 18 channels is enough for that big of a jet. I guess we need the commercial airliner update, lol.
High Orbit.....
Joined Jun 2009
Time time time.....
Its an on going conversation, time. But its not time that we are really watching, its what we are applying time to.
So not to close the conversation or prolong it, I'm curious if my perspective on watching time really needs much else. Since TX time is independent, you can fly many models vs the power source of each model, you need a timer for that. In the model its generally the lowest of all power draws. And it doesn't really need a carry forward because we usually try to avoid flying extra battery than we need. But some do have larger batteries so may be this is the only area of various setups that may need an extra timer with a carry over. Thats two, may be three times so far. Since the measure of time is really only tied to the battery source of one thing or another, the trigger would be tied to what ever the minimum is. e.g. FPV the moment I turn it on, I want to be timing it as a failsafe to the Telemetry. That basically tracks with the TX timer count down because the TX turns on first. Already there. The rest is throttle driven since its the quickest depleted source unless your a glider which is why as far as I understand they use a start switch. When I throttle up I'm using up minimum fuel timing. We've always been told to have our RX power source greater than fuel source obviously so thats tied to the throttle drive time. Its true though that we may use RX batts in multiple flights or may be flying a glider so a choice of what triggers the start becomes the factor which is also provided. None the less we don't track RX source with a carry forward timer because we watch the TX carry forward timer for that. Its my guess that that is the reason why radio makers arrive at just two timers in general. A third timer kind of becomes necessary if using a throttle triggered time if the aircraft can shut down the fuel burn and then may have a varied longer run time than the RX. So I would feel safer to allow as always the TX timer, that just goes on connection, a Throttle timer for fuel burn and timer for min RX or other levels. Not mocking anyone else's choice of timer but I am curious what else is really being timed that we are not already doing in some manor already. OK may be I'm prolonging the conversation and selfishly am seeing if theres a reason why I need more but sincerely.... is there something else that I should be timing that I haven't been paying attention to? Even if its a form of the hobby that I haven't tried yet. Did I miss anything? Not looking for an arguement.... just looking to refine what I should think I should need, not just want. |
Joined Jun 2006
I agree. Why use a timer at all? For the safety of the aircraft and fellow pilots? Yes. How about applying time to education? I like to know it took me 21 hours until I learned a new-fangled XYZ maneuver on the airframe (don't laugh, maybe Im a little slow
. Perhaps it's a good indication of flight tendency on a new airframe if I get that time down to 14 hours or so. For my selfish purposes I'm only concerned with timing for the following. 1. Current Flight (currently available on dx18) 2. Time of "ON" throttle for flight (currently available on dx18) 3. Entire TX lifetime clock (currently available on dx18) 4. Cummulative flight time for selected model, not entire time model is selected (NOT available on dx18) I'm sure I missed something, being slow and all.
High Orbit.....
Joined Jun 2009
I didn't post that to find whats good for your uses, but more so for all. Is there some area in the hobby that needs a 3rd timer if they opt out of using telemetry?
Two timers cover pretty much everything. I haven't figured how more would be useful. In fact carry over log timers for say an RX could be misleading since you already have figured even before you fly how many flights a RX batt will last. So no need for logging it. That's what I've been working with but the repeating conversation has me wondering if I'm just missing something. Based on your blunt comment Andy its obvious, in your opinion there really isn't another valid reason for extra timers regardless on which end of the hobby your in. K. So I'm not missing out on anything as far as I can tell. |
| Thread Tools | |
| Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users | aeajr | Sailplane Talk | 25 | May 29, 2012 03:14 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Dec 20, 2011 05:12 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 4 | Dec 14, 2011 07:30 PM |
| For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 | zaptherio | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 15, 2011 05:14 PM |
| Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Oct 19, 2011 04:59 AM |
