Old Sep 16, 2012, 03:53 AM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by AndyKunz View Post
The bump is caused by the kick point not exactly the same as the offset. Tweak the offset a little to get rid of the bump.
Andy
Got it to work by playing around with rate and offset. The initial mix is switched by flight mode to give me the up elevator added in as throttle goes below 50%. The other mix is combo switch and counteracts the first one below 20% throttle only when in correct F-Mode.
davidmc36 is online now Find More Posts by davidmc36
Old Sep 16, 2012, 04:08 AM
simo71 is offline
Find More Posts by simo71
The land down under
simo71's Avatar
Australia, NSW
Joined Jul 2010
Needs dual timers on the main screen.
Needs larger native font within all menus & setting's
simo71 is offline Find More Posts by simo71
Old Sep 16, 2012, 06:58 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Dual timers on main screen?
If your are asking for this feature for the DX18, then all you need to do is enable Timer2 because it already has dual timers that can be displayed on the main screen.
freechip is offline Find More Posts by freechip
Old Sep 16, 2012, 01:42 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
You have one? -or just browsing
richard hanson is offline Find More Posts by richard hanson
Old Sep 16, 2012, 02:43 PM
bcovish is offline
Find More Posts by bcovish
bcovish's Avatar
Austin TX
Joined Jun 2008
What use is dual timers on main screen
bcovish is offline Find More Posts by bcovish
Old Sep 16, 2012, 02:56 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
On my DX18 and on ALL of my models I have Dual Timers enabled.
Models with telemetry, my Timers count up and Models without telemetry timers count down. Personal prefference.
Timer #1 is set to Start/Stop with throttle regardless if counting up or down
Timer #2 is set to Start One Time with Throttle regardless if counting up or down.
What this does FOR ME is have a Total Flight Timer and Motor Runtime Timer.
For example :
Timer#1 - 4:55
Timer#2 - 7:34
This tells me I had the motor on for 4:55 minutes but the total flight time was 7:34
meaning I had a little over two 1/2 minutes of gliding around sort of speak.
Old Sep 16, 2012, 03:51 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Oh man and no one could have told me this earlier...I just barely ordered one Next I am going to read the trims are hardly visible and that this is way to much radio for use with my bnf models Though it might look a little silly when i pull it out with the ncpx i just ordered too
indoorheli is offline Find More Posts by indoorheli
Old Sep 16, 2012, 04:34 PM
simo71 is offline
The land down under
simo71's Avatar
Australia, NSW
Joined Jul 2010
Oh really....cool I had a flick thought the manual & could not see it, my initial thought was how could a radio in this price point only have one timer.
Browsing at this stage.
Old Sep 16, 2012, 10:17 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
For example :
Timer#1 - 4:55
Timer#2 - 7:34
Great idea. Thanks for the tip. (This is why I like RCG!)
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Sep 16, 2012, 11:09 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
I like the font the size it is....some of the screens have a lot of words and present a lot of information. A larger font would crowd things up.
I like freechips dual timer idea and will start using that technique myself. I normally only use a singe countdown timer that activates when the throttle is at 25%, but would like to compare motor run time and total flight time once in a while.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Sep 17, 2012, 03:44 AM
simo71 is offline
The land down under
simo71's Avatar
Australia, NSW
Joined Jul 2010
I fly heli's.....I have a timer for normal flight mode & a second timer for when I go into one of my flight modes.
I have gone through the manual (page 26) & it says nothing about a second timer.
Can I have a pic of the dual timer on your main screen from those who use it?
Thomas B yes it does appear to be the case, normal screens are pretty clear perhaps they can remove the graph from the servo menu for travel adjust etc & have that in the servo monitor screen?
Old Sep 17, 2012, 05:48 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by Thomas B View Post
... I like freechips dual timer idea and will start using that technique myself. I normally only use a singe countdown timer that activates when the throttle is at 25%, but would like to compare motor run time and total flight time once in a while.
I started using 2 timers for my Radian Pro. I could time my entire flight BUT also time how long the motor was ON. From there I use it pretty much on all my models. WHY NOT its there to be used right?
Old Sep 17, 2012, 05:53 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
@ simo71 - Yes the manual is not 100% clear but what the manual does show is a picture of the display. The timer display itself is titled TIMERS (S) and then TIMER 1 (1) is identified. These would indicate more then one timer and the fact that you can scroll to TIMER 1 sort of indicates it can be changed.
I will post of pic of my DUAL Timers as soon as I can .
Courtesy of http://www.horizonhobby.com/products...ode-2-SPM18000
Originally Posted by HH website
• Four timers - a system timer for the overall on air time of the radio, a model memory timer for the flight time of a specific model,
and two count down/stopwatch timers that can be activated any number of ways.
Old Sep 17, 2012, 08:36 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Speaking of model membory timer, how do you reset it?
Old Sep 17, 2012, 08:43 AM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
I just had an idea, since we know the throttle position and how long the motor is on in that position, maybe we can calculate a crude approximation of mAh used. If we input the amp draw for 25%, 50%, 75%, and 100% throttle, the radio software should be able to interpolate and calculate the mAh used... Kind of a virtual current sensor.
jhroof is offline Find More Posts by jhroof
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
