Old Sep 14, 2012, 07:56 AM
tourist_603 is online now
Find More Posts by tourist_603
Joined Dec 2007
Moving flaps to left slider
I currently have three position flaps on switch D. I'd like to move the flaps to the left slider so that they are infinitely adjustable. I am guessing that the answer lies in system set up somewhere, but I need some help on the details.
tourist_603 is online now Find More Posts by tourist_603
Old Sep 14, 2012, 10:41 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Well, there are a couple options.
If you leave your wing type as it is (no flaps) then you can go to the Channel Assignment screen, select NEXT, and change AUX1: D to AUX1: LLv (left lever) or whatever else you want.
If you want to have more options, change your wing type to include flaps. This will provide a Flap System screen where you can assign the switch, the speed delays, the positions it goes to, as well as elevator compensation.
The choice is yours!
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Sep 14, 2012, 04:36 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
I am about to order one of these but havent been paying close attention. IS there any know issues with old vs new stock llike the dx8's
indoorheli is offline Find More Posts by indoorheli
Old Sep 14, 2012, 04:38 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
There hasn't been any hardware issues with this radio.
At least that have been reported here.
freechip is offline Find More Posts by freechip
Old Sep 14, 2012, 04:41 PM
indoorheli's Avatar
Joined Sep 2007
thanks that is what i was looking to hear
Old Sep 14, 2012, 05:05 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
I put a poll up about Radio brands and RF systems for sailplanes.
http://www.rcgroups.com/forums/showthread.php?t=1732320
Any of you guys using the DX18 for sailplanes?
aeajr is offline Find More Posts by aeajr
Old Sep 14, 2012, 08:22 PM
bcovish is offline
Find More Posts by bcovish
bcovish's Avatar
Austin TX
Joined Jun 2008
DX18 Warnings
Can warnings be turned on on Aux 6/7. (X-1, X-2)
bcovish is offline Find More Posts by bcovish
Old Sep 14, 2012, 09:14 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes. On the Warning screen, you can select any channel. There are two channel options at the bottom of the screen.
Andy
Site Sponsor
Old Sep 14, 2012, 09:19 PM
bcovish is offline
bcovish's Avatar
Austin TX
Joined Jun 2008
Andy
I see the two options at the bottom but they only go to Aux 5. The X plus channels are active
Old Sep 14, 2012, 10:14 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Sorry, I missed that you wanted X+ channels.
No, you can't alarm on X+ channels, only on standard ones.
Andy
Site Sponsor
Old Sep 14, 2012, 10:33 PM
bcovish is offline
bcovish's Avatar
Austin TX
Joined Jun 2008
Thanks Andy, I moved the channel that I wanted the warning on to Aux 5.
Great radio. Setup my turbine on the 18 and did the test flight with it yesterday. Flew great with no issues. Setting up crow with it was a snap.
Old Sep 15, 2012, 09:23 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Glad to hear that! I hear it was pretty popular at E-Jets and Air Meet this year too.
Andy
Site Sponsor
Old Sep 15, 2012, 08:34 PM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by davidmc36 View Post
Cool, I was not thinking Analog Switch initially.
For sure it will be a Combo switch too, only active when Flight Mode brings the flaps down and the throttle is past the kick point.
I don't think it needs to be active for all Flaps Down Flight Modes either. One notch of flaps on a breezy day does not give me too much issue but two, three, or four notches when it is calm is where I feel the need for it.
Gotta get into some programming now.
I tried some mixing for this. It seems that a curve mix may be the best way to do it, but there seems to be a limit to how close together the points can be. If I could put them closer I would have what I want.
Trying it with analog switch it seemed to reverse the elevator (go back down a bit) when I hit the kick point.
I may have to put my control rod farther out on the elevator horn thereby causing the servo to rotate more to get the proper travel on the elevator. Then I think the wider spaced curve points may work. I have the dual rate turned down pretty far to get the proper elevator travel for this model.
Overall that may give me an added benfit of a slower control surface response because the servo will take a bit longer to get the elevator from "point A to point B". I find the elevator is a tad touchy but I dont want to put too much expo since that can get a little dicey when nearing full travel, it moves fast all of a sudden.
I wonder if another way to go is just do the control horn move and make the elevator a bit "softer".
davidmc36 is online now Find More Posts by davidmc36
Old Sep 15, 2012, 08:56 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
The bump is caused by the kick point not exactly the same as the offset. Tweak the offset a little to get rid of the bump.
Andy
Site Sponsor
Old Sep 15, 2012, 09:08 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Andy
Right on, I'll try that tomorrow evening when I get back into it again.
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
