What's wrong with pluging it in AUX2 or 3?
Latest blog entry: Get Help by posting your SPM File
D*mn? Just trying to understand what you are doing so I can try to help you better.
Is it because you don't want to switch wires around and want to use the radios capabilies? |
Starting with a New Acro Model Type.
For example I used Dual Aileron and Dual Elevator wing type. Go to Channel Assign & RX Port Assignments Move L Elevator to the port channel you want, for example I moved it to AUX2 And moved AUX2 in the place where L Elevator was (AUX4) Then go to the next screen Channel Input Config. Change AUX2 to RKNOB. Now it should be working. If you look at the servo monitor screen you should see the AUX2 name of the channel is moved to the second to last spot which used to be AUX4. So if you connect your choke servo in the AUX4 port, You're RKNOB will contorl the servo plugged into it. If you need any more info you can surely PM me.. |
When I went to the DX7 I had to change 'em all again and didn't even fly my gassers as I needed 8 channels. Then I had to change stuff around again when I got my X9303 and lastly again when the 12X got here. IF I change functions around on the individual rx's, my 12X won't work on that model again. But the BIGGEST problem is that I quit smoking five months ago and right now I'm ready to dump that new radio, get a cigarette or leave things alone for awhile 'till I settle down. Thanks for the help guys, I'll try it in a bit... |
Got it to work and must admit I was overthinking the issue but if one considers who the primary audience is for these things, a bit better explanation (or at least a note) in the manual might be in order. Especially if Andy says the inhouse JR guys have been having the same issue....
Who do you think the primary audience is for this radio?
I would put my money on HH not expecting the current amount of owners over buying. Example: buying it and flying micro BNF models only. Glad you got it working. |
| Thread Tools | |
| Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users | aeajr | Sailplane Talk | 25 | May 29, 2012 03:14 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Dec 20, 2011 05:12 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 4 | Dec 14, 2011 07:30 PM |
| For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 | zaptherio | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 15, 2011 05:14 PM |
| Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Oct 19, 2011 04:59 AM |
