That's really too bad. Is Spektrum going to fix this so that some sounds can be disabled, and others enabled? I hope so. For this kind of money, I don't like being a beta customer.
On some 3D flights, I might go very easy on the throttle. In others, I might fly WOT more frequenty. E.g., during a long elevator, it might take awhile to float toward Earth, in which case during that time I'm not using much from the battery. On other flights, I might do a lot of high energy tumbling, which would use up the energy stored in the battery quicker. The over 25% timer function seems to work well with the sound off. But the lack of audible feedback while trimming bites big time. Spektrum please fix this. It is a user interface issue that is important. |
Latest blog entry: Rusty Thumbs on 3DHK Slick 360
Exploring the DX18. I LOVE my DX8...but I want to have a radio that is future-proof. I see myself doing BIG planes one day...and I want to have the option to use 3 servos per wing, 2 on elevators, 2 on rudder, and throttle and ignition kill.
Obviously the ignition kill doesn't care about latency, but is it possible to set up the other 11 servos to operate at low latency? If I was to put, say, throttle on an X+plus channel, would I notice a difference in responsiveness? |
I have a question about the absolute travel setting. For example on a night vapor i want to use both the aileron and rudder sticks for the rudder and mix it so it works that way how do i prevent overtravel of the servo if by chance both inputs are used. Is 2048 the max # of servo steps no matter what servo is in use? Do I just set the ral and lal settings to 2048? BTW that would be a lot of scrolling! LOL. Just got my DZ18 last evening and playing with a simple airplane to start with. Am not looking forward to setting up my Stryker much less my Radian Pro as of yet with my limited knowlwdge.
Thanks |
It's pretty easy to calculate the values, too. Here is the info you need: 150% = 1024 steps (per side), so 100% = 682 steps. The center position is 1024, so you set the low end of travel to 1024 - 682 = 342, and you set the high end to 1706. If y is the percent of travel in either direction, then x is the value to add to or subtract from 1024 (center position). x = (1024 * y) / 150 Low = 1024 - x High = 1024 + x Quote:
I pulled the Y for the rudders off so mine has Dual Rudder for the tail. Andy |
The difference with X+ is not the latency number, but the way it could possibly vary. The latency can vary from 22ms to 88ms, but the transmitter works an algorithm to try to keep channels that are active at the lowest latency possible, so if you are moving the throttle it would take priority over something that is not moving on an X+ channel. If something like throttle is the only thing out there, then it is likely to not have a latency you can feel. However, you can't put the processed throttle out there, only the raw throttle stick (since X+ is for auxiliary functions, the throttle stick is sent rather than the processed stick). The DX18 supports 4-aileron wings with dual rudder and dual elevator. It does not have a 6-aileron wing type - you would need to create that yourself using mixes. Andy |
@ captdave221 - I have both the Styker and the RP, let me know when your ready and I can post my SPM files to get you started.
Latest blog entry: Get Help by posting your SPM File
| Thread Tools | |
| Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users | aeajr | Sailplane Talk | 25 | May 29, 2012 03:14 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Dec 20, 2011 05:12 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 4 | Dec 14, 2011 07:30 PM |
| For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 | zaptherio | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 15, 2011 05:14 PM |
| Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Oct 19, 2011 04:59 AM |
