Old Sep 06, 2012, 02:56 PM
Howard L is offline
Find More Posts by Howard L
United States, FL, Melbourne
Joined Jul 2005
Has anyone used the remote receiver extensions available from Hobby King. I bought some thinking I could use them for telemetry extensions. I am assembling an H9 1/4 scale Cub and want to hide one of the remotes at the top and behind a bulkhead former so it can't be seen when looking into the interior and I need about a 20-24 inch extension. If I have to get the real deal extension it is going to hold be up a few days but I don't want a faulty remote receiver extension to ruin my day. Thanks
Howard
Howard L is offline Find More Posts by Howard L
Old Sep 06, 2012, 03:04 PM
Gambler71 is offline
Find More Posts by Gambler71
United Kingdom, England, Cheltenham
Joined Apr 2007
DX18 - TM and voltage
I have recently received my replacement DX18 after my original issues from Horizon UK. Despite my disappointment at losing two models to a faulty transmitter, I can only praise the service and response I have received from Horizon UK.
I've had approximately 15 flights with the new radio and everything seems fine so far.
I now want use the DX18 with the TM1000 and an AR9010 DSMX receiver in another airframe, using a CC BEC PRO, which has two voltage outputs, which have been set to 6v.
The AR9010 has one battery port and one data/batt port. If I use the normal battery port for one output from the BEC, the other data/batt port for the connection to the TM 1000, can I use any other spare receiver port, such as Aux4 for the other voltage output from the BEC?
Or should I use a Y lead on the data/batt port and connect both the TM1000 and one output from the BEC through this?
Dave
Gambler71 is offline Find More Posts by Gambler71
Old Sep 06, 2012, 04:38 PM
PeteDee is online now
Find More Posts by PeteDee
Go and fly now!
PeteDee's Avatar
Australia, ACT, Canberra
Joined Feb 2012
Howard
I have some but have not used them yet but my general experience with HK cables is that they are very good and would not hesitate to use them.
PeteDee is online now Find More Posts by PeteDee
Old Sep 06, 2012, 05:50 PM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Dave
The power is connected to all ports in parallel. Just connect it where you want it.
Mukenukem is offline Find More Posts by Mukenukem
Old Sep 06, 2012, 08:22 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Looks like ebay has the smae thing I got, but it's AU $499
http://www.ebay.com.au/itm/Spektrum-...-/170900612748
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Sep 06, 2012, 11:11 PM
dale69101 is offline
Find More Posts by dale69101
Joined Jan 2006
I have a strange thing happening with my TM1000. Just tried to bind it to my JR921 RX. If I plug it into the Data port the RX doesn't go into bind mode, however if I plug it into the Batt/Bind port things seem to work fine. I get telemetry from both Batt1/Bind and Batt2/Data! Is this all a bit strange?
dale69101 is offline Find More Posts by dale69101
Old Sep 07, 2012, 12:51 AM
Buschbarber is offline
Find More Posts by Buschbarber
Buschbarber's Avatar
United States, NY, Rochester
Joined Apr 2004
You won't get Flight Log Data if you plug the TM1000 into the Bat/Bind port. The same is true if you use the TM1000 with an Rx that does not have a Data port. You will still get other Telemetry data (Temp, RPM, Voltage, etc.).
Buschbarber is offline Find More Posts by Buschbarber
Old Sep 07, 2012, 12:52 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
That all sounds perfectly normal.You will get telemetry and the TM will function fine when plugged into any port.You will only gt FL data if it is plugged into the Data port.You wont be able to get both the Rx and the TM to go into bind mode using the button on the TM or a bindplug using a y harness.
In the case of some Rxs where the bind and data ports are not on the same port I sugeest plug the TM into the bind port with a y harness.Put a bind plug in the open spot on the y harness.Power up and bind.Powerdown and move TM to Data port.
aerocal is offline Find More Posts by aerocal
Old Sep 07, 2012, 01:17 AM
Joined Apr 2004
I have my TM1000 connected to the Data port on the AR8000. I can Bind both the Rx and TM1000 using only the Bind Button on the TM1000. The same should be true for the 921 Rx.
http://www.horizonhobby.com/pdf/SPM9548-Manual_EN.pdf
http://www.spektrumrc.com/ProdInfo/F...-Manual_EN.pdf
If I remember correctly, you cannot Bind for Preset unless you use the Bind Plug and follow the Bind procedure for Preset. It was mentioned in one of these threads as a limitation of Binding using just the Bind Button on the TM1000.
Old Sep 07, 2012, 06:02 AM
Joined Jan 2006
Thanks for the responses guys, Aerocal has hit the nail on the head with my problem. The JR921 has the bind and the data on two different ports. This is the reason for the RX not binding as per item 2 in the TM instructions. Basically if I plug the TM into the data port the TM goes into bind but not the RX. Resulting in a failed bind. Most of the other RXs I have looked up AR8000, AR9020 and AR9100 all have the data and bind on the same port therefore correctly binding as per instructions.
If I bind with no bind plug ie TM straight into the bind port then move to the data port after binding what will be the result?
Old Sep 07, 2012, 06:33 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
... If I bind with no bind plug ie TM straight into the bind port then move to the data port after binding what will be the result?
A working system.
freechip is offline Find More Posts by freechip
Old Sep 07, 2012, 08:19 AM
Joined Apr 2004
I understand now why Andy suggests using the Bind Plug in the Rx rather than the Bind Button on the TM1000. I have only been using my TM1000 with my AR8000. I hadn't tried it yet with my AR9000 or R921.
Old Sep 07, 2012, 04:13 PM
Joined Jan 2006
Do you know where Andy has spoken about this in the past? If not I'd like to hear from Andy on this.
Cheers
Old Sep 07, 2012, 04:44 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Use the Advanced Search option. Look for posts by AndyKunz with the keywords
TM1000 servo Y
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Sep 07, 2012, 05:10 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Cheers
The data cable that connect between TM and receiver is generally plugged in the data/bind port in order to get flight log information.
Connect a Y in the bind port, connect the TM in one end and use the other for bind plug
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
