Old Sep 04, 2012, 08:57 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I have it cranked up but not for the lipo battery itself. The reason why I have it cranked up is to help me with once it triggers I can still reduce it and get a couple more minutes of use.
The first couple time it triggered on me I was in the process of programming and my programming was cut short and I could no longer continue.
So I post and recommended owners increase the settings so people get a second chance sort of speak.
Kinda like a the reserve setting on my ATV fuel tank.
As for the default value being good for the batt, don't forget this is a tx battery with minimal current drain on it.
freechip is offline Find More Posts by freechip
Old Sep 04, 2012, 09:00 PM
Jayray123 is offline
Find More Posts by Jayray123
OUCH!!!
Jayray123's Avatar
United States, PA, Erie
Joined Sep 2008
Mine won't read more than 7.8v on the TX screen, while hooked up to my icharger it shows 8.4. My low volt alarm went off the other day while in the air, and when I put my meter on it, it was a full volt higher than what showed on the TX. Is there a calibration that needs done?
Jay
Jayray123 is offline Find More Posts by Jayray123
Old Sep 04, 2012, 09:59 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The 6.4V default alarm is appropriate for technology of cells of the type we sell for it at the low discharge rate. These are NOT LiPos that you would power your plane with!
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Sep 04, 2012, 10:09 PM
Zeeb is offline
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Andy
Thanks Andy....
I was kind of figuring that might be the case but I REALLY hate to assume under any circumstances let alone LiPo batteries....
Zeeb is offline Find More Posts by Zeeb
Old Sep 05, 2012, 01:53 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Jay
Jay
Have you been charging it with an external charger? At what rate have you been charging it? When you checked it with your meter was that static voltage or did you have the equivalent load of the Tx on it when checking externally? Or maybe you tapped into the lead and directly compared the reading on a meter with the display while it was powered on?
It is possible to have a calibration issue but it is also possible if not more probable that there may be an issue with the circuit in the pack itself.
A half a volt is a long way out of calibration.
What pack are you running?
aerocal is offline Find More Posts by aerocal
Old Sep 05, 2012, 05:41 AM
Ib Jensen is offline
Find More Posts by Ib Jensen
Ib Jensen's Avatar
Forest Lake, Minnesota
Joined Apr 2003
Originally Posted by freechip View Post
On a fresh model. Sail - If you enter F-Mode Setup, there you should see Custom
Then it's a matter of going to the next screen and getting to Flight Mode Names screen.
Maybe it's just how I am looking at it.
You can surely make it a request to see that screen more on it's own kinda deal.
Yes you can get to the Flight Mode Names screen through the Sail setup screen if you want to erase your current setup and re enter everything. The setup screen warns you that it will erase your model if you go ahead.
You can change the F-Mode setup easily to add or modes, but the F-Mode name screen is hidden behind the Prev button instead of there being a Next button that should take you to the F-Mode name screen.
I still think it is a bug and it certainly the manual how to get to it except through the Model Type setup screen. Manuals always seem to be an afterthought these days.
I blame Apple for starting that trend "Its so simple you don't need a manual". Or maybe it is a conspiracy by after market "For Dummies" book publishers.
Ib Jensen is offline Find More Posts by Ib Jensen
Old Sep 05, 2012, 02:52 PM
OUCH!!!
Jayray123's Avatar
Joined Sep 2008
Originally Posted by aerocal View Post
Jay
I am running the stock pack, and always charge it with the supplied charger. I hooked it up to the icharger once to see what was going on, and was surprised by what I found. Just odd that the I charger and no load meter agree exactly and the radio itself is off by a bit.
Jay
Old Sep 05, 2012, 08:43 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Does anybody know if there is a global setting to disable the sounds? I know you can do it on a per model basis, but when I'm setting a bunch of planes it would be nice to not have to disable sounds on every model.
Does anybody know if you can copy a plane setup from the DX8 to the DX18? If not, could spektrum make a utility to convert the setup files?
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Sep 05, 2012, 09:23 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
No global sound setting but it has been request already.
Can't use DX8 spm file for the DX18.
Old Sep 06, 2012, 04:02 AM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
I think it is hard to convert since the DX18 offers so many ways to do things.
I would recommend that you do it by hand. You could use the https://sites.google.com/site/txprof...home/downloads to display the DX8 settings on the PC, so you do not have to scroll to the various screens on the DX8.
Mukenukem is offline Find More Posts by Mukenukem
Old Sep 06, 2012, 08:28 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Thanks for the link.
If Spektrum paid me for my time and provided the approriate specifications, I know I could do it. These sorts of things aren't hard, though there might be an oppotrunity or financial cost on the part of Spektrum.
DX18 to DX8 would be more problematic. DX8 to DX18 seems from an outside perspective to be not so difficult. Tedious perhaps, but not as tedious as having each customer do it by hand.
Old Sep 06, 2012, 08:38 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
From an inside perspective, it's a big deal. While not impossible, it's certainly a BIG project.
Just as an example, take a default model from your DX8 and export it. Do the same for a DX18. Compare the results. Note in particular the quantity of differences in values assigned for things with "ID" in their name.
Andy
Site Sponsor
Old Sep 06, 2012, 10:02 AM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
Andy
For the guys who just like a nice easy to use tx - the DX8 shines
I think of it as a "concept " design and the DX18 as a "refined concept " design.
It becomes apparant very quickly that the amount of info available in the DX18 tx required a different processing setup-
so---- I decided that it would be best for me - to accept that programs are not interchangeable even tho the "programming concept" is basically the same .
richard hanson is offline Find More Posts by richard hanson
Old Sep 06, 2012, 10:37 AM
7oneWo1f is offline
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Regarding the DX8, I just looked at my receipt, and what I got for it. $340 for a DX8, TM1000 and sensors, and two AR8000s. The radio was cheaper than a DX6i in that deal. Which is probably why I jumped all over it last year. I'd probably jump all over it again if they offered it still.
That DX8 deal must have been a loss leader, or manufacturing/distribution costs must have doubled in the last year.
Old Sep 06, 2012, 10:44 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Wow-where did you get that deal? I'd be all over it like a cheap suit!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
