Old Sep 03, 2012, 05:47 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
XPLUS channels X+1 and X+2 correspond to channels 11 & 12. Do your channel input assignments and mix setups with XPLUS enabled (use the Frame Rate screen to enable it, then bind). After you have it working, you can turn off XPLUS.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Sep 03, 2012, 05:58 PM
Ib Jensen is offline
Find More Posts by Ib Jensen
Ib Jensen's Avatar
Forest Lake, Minnesota
Joined Apr 2003
I found a small but annoying bug in the latest DS18 flight mode setup software. The flight mode naming screen is not easy to find since it is accessed by hitting the PREV button on the prior screen.
Not a big deal but it did frustrate me for a few minutes.
Ib Jensen is offline Find More Posts by Ib Jensen
Old Sep 03, 2012, 06:41 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Small bug? It's just a matter of how you view things. Flight Mode Name Setup is right there in plain view in the system setup list.
In Sail Type, clicking on Custom brings you to different screens where when you scroll to next brings you the Flight Mode Names and there you can edit the names.
Fairly easy when you know how it works and that would fall to the manual to instruct but we all know the story with manuals.
freechip is offline Find More Posts by freechip
Old Sep 03, 2012, 07:08 PM
indoorheli is offline
Find More Posts by indoorheli
2 seconds from crashing
indoorheli's Avatar
United States, WA, Seattle
Joined Sep 2007
Can you assign any function to any channel such as throttle to channel 4?
indoorheli is offline Find More Posts by indoorheli
Old Sep 03, 2012, 08:44 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Yes. Primary functions can be assigned to any of the first 10 channels. Any switch or input can be assigned to them as well.
Secondary functions or raw stick inputs can go to the XPLUS channels, but XPLUS cannot do things like Right Aileron or similar due to the variable latency.
Andy
Site Sponsor
Old Sep 03, 2012, 09:06 PM
indoorheli's Avatar
Joined Sep 2007
Perfect thanks Andy..time to sell the dx8.
Old Sep 04, 2012, 07:30 AM
Ib Jensen's Avatar
Joined Apr 2003
I don't see that on my DX18:
System Setup
< Main Screen >
Model Select
Model Type
Model Name
Sailplane type
Tail
Motor
F-Mode Setup
Chanel Assign
Trim Setup
Model Copy
Model Reset
Warnings
Telemetry
Preflight Setup
Frame Rate
Bind
Trainer
Analog Switch Setup
System Settings
Transfer SD Card
I can still only find the Flight Mode Names screen by selecting Prev on the Flight Mode Table screen.
Old Sep 04, 2012, 07:53 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
On a fresh model. Sail - If you enter F-Mode Setup, there you should see Custom
Then it's a matter of going to the next screen and getting to Flight Mode Names screen.
Maybe it's just how I am looking at it.
You can surely make it a request to see that screen more on it's own kinda deal.
Old Sep 04, 2012, 08:19 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
In Sail mode that is correct. That is where you edit the names.
Andy
Site Sponsor
Old Sep 04, 2012, 08:41 AM
Howard L is offline
Find More Posts by Howard L
United States, FL, Melbourne
Joined Jul 2005
Andy
Andy,
I am not real clear about the 'Channel Assign' screens and could use a little direction. When you say that you can assign the primary functions to any of the first 10 channels and then any switch or input can be assigned it seems to conflict with my hands on experience with the DX18. For example when I use the 'Aircraft Type' menu in the 'System Menu' to create a new plane that has 2 ail, 2 flaps, and 2 elev and then move the 'Channel Assign' menu I find that all but two channels have alread been assigned and that if you wanted to assign the gear channel to 'Gear' and the gear switch you cannot do that because the radio does not make those choices available to you. Am I doing something wrong or do you mean you can move only primary flight controls around and change inputs only on those channels not being controlled by the radio due to choices made in the 'Aircraft Type' menu. I sure hope this is understandable and if not don't waste your valuable time -- I will keep plugging and figure it out.
Howard
Howard L is offline Find More Posts by Howard L
Old Sep 04, 2012, 09:36 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
The Aircraft Type screen selects a default channel assignment for all the aircraft control functions (left/right ailerons, left/right flaps, etc.). These selections will, for the most part, match the channels selected by a DX8. The intent is to allow use of the smallest receiver (save you money).
The "Channel Assign" menu option gives you two screens. The first screen allows you to map an airplane control function to a receiver port. This means you can put the Left Aileron, for instance, onto any channel shown there.
The second screen allows you to map an input device to an airplane control function, but only to auxiliary functions. So you can put a switch onto the AUX1 function in this screen, then on the other screen put the AUX1 function into the AUX3 receiver port.
One more item: When the channel processor assigns functions, it takes ownership of that function. In your example, Left Flap was put onto the slot normally named "Gear" so there is no more function named Gear any more. You can still control your landing gear if you wish, but you do it through a function with a different name. HINT: If you use the Sequencer for controlling the gear, you can get the name back if you want to.
Does that explanation make more sense?
Andy
Site Sponsor
Old Sep 04, 2012, 09:56 AM
Howard L is offline
Joined Jul 2005
Andy,
Thank you sir and yes it does make sense and correspond with my experience. Thank you.
Old Sep 04, 2012, 08:27 PM
Zeeb is offline
Find More Posts by Zeeb
Zeeb's Avatar
United States, UT, Highland
Joined Jun 2006
Oh man, two hundred plus pages.... wow!
Although I've been kind of following this thread, I got a DX18 a bit sooner than I expected. It's most likely been addressed but I've not found it; the low battery warning seems like it's set way too low for modern LiPo batteries, is anyone cranking that voltage up a bit for the low battery warning?
Zeeb is offline Find More Posts by Zeeb
Old Sep 04, 2012, 08:54 PM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Uuuh, 6.4 seems fine?
davidmc36 is offline Find More Posts by davidmc36
Old Sep 04, 2012, 08:57 PM
Zeeb is offline
Zeeb's Avatar
Joined Jun 2006
That's what I'm asking; most LiPo batteries now have a higher cutoff voltage than the previous 3.2 volts or so with most indicating that LiPo's should not be drawn down below 3.7 volts per cell now....
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
