Old Aug 30, 2012, 12:42 PM
howcar is offline
Find More Posts by howcar
Joined Jun 2004
[QUOTE=RCing;22593311]NO ACTION? how do you know this? Do you work for the company and this is why you no what is going on at HH/Spek?
I don't mind giving them time to work out the issue. I've been to the mechanics before where I needed to come back or leave the car to them for some time so they could find the problem and fix it then they always go for test drive to ensure it's working properly.
Unless you work for them and can say no action is being done, I much rather wait and see for myself.[/QUOTE]
But you wouldn't wait weeks and weeks or months and months for your car, would you? No, you would expect results.
And when you got it back and new faults had been introduced, you'd be ok with that too, would you? Well, no you wouldn’t, so why is it ok for Spektrum but not your garage?
As for NO ACTION, please read my post carefully. It clearly sayscan produce no action’.
They may well have been working behind the scenes, but Andy is generally careful to ensure we are not told this (or even supposed to ask). And anyway, the action is only valid for the end user when it is released and fixes the problem.
Just how much time do you want to give them before they fix your car (sorry, radio)?
If bugs were sorted within a reasonable time scale,( and even those who find no fault with Spektrum products have commented they also think they aren't), I suggest most Spektrum forums would be a third less long than they are now and we wouldn’t be having this conversation.
FIX THE BUGS AND PROBLEMS IN A TIMELY FASHION - THAT IS HH's DUTY. HOW CAN YOU POSSIBLY ARGUE AGAINST THAT?
howcar is offline Find More Posts by howcar
Old Aug 30, 2012, 01:04 PM
AeroKen is offline
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
The way I read some of Andy's posts about the recent DX8 update is there has been some fundamental re-architecture going on which is not really visible to the user, but which will enable faster development in the future. I believe the DX7s, DX8, and DX18 now share a lot more code than they used to. That should reduce the bug count for all of them, and get updates/fixes out for all faster.
AeroKen is offline Find More Posts by AeroKen
Old Aug 30, 2012, 01:15 PM
RCing is offline
Find More Posts by RCing
Closed Account
Joined Mar 2011
@ Howcar - Yes you are right however I do place higher priority on my car then I do my toys.
RCing is offline Find More Posts by RCing
Old Aug 30, 2012, 01:30 PM
hakank is offline
Find More Posts by hakank
Sweden (Åkersberga)
Joined Nov 2004
Having about 10 model memories occupied, do I dare to upgrade to 2.05?
From the redme:
"NOTE: This change affects sub-trim and travel of existing models and ones you
will import. You may need to adjust sub-trims and travel on all control surfaces in both airplanes and helicopters."
I'm not very found starting all over with 10 models again..
Has anyone tried upgrading?
/Håkan
hakank is offline Find More Posts by hakank
Old Aug 30, 2012, 01:49 PM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Håkan,
The issue is only for reversed channels with non-zero subtrims or asymmetric travel ranges. If you don't use sub-trim and have equal throws on the reversed channels, you will be fine.
If you can wait a few weeks, we are working on an update which will make the update smoother for you.
If you don't have channels in an aircraft meeting those requirements, then you won't run into any problems.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Aug 30, 2012, 04:20 PM
bcovish is offline
Find More Posts by bcovish
bcovish's Avatar
Austin TX
Joined Jun 2008
Anyone know how to setup crow on the DX18? If so could outline it here. It's kicking my how to do it.
Bob
bcovish is offline Find More Posts by bcovish
Old Aug 30, 2012, 04:22 PM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
You need a wing with 2 ailerons.
Mix the input you want to use to LAL at a high percentage.
Andy
Site Sponsor
Old Aug 30, 2012, 04:48 PM
Busher is offline
Find More Posts by Busher
Joined Apr 2011
From the redme:
/Håkan
I have upgraded, and the effect it has had on my models (12 in total) is minimal. I have had to redo the reversed channels that had subtrim but it was an easy sort out. All my flybarless heli's (4 in total) have been easy to put back to centre. I have yet to get round to my vbarred heli but I guess this will be the same.
I am a bit cheesed off about the end point adjustment being reversed on reversed channels and also that it seems to have got worse, but I reckon they are working on a fix just need time to get it in the right place at the right time.
I have noticed something though on a positive note, Before I updated I re callibrated the hand set, then I updated. When I revisited my flybarless heli's the stick inputs needed no subtrim and the end throws where at 100%, this was not the case before, they needed 6 points of subtrim to centre and 3 points on end throw to make 100% throw. That has made my set ups dead easy and I can now relate the stick input to the displayed tx and computer values.
So I am pleased that the update has made my setups easier to accomplish.
The mixer bug caught me out, and I am glad that was fixed, I like the backlight options and the TX idle alarm can now be configured to different times.
You should have no fears in upgrading to 2.05 it works well.
Busher is offline Find More Posts by Busher
Old Aug 30, 2012, 10:12 PM
bcovish is offline
bcovish's Avatar
Austin TX
Joined Jun 2008
Andy
I have it setup with 2 ailerons and 2 flaps
I was at Illini Jets in Monticello last weekend. Had a great time.
Old Aug 31, 2012, 08:05 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Thanks for coming up! I was coming back from vacation so I missed the event. Hopefully the trash truck gets there today before Isaac visits!
You can do something like mix LLV > RFL, at 50%/50%, with the offset = 100%. Now as you pull the left lever, the flaps come down.
Next mix is LLV > LAL, 50%/50%, offset=100%. When you pull it down the ailerons will go up.
You might need to use -50%/-50% on one or both mixes to get the travel in the correct directions.
Adjust the mix ratios as desired for the amount of deflection you want.
You may need to use the Absolute Travel to keep from overdriving servos.
Andy
Site Sponsor
Old Aug 31, 2012, 12:50 PM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
Thanks for your input. I was also looking forward to the fixes and enhancements. However I think I wait a little bit more as Andy said a new update is on it's way with an easier way to upgrade.
Old Aug 31, 2012, 12:55 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Don't confuse the DX8 thread versus DX18.
Håkan,The issue is only for reversed channels with non-zero subtrims or asymmetric travel ranges. If you don't use sub-trim and have equal throws on the reversed channels, you will be fine.
If you can wait a few weeks, we are working on an update which will make the update smoother for you.If you don't have channels in an aircraft meeting those requirements, then you won't run into any problems.
Andy
It may have been posted here but it's ment for the DX8 IMO
freechip is offline Find More Posts by freechip
Old Aug 31, 2012, 01:04 PM
hakank is offline
Sweden (Åkersberga)
Joined Nov 2004
To mix up things even worse, I happen to have the DX8 but writing in the DX18
Old Aug 31, 2012, 01:13 PM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I figured that when you posted update version 2.05 (DX8).
The DX18 is at 1.02
Old Aug 31, 2012, 01:16 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Well I just joined the owners club. Sold my A9 (loved it) but I have too many BNF planes and micros so needed an upgrade to my trusted but old DX7.
Hope I don't miss the touch screen too much!
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
