To change your flight mode switch assignments, you just pick new switches (see that PREV button in the bottom left corner?). If you want to try again completely, change all the switches to INH, exit to the menu, come back in. Now select Edit Custom (NOT the "Reset" one!) and re-build w/o losing what you already did. If you don't want flight modes to do anything, pick a different switch to control it (there's a switch INH which means its disabled, and another ON which makes it always enabled). Quote:
Andy |
Joined Jan 2006
Hi I'm having a problem updating my DX-18, I have downloaded the file and transferred it to the SD card. When I start up the TX nothing different happens the transmitter starts up as normal? here is a pic of what is on my SD card
Under "System Settings" and "Serial number" it has export 1.00. I live in Australia and US-247 displays when I switch on the transmitter. Also should I remove old update files and the saved models? |
from what I can see in your pic, there is a file named "spmtx-2.sax" (red highlighted) in your SD card. Maybe it is the downloaded file, renamed by your Operative System (MAC OS?). Its correct name should be "spmtx.sax". Please, double check the file name after download it; if it is different from "spmtx.sax", you should correctly rename it before transfer it to the SD card. About the old .sax file (spmtx100.sax in your pic), you could remove it if you want. Ciao, Egidio |
Italy
Joined Nov 2009
Question:
i'm tring to setup an EXTRA 330 with two servo on elevator, i have chose the appropriate configuration (aircraft with two servo on elevator), but when i try to SUB TRIM them, both surfaces move! How can I sub trim separately the two elevator servo? THX!!! |
In Servo Setup screen on the Sub Trim menu there should be LEL and REL. pick the one you want then trim.
Italy
Joined Nov 2009
![]() before I connect the plain whit my new DX18, I had use my old DX7 and I forgot that the two elevon servos was connected to the RX with an Y cable! ![]() thanx and sorry for the stupid question! |
In Flight Mode with 2 Switches, can I change the position of where one Switch operates the other? Example: LLever0>FM1, LLever1>FM2,4,5, LLever2>FM3. Changed to: LLever0>FM1, LLever1>FM2, LLever2>FM3,4,5. ...Still bummed that I can't do slow proportional flaps with slow elevator comp. But this could help. How do I turn off the Registration screen that pops up when turning the radio ON or OFF? Is there a way to save Pre-Flight Checks that I created in place of the ones that are installed? OK, Here's a mix for ya. And I've tried Normal and Curved mixes, combo switches, switch controlled function to function, but since no mix will offset, nothing workie!... Is there some other way you are offsetting a function to get your mix? Example: P-51. Radiator Cooling Flap (CFlap) used for scale cooling to electric system. It works with Throttle, D, and Gear. Throttle>CFlap: 0-50%> Full Open 50%>CFlap starts to linear Close (no expo) 100%>Closed Switch D>CFlap: D0>Manual Closed (Overrides both Gear and Throttle) D1,2>Automatic (Always Open with Gear Down / follows Throttle with Gear Up) Gear>CFlap (D2Auto): Down>Full Open (overrides Throttle and D2) Up>Automatic with Throttle "Whyyy, I've had this mix on my 10x for years... No offense!" - R. Dangerfield voice...
Have a look at my Twin Otter file, you can see the difference. |
Andy |
I don't think it is a niche market at all. I do think that relative to all the other items controlled by spektrum technology though it is pretty small.
If you were to compare the quad copter flyers vs all the bind and fly, gassers, and electric guys, it is probably less than 1% in all honesty. Same with UHF devices controlled out of the spektrum trainer port. Andy said they don't support UHF....no problem...I understand that isn't their market. Markets are driven by sales and profit. If thousands of quad copter guys were saying to spektrum that they are buying the competition then I sure the attitude would be different, but we aren't there yet. I feel your pain, but like my uhf issue, you probably won't get official support. |
1.02 Firmware Flaw
I believe I have found a firmware flaw in 1.02 or if this is already a known issue then all the better.
In helicopter mode. Bound in DSMX 2048 11ms. If you reverse a channel like aileron or etc. then AFTER the channel is reversed if you adjust travel adjust(end points is what I and most call it) where BOTH numbers are adjusted at the same time everything works. If you for instance hold full left aileron and adjust one side at a time NOTHING MOVES. It will only do this if the channel is reversed. Adjust left and right at same time everything works. Adjust one side at a time and you can scroll way over the default percentage of 100% or WAY under and nothing happens. Go to the monitor and it shows everything adjusting BUT... nothing actually moves. I have not tried to see if this flaw exists in DSM2 mode or not, but in DSMX at 2048 11ms it sure does in helicopter mode. It sure needs to be fixed quickly. Have not come across any other issues. Norman Ross Jr. |
| Thread Tools | |
| Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users | aeajr | Sailplane Talk | 25 | May 29, 2012 03:14 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Dec 20, 2011 05:12 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 4 | Dec 14, 2011 07:30 PM |
| For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 | zaptherio | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 15, 2011 05:14 PM |
| Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Oct 19, 2011 04:59 AM |
