Old Jun 22, 2012, 09:45 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Originally Posted by Minimog View Post
Andy,
So if I understand correctly I should have the first sequence to deal with the doors (only mains have doors), then sequence the mains of the gear door position and lastly have the tail retract off the position of one of the mains? Does that sound right?
That's one way, and it would work.
Given this new info, I would run 2 sequencers.
One would be the as-provided demo for one side of the plane with only perhaps a change to the time duration. WHL and DOR would be almost unchanged. The second would be a copy of it for the WHL channel, with slight changes to the points near the end to achieve the different left/right timing.
The DOR on the second sequence would be renamed to the TW and would have the appropriate up/down commands for the tail wheel.
I'd either use a Y cable or a copy of DOR to control the inner doors.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jun 22, 2012, 10:05 AM
Minimog is offline
Find More Posts by Minimog
Canada, BC, Coquitlam
Joined Dec 2009
Ok, but if I didn't want to Y anything (got plenty of available channels, ar9020 + x-plus 8), would I still be able to do it with 2 sequences or 3 would be required? If I understand correctly each sequence is able to drive two separate physical channels?
Minimog is offline Find More Posts by Minimog
Old Jun 22, 2012, 10:15 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
There are several ways to skin the cat.
The easiest is to do the "Y" in the tx. Just make a copy of DOR in the Channel Assignment screens. It's easy, and ensures that the doors close together. If you want the doors to close a little differently, you can do that with the Servo Speed functions.
Andy
Site Sponsor
Old Jun 22, 2012, 10:33 AM
Minimog is offline
Joined Dec 2009
Got it! Thanks Andy.
Old Jun 22, 2012, 02:38 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
My dx18 got lots of positive comments and admiration at the Warbirds over North Texas event last weekend at the North Dallas R/C club site....great event. A couple of guys did not care for the TX antenna until I explained the TX antenna diversity feature to them and mentioned that the new antenna is a lot less likely to ever get damaged... Then they appeared to like it better!
Like the feel and balance of the DX18 more and more. I normally fly without a neck strap and the balance is perfect for me. I had two warbirds up and working in the DX18: my H9 F6F and Starmax A-1 Skyraider. Now have 6 models on the DX18 and every time I put one in there, I like the programming more and more.
Thomas B is offline Find More Posts by Thomas B
Old Jun 22, 2012, 02:44 PM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
That is one great local event!
eroeder is offline Find More Posts by eroeder
Old Jun 22, 2012, 02:49 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Originally Posted by davidmc36 View Post
Twin Otter
Wanted:
Five flap positiions: UP, 10, 20, 30, 40 degrees (because it is scale)
Differential Thrust mixed to Rudder
Aileron Droop
RUD-AIL mix for crosswind
Nose wheel is just "Y" connected to RUD, I achieved all the taming down of steering mechanically.
Dual Elevator servos that have to be opposite travel directions (not my choice, just the way the aircraft was constructed/configured)
Flaps, Droop, and Elevator offset to move at slow speed (each reaching their target at the same time)
Sequential use of Flight mode switches so all my actions are of the same format that I have been using since my first computer radio 15 years ago. Up/Away From Me for "flying" and Down/Towards Me for "landing" is the convention I have always used. What you referred to as "Panic Mode", I want to be all the same direction of stick movement, not have one towards me and another away from me on the primary switch.
This is the way I want the F-Mode switches to work:
B in 0/C in 0--FMode1
B in 1/C in 0--FMode2
B in 2/C in 0--FMode3
B in 2/C in 1--FMode4
B in 2/C in 2--FMode5
I expect that all my desires for Dual Elevators and Differential thrust would be easy to do in Acro but the lack of assignability of the primary F-Mode switch in Acro is what drove me to try it in Sail.
When you get all or most of that worked out, will you share it for my Twin Otter???.....
Latest blog entry: 2014 events and travel
Old Jun 22, 2012, 03:11 PM
SlayerNZ is offline
Find More Posts by SlayerNZ
Spektrum Fan Club
SlayerNZ's Avatar
New Zealand, Southland, Gore
Joined Jan 2011
Originally Posted by AndyKunz View Post
Nope, they're totally different gimbals than the DX8. Buy the mode you want! You would literally have to disassemble the entire radio to swap the gimbals. Let OMP do it for you.
Andy
Thanks, It might be easier to attempt a gimbal change as it will be ages before there are more mode 1 versions in the country.
SlayerNZ is offline Find More Posts by SlayerNZ
Old Jun 22, 2012, 04:11 PM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
I sure will!!!!
Actually I just fixed what I needed. Opened the SPM file in wordpad and copied the F-Mode entry from a SAIL Model into an ACRO model and imported. The switches work the way I want them to now. The rest of the mixes and whatever should be easy to set up since I will be working with an ACRO with dual elevators.
I expect that if I ever visited the F-Mode setup screen again all would be lost though.
How do we say it? More than one way to skin a cat!!!!!!!
I will still take a shot at setting it up as a SAIL just to see how it goes. I will share that too when I have a chance.
davidmc36 is online now Find More Posts by davidmc36
Old Jun 22, 2012, 04:13 PM
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Twin Otter
Wanted:
Aileron Droop
Oh yeah, forgot about the flight idle feature using the left lever. Should be no issue.
Old Jun 23, 2012, 06:20 AM
Mukenukem is offline
Find More Posts by Mukenukem
Vienna, Austria
Joined Oct 2010
Just a quick one: Can I copy/paste the settings from the DX8 directly to the 18 ? I understand that I cannot transfer it via SD card, but if I can transfer the values, subtrims, etc 1:1, it would be helpful.
I hope my new toy will arrive on tuesday. Hopefully. Been waiting long enough...
Mukenukem is offline Find More Posts by Mukenukem
Old Jun 23, 2012, 06:40 AM
Cherokee Flyer is offline
Find More Posts by Cherokee Flyer
Cherokee Flyer's Avatar
United States, KS, Rose Hill
Joined Sep 2007
The copy and paste has worked great so far in my case, of course you need to rebind and check movements. I have moved several across with sucess. I have had the airplane fly without a single click of trim change.
L.
Cherokee Flyer is offline Find More Posts by Cherokee Flyer
Old Jun 23, 2012, 06:43 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Transferring values like sub trims is a bit helpful but not 100% as the two radios may not be 100% indentical.
Haven't got mine yet to try it but it may be possible to copy&paste part of the spm file that contains that information from one radio to another.
I will surely give it a try because of the amount of members asking but looks like you will be getting yours first so the answer is No but maybe Yes.
freechip is offline Find More Posts by freechip
Old Jun 23, 2012, 06:58 AM
Howard L is offline
Find More Posts by Howard L
United States, FL, Melbourne
Joined Jul 2005
The battery in the DX18 is a 2S 2600 mah LiPO and is charged with the provided power supply plugged into the radio where the charger is located (if I have that wrong someone please correct me) I noticed that the battery has only two leads going to it which prevents it from being balance charged. I was under the impression that it was best/necessary to balance charge a LiPO. Any comments?
Howard
Howard L is offline Find More Posts by Howard L
Old Jun 23, 2012, 08:00 AM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Howard, if it is like the DX 8, the radio does it for you!
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
