USA, LA, Sulphur
Joined Apr 2006
You have to manually add points 6 & 7. Move the throttle stick in an area between the other points and at the bottom of the screen you will see it show "add point". Scroll down to the bottom over "add point" and click it. If you want the points spaced evenly across the whole range you will first need to remove the points at 25% and 75% using the same method listed above then add them back where you want.
Rhode Island USA
Joined Aug 2010
![]() VP |
If you exit the screen, they are connected by default and the switch works to select the graph as you expect. Once you change the curve manually, they become disconnected (independent). The label in the top always shows the current switch position. Andy |
I havent had a chance to jold one yet. I respond well to tactile objects. Hopefully this will get a tick.
Maybe one for the future.... I love my FPV... It would be great to have any switch change or slider change flash on the goggles for a couple of seconds, like the volume prompt or channel name hates flashed on a television screen. |
Andy..
Didn't quite understand your reply about the Connect / Disconnect thing on the Throttle Curve Graph... Other Setup Screens change the Graph when you toggle a switch - The Throttle Curve doesn't.. More importantly, the label changes on the Graph when you toggle, showing the Wrong curve... I'm sure others have noticed this - or Not? Can you try to explain it again... Am I missing something here? Thanks.. |
The throttle curve is handled differently than the other curves. The behavior you have is exactly what the spec says it should be for the throttle curve and the different behavior on others is what the spec says they should be.
The current position of the switch is in the top left corner. It shows in text what the switch is set to. It's not always easy to see the position marker below the checkboxes especially if you use Flight Mode as the switch. This is the not title of the graph you're looking at, it's the name of the switch position. Throttle curves are specifically disconnected from the switch position so that you can select a curve w/o causing a change to the throttle servo. The other curves default to being connected so that you can see the change immediately on the aircraft. Andy |
| Thread Tools | |
| Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users | aeajr | Sailplane Talk | 25 | May 29, 2012 03:14 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Dec 20, 2011 05:12 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 4 | Dec 14, 2011 07:30 PM |
| For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 | zaptherio | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 15, 2011 05:14 PM |
| Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Oct 19, 2011 04:59 AM |
