Old Jun 07, 2012, 06:08 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Originally Posted by Howard L View Post
... have all new trims programmed to handle balooning from the flaps ... Howard
Doesn't the elevator compensation take care of this instead of having new trims programmed with flaps? I have several flap planes and use the elevator compensation inthe flap menu system to help with balooning/pitching.
Just curious you can PM me if you want to..
freechip is offline Find More Posts by freechip
Old Jun 07, 2012, 07:00 AM
Howard L is offline
Find More Posts by Howard L
United States, FL, Melbourne
Joined Jul 2005
Freechip: If you are using flaps you could put most of the needed trim change in the flap-elevator compensation. The flap screen on the DX18 is very handy for this. For landing you may or may not use the flaps and if you do not use flaps then transitioning to a landing 'flight mode' could be used to change the elevator trim (for reduced power) and depending on the type of plane you may want to change the rudder trim also needed for reduced power and reduced air speed. Having a flight mode delay would allow this to occur slowly instead of a step function and subsequent bump in airplane.
Howard
Howard L is offline Find More Posts by Howard L
Old Jun 07, 2012, 07:58 AM
Steve Graham is online now
Find More Posts by Steve Graham
AMA L897187
Steve Graham's Avatar
NE Denver, CO
Joined Sep 2007
Hey Andy,
Any update on my question from post 1456.
I'm pretty sure it's a glitch as even the manual says you can do it on page 14.
Steve Graham is online now Find More Posts by Steve Graham
Old Jun 07, 2012, 08:11 AM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Originally Posted by W.W. Corrigan View Post
Hey Andy,
Is it flight mode dependent? I would expect it to work in Normal and Hold and be disabled in Idle-Up.
Fig Jam is offline Find More Posts by Fig Jam
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
When we tested it here, both the analog and digital trims were active on throttle when selecting analog. We were not able to reproduce your claim that analog was not active. There is a bug there, but not the one you mentioned so far as we could tell. Having an SPM file would make it easier for us to try to track down your issue.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Jun 07, 2012, 08:20 AM
ltdorn1 is offline
Find More Posts by ltdorn1
United States, AZ, Sierra Vista
Joined Dec 2007
Originally Posted by Harry H View Post
Ever considered the guys in the brown shorts used your package for football practice?
Harry
I would think there would have to be some SERIOUS g loads on that package to get a Rx to fail, plus the shipping box was in fine condition when it was received.
Just really annoyed to get the one system where both the Tx and Rx have a problem. but in reality who actually uses those dials anyway? In my 20 years plus, i dont think i have ever used them on any Tx (maybe a heli hover trim out). But i paid for a 100% working system and thats what i would like.
R/
ltdorn1 is offline Find More Posts by ltdorn1
Old Jun 07, 2012, 09:17 AM
AMA L897187
NE Denver, CO
Joined Sep 2007
Andy
I will see if I can send you the file you requested. How do I do it?
Old Jun 07, 2012, 09:24 AM
freechip is offline
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Export model file on sd card.
Transfer or copy the model file from sd card to pc.
Email model file / spm file to Andy
Old Jun 07, 2012, 10:53 AM
Roger Anderson is offline
Find More Posts by Roger Anderson
Aeronaught
United States, OR, Sherwood
Joined Oct 2007
Test msg
Roger Anderson is offline Find More Posts by Roger Anderson
Old Jun 07, 2012, 10:57 AM
Aeronaught
Joined Oct 2007
2. AR9020 Rx. Will not power up or bind right out of the box. The tx will bind with my other spektrum Rx's. (annoying because i only have a couple of the 6 channel spk rx. and needed the 9 channel to run the pawnee)
I found the same problem, which was caused by me assuming the servo wire polarity was the same for both sides of the AR9020....I called Horizon and they helped me discover that although I had the servo wires connected correctly on one side, assuming it was the same orientation on the other was not quite the way to go.
Thanks again to the help offered to my earlier request for powered glider setups, VERY much appreciated!
Old Jun 07, 2012, 11:32 AM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
Very nice unit! Now I must play with it and start transfering data...
Wonder when Spektrum will have downloads for the various aircraft available for the DX18 as they do with the DX8, any news Andy?
eroeder is offline Find More Posts by eroeder
Old Jun 07, 2012, 03:34 PM
ltdorn1 is offline
Joined Dec 2007
Woot.. thanks Roger... it was the labeling on the sides of the rx that threw me off.
So Rx is good woot. as for the r dial... maybe after the new transmitter excitement wears off i will send it it to get fixed.
R/
Old Jun 07, 2012, 04:23 PM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Timer Functions
I was just browsing through the manual and realized some functionality of the timer. When I messed around a bit on the weekend I noticed that with the default setting of 25% throttle to start the timer, that it stopped again when I moved the throttle below 25%. I thought, that is a nice way to have it. If you have a chance to stop on the runway and do some adjustments and then take off again it will pause while you are stationary and then resume when you take off. In that case I would have the threshold set very low so it only stops when you are basically at zero throttle.
I now see there is another setting in the timer screen One Time, and default is inhibit. I assume if you made another choice like Active then once started it would continue to run even if you went below your threshold again?
That makes for flexible configurations you could have.
davidmc36 is offline Find More Posts by davidmc36
Old Jun 07, 2012, 05:04 PM
tourist_603 is offline
Find More Posts by tourist_603
Joined Dec 2007
Neck strap gizmo
The DX18 comes with a neck strap. The strap has a hook for attaching to the tx. Attached to the hook is a split ring. Also attached to the split ring is a black plastic gizmo that has a quick release buckle and a loop of what looks like black nylon twine. Curious minds wish to know the purpose of the gizmo, which is obviously specifically designed to do something. Maybe to attach one's receiver bind plug to, to make it harder to lose?
tourist_603 is offline Find More Posts by tourist_603
Old Jun 07, 2012, 05:17 PM
Willyboy is offline
Find More Posts by Willyboy
Willyboy's Avatar
United States, CA, Tehachapi
Joined Sep 2007
Does anyone know if I can download upgrades for the Spektrum transmitter on a Mac computer? I will be getting a DX18 soon and I don't own a PC. Would it be possible for me to put the SD card into my Mac after downloading upgrades and then put the SD card into the transmitter and have everything work okay?
Bob
Willyboy is offline Find More Posts by Willyboy
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
