Ya for sure, I may not own one right now but still very much reading in as much as I can.
Latest blog entry: Get Help by posting your SPM File
United States, OR, Sherwood
Joined Oct 2007
Love the TX...I have two (Count 'em) DX8's and have attempted over the past year to get a 6-channel powered glider programed on one of them.....had to give it up and await release of the DX18. Though I did find in this thread the Kennedy composite non-powered glider setup...Spektrum has not as yet anything on the 'community' site. If anyone here has set up their DX18 for a powered glider and would share....I would try to use it as a 'tutorial' and perhaps learn enough to do it myself. Perhaps.....
Thanks in advance to the White Knight!! |
Mike |
Andy |
Joined Dec 2007
First impressions DX18
my DX 18 came monday ( i preordered back in early march) i have been reading the manual. i have a DX6i i bought just for my MCPx otherwise i have been a futaba guy my last 20 years in RC. Now i have a couple aircraft running spektrum. I got the DX18 because i wanted to try out the telemetry stuff and no way i am paying $3K for the futaba 18mz.
1. Tx. the right dial doesn't have full range. i realized it when it kept doing the centering peeping sound. then i shook the radio and and it got worse. then started flipping dial, switches, stick... then realized it the dial. went to the calibrate screen and noted with will not give the OK for the right dial. The servo monitor screen confirms no full throws. If you tap the top of the dial, the throw jumps all over the place. R/ Lawrence LCDR US Navy |
Kirkland Washington
Joined Feb 2002
Six servo Glider with a motor
If you want to add a motor, it is REAL simple. In Sailplane Type, at the bottom of the screen is the motor selection. When you scroll over this section and click, the box will start blinking. Scroll through all the possible selections to use, switch, stick, lever or throttle. Check Rx Port Assignments to see where the radio assigned the ESC to be plugged in. (should be #7) In the Function List, two new menu selections will show up. Throttle Cut and Throttle Curve. Everything you need should be there. Hope this helps. Sherman Knight |
San Jose, CA USA
Joined Oct 1999
One thing I like about the DX18 is that I can set common or independent trim for each channel... since I want the same nose gear steering trim for both takeoff and landing, but I want independent trim on elevator and aileron. And yes, this is fixed wing powered stuff. No, its not "spooky", its the quick and easy way to do it. Bob |
South Africa, KZN, Durban
Joined Apr 2012
Joined Apr 2012
Hey Sherman,
Downloaded your 6 servo glider program. The downloading worked great! Checked your programming out on the servo monitor and it all looks fantastic. Just one question though, when moving ailerons (can't remember in which flight mode) the aileron moving down reflexes slightly upwards at max stick deflection - what is the reason for that? Thx Stan |
Rhode Island USA
Joined Aug 2010
VP |
USA, FL, Rockledge
Joined Jul 2005
Andy,
Page 31 of the DX18 manual "Camber Preset. This is only available when 2 or 4 aileron wing type is selected in Sailplane Type" Reducing power at the break in order to slow down for landing is an 'acro' type manuever. Honest, my goal is not to make this a shoe wetting contest, I am simply saying that a flight mode delay would be a welcome and usable function for sport flyers and that would make the DX18 an even better radio for the regular flyer. ![]() Howard |
| Thread Tools | |
| Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users | aeajr | Sailplane Talk | 25 | May 29, 2012 03:14 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Dec 20, 2011 05:12 PM |
| Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 | shooboy | Aircraft - General - Radio Equipment (FS/W) | 4 | Dec 14, 2011 07:30 PM |
| For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 | zaptherio | Aircraft - General - Radio Equipment (FS/W) | 1 | Nov 15, 2011 05:14 PM |
| Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition | shooboy | Aircraft - General - Radio Equipment (FS/W) | 6 | Oct 19, 2011 04:59 AM |
