Old Jun 05, 2012, 11:45 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Every time this subject comes up, it reminds me of those billboards:
"This year thousands of men will die due to stubbornness."
http://thehealthcareblog.com/blog/2011/04/20/stubborn/
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jun 05, 2012, 11:48 AM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
Originally Posted by freechip View Post
Admitting you need glasses is the first step in the right direction.
Maybe Freechip needs a prescription, but I dont. I can see the text just fine on the DX8 minus the trim displays of course.
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Jun 05, 2012, 12:04 PM
dfrazier is offline
Find More Posts by dfrazier
USA, LA, Sulphur
Joined Apr 2006
Originally Posted by AndyKunz View Post
Which way did you set up those channels? Can you attach the SPM file?
Andy
Don't have the TX near me now but will try to get a file uploaded later.
dfrazier is offline Find More Posts by dfrazier
Old Jun 05, 2012, 12:06 PM
brentrob is offline
Find More Posts by brentrob
USA, MI, Shelby Township
Joined Aug 2006
telemetry
I think that all receivers should have built in battery pack voltage telemetry and but the add on module for additional telemetry. At least that is what I am hopingfor.
brentrob is offline Find More Posts by brentrob
Old Jun 05, 2012, 12:07 PM
dfrazier is offline
USA, LA, Sulphur
Joined Apr 2006
If there only going to 29% then they are setup as trims for those channels
Thats possible. I thought I set it up correctly but I have been wrong before. I am not near my Tx right now to check but I believe in the channel assignment screen I chose the Lt and Rt digital trims as inputs.
Old Jun 05, 2012, 12:08 PM
struggleforlife is offline
Find More Posts by struggleforlife
struggleforlife's Avatar
The Netherlands, LI, Gennep
Joined Feb 2011
Edit. I shouldn t allow myself to get so worked up about it.
struggleforlife is offline Find More Posts by struggleforlife
Old Jun 05, 2012, 12:20 PM
javabeans is offline
Find More Posts by javabeans
Bedford, Mass. USA
Joined Dec 2007
I need to wear glasses to read a paperback or a PC screen at my preferred resolution. Without my glasses I can see the text on the DX-18 fine.
I like the screen resolution of the DX-18, it allows for more information being displayed and crisp text (even if it is smaller).
javabeans is offline Find More Posts by javabeans
Old Jun 05, 2012, 12:38 PM
rillo75 is offline
Find More Posts by rillo75
Italy, Emilia-Romagna, Bologna
Joined Nov 2009
me too!!!
Also because all the other manufacturers have already!
rillo75 is offline Find More Posts by rillo75
Old Jun 05, 2012, 04:32 PM
HeldderStille is offline
Find More Posts by HeldderStille
Germany, NDS, Brunswick
Joined Apr 2012
When will the DX 18 be available over here in europe?
I hope soon.
HeldderStille is offline Find More Posts by HeldderStille
Old Jun 05, 2012, 07:23 PM
Kam Arrow is offline
Find More Posts by Kam Arrow
Citizen #302
USA, OR, Canby
Joined Oct 2007
Originally Posted by ncarbon View Post
Can some one measure the base of the radio to antenna tip.....I have a case I want to fit it in. Thank you!
Ned
Did you ever get an answer? I searched and could not find, I also would like to know if it will fit in the case I have (it is 12 1/2 inches inside)
Bill
Kam Arrow is offline Find More Posts by Kam Arrow
Old Jun 05, 2012, 08:06 PM
Snowflake6515 is offline
Find More Posts by Snowflake6515
Michael
United States, ME, Wells
Joined May 2008
I just measured mine and it is 11 3/4" standing on my bench with a ruler measuring base to top of antenna.
Michael
Bill
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Jun 05, 2012, 08:30 PM
dfrazier is offline
USA, LA, Sulphur
Joined Apr 2006
Originally Posted by dfrazier View Post
I did find 1 small issue. I set up the L and R digital trims as auxiliary channels to be used as gain channels for my DJI NAZA flight controller and on the monitor screen the values only go to 29% both ways. I ended up solving the problem but I had to set the travel limits to 150% and also setting up a gear/gear p.mix with the values maxed out. I can now get 99% in both directions on both channels.
Andy and Freechip.
I figured out the problem with the L trim and R trim Issue. It was my fault. I assigned the channel inputs to LTrD and and RTrD. I did not scroll far enough to see there was a LTrA and RTrA. I changed the inputs to these, disabled the mixes and reset the endpoints to 100 on both ends and it now goes to 100% both ways.
Old Jun 05, 2012, 10:21 PM
Citizen #302
USA, OR, Canby
Joined Oct 2007
Michael
Thank you
Bill
Old Jun 06, 2012, 12:30 AM
parky is offline
Find More Posts by parky
San Jose, CA USA
Joined Oct 1999
Originally Posted by aeajr View Post
So I would guess it is the glow/gas and maybe Jet pilots that care about analog or digital on the "throttle" stick.
I do electric and also turbines. Like you, I never touch throttle trim on electrics.
On a turbine, the ones I have used are set for idle at high trim and engine kill at low trim, so analog is nice for that... BUT AMA regs require a kill switch anyway, and it should be accessible in flight by your caller. (shutting down the engine before a crash GREATLY reduces the chance of fire.. even 1 second makes a huge difference.) So, I just set high trim, and leave it there and use the kill switch. So, digital vs analog just does not matter to me.
parky is offline Find More Posts by parky
Old Jun 06, 2012, 01:46 AM
stanh2 is offline
Find More Posts by stanh2
South Africa, KZN, Durban
Joined Apr 2012
Select another switch then come back to I and see if that resolves it.
Andy
Hi Andy, thanks for the support. I solved my problem, switch was fine but I had forgotten that the black check boxes mean “selected”, so I inadvertently “unselected” all the control functions of the slave unit.Rectified this.
What I am noticing now is that there is a jump in trim between the master and slave in Pilot Link mode when buttion I is pressed/released.
stanh2 is offline Find More Posts by stanh2
Discussion Spektrum DSM2 and the Nats - Question for Spektrum/JR users aeajr Sailplane Talk 25 May 29, 2012 03:14 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 6 Dec 20, 2011 05:12 PM
Sold Spektrum DX6 6-channel System with Spektrum AR6000 Receiver $50 shooboy Aircraft - General - Radio Equipment (FS/W) 4 Dec 14, 2011 07:30 PM
For Sale Spektrum & JR 2.4 Ghz DSM2 receivers for sale I have a sailplane sized Spektrum AR93 zaptherio Aircraft - General - Radio Equipment (FS/W) 1 Nov 15, 2011 05:14 PM
Sold SPEKTRUM DX6i DSMX with Spektrum Ni-cads and charger- like new condition shooboy Aircraft - General - Radio Equipment (FS/W) 6 Oct 19, 2011 04:59 AM
