Old Feb 01, 2012, 04:49 AM
rangamatchstic is offline
Find More Posts by rangamatchstic
Mt helena western australia
Joined May 2009
school project
My goal is to make a plane retreivial system that turns on when the receiver loses power or signal and it uses gyros to level out an rc plane then turn it 180 degrees in a gentle slow turning bank aswell as turn, then it has to fly level after the turn, fly for about a quarter of the total time you have been flying for then slow down until it stall s and deploy a parachute. My only problem im going to have (i have looked into all the other components and found ways to do them using components available to me) is i want a single signal wire to be attached to the servo signal wire at all times to control the servos when the planes receiver loses signal. What i am wondering about is A. will the receiver lock the servos in place if it losses signal and can you change this setting if so, and B will the receiver be ok when a signal is given to the servo on the same wire ie will this short the receiver out.
rangamatchstic is offline Find More Posts by rangamatchstic
Old Feb 01, 2012, 05:05 AM
srnet is offline
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Depends on the actual receiver, there are several different behaviours here.
You cant directly connect two outputs together, which is what you are suggesting. Extra components are needed to, in effect, turn off the receiver output.
srnet is offline Find More Posts by srnet
Old Feb 01, 2012, 05:09 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Its the wings that make the plane turn so the plane will have to bank over.
Old Feb 01, 2012, 05:43 AM
Joined May 2009
The receiver i will be using is a turnigy 9x
im not connecting the power will only be provided to the servos by the circuit if the receiver losses power and i am thinking that the receiver will already have a diode to prevent damage if you plug a battery in the wrong way around.
Old Feb 01, 2012, 05:49 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Used to be an electronic black box in the UK about the 70's that on loss of signal centralised the servos and cut the throttle to half. A later system deployed a parachute to float it down.
Possibly Roy Lever, I think he made and sold the system commercially, - nothing new under the sun.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Feb 01, 2012, 05:58 AM
Joined May 2009
meh, still want to have a go at it.
Also what component could i use on the two outputs? i was thinking of a diode but that drops the voltage by 0.6v and the analogue servos work on a voltage reading =/.
Also i know plane have to bank to turn, i used to fly and rc nitro plane and park flyers but now fly helis and drive cars.
Old Feb 01, 2012, 06:06 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Suggest you also browse this forum:
http://www.rcgroups.com/uav-unmanned...-vehicles-238/
..a
Old Feb 01, 2012, 06:24 AM
Joined May 2009
stuff it just work it out myself i guess =P
Old Feb 01, 2012, 06:27 AM
Joined May 2009
ill just use a lot of mechanical switches activated by a servo on the fail safe that will turn change the control to the seperate circuit board, probably activated by the same circuit ill use to get the seperate circuit board going
Old Feb 01, 2012, 07:31 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
If you think analogue servos are controlled by varying voltages this is going to take you A LOT of working out. Hint - the servo control is a varying pulse time NOT a voltage level.
Steve
slipstick is offline Find More Posts by slipstick
Old Feb 01, 2012, 09:50 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Perhaps a silly question, but the '......it uses gyros to level out an rc plane then turn it 180 degrees in a gentle slow turning bank aswell as turn,.....'
What if it isn't flying directly away from the pilot when the system takes over ?
eflightray is offline Find More Posts by eflightray
Old Feb 01, 2012, 11:56 AM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Indeed.
And why let it glide for a 1/4 of the flight time ?
If you flying fairly close in, then the plane is more likley to be further away when the parachute is deployed.
I would think that even limited return home functionality would require a GPS ........
Old Feb 01, 2012, 03:23 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
OK for an academic exercise, but why a parachute? If you lose radio contact, it is most likely because you flew out of range. If you flew out of range then a simple 180 would most likely get you back in range.
Also, if your receiver batterys fail, the servos would not function. If using a separate battery for the servos, that is the one most likely to fail since the servo's have high current drain compared to the receiver which has very little current drain.
jeffs555 is offline Find More Posts by jeffs555
Old Feb 01, 2012, 03:35 PM
Kiku0 is offline
Find More Posts by Kiku0
Estonia
Joined Nov 2011
How about a compass and gyros on 2 axis (one to bank, other to keep the pitch). When the signal is lost for x seconds it starts to turn until the heading is 180 degrees different. If the signal isn't restored in y seconds after the first turn, it will do an full circle, the process will be repeated till the signal is restored. If you put it on a slow turn and the plane is in visual range, you will ultimately get the plane back, even if it involves some running towards the plane
Kiku0 is offline Find More Posts by Kiku0
Old Feb 01, 2012, 03:41 PM
srnet is offline
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
I guess it possible, with poor RC gear, but then why use poor RC gear in the first place.
The only crashes that I have experienced, apart from those induced by the idiot behind the sticks, were power or mechanical failures. Loose wires, switches, plugs and the like plus a couple of Lipo failures.
Going out of range, nope, I have difficulty flying a model when its half a mile away anyway.
Build Log School Boat Project at 150% P. Tritle Scale Boats 28 Jan 08, 2013 02:08 AM
Discussion High School Multi Rotor Project (For My Students) Buzz_Man Multirotor Talk 23 Dec 04, 2011 05:08 AM
Discussion Please help me out with some questions I'm asking for a school project! Thanks! Piece Electric Plane Talk 38 Apr 07, 2011 08:32 PM
Help! Please help me out with some questions i'm asking for a school project! Thanks!! bd18z3 Life, The Universe, and Politics 177 Apr 04, 2011 11:03 PM
Discussion Electrical expertise needed for building a small generator (school project? get dustd Chit Chat 1 Mar 08, 2011 07:39 AM
