Old Feb 12, 2013, 01:44 PM
Plane Chaos is offline
Find More Posts by Plane Chaos
Joined Dec 2009
Originally Posted by quitcherbitchen View Post
Well, mine fell off the bench today. Broke the wing tip off and kind of crushed the end. Now I am going to modify it to a shorter wingspan AM6-3 HAMP. model 23. I also notice my motor making a clicking noise so I took off the cowl . Still clicked. Disassembled the motor and everything check out OK. It still clicks a very tiny bit. Weird.
Sorry to hear that qb.
... keep us posted on your clipped-wing version.
Does the motor-click arise at a specific point in its roation ?
Plane Chaos is offline Find More Posts by Plane Chaos
Old Feb 12, 2013, 02:27 PM
FLOEY is offline
Find More Posts by FLOEY
Norway
Joined Dec 2007
Dip the wing and broken parts in hot water (close to boiling).
Reglue with (Gorilla glue or other polyurethan glue) remember to
moist with water (spray gun). AND don't forget to lock the parts
with needles or similar, the glue EXPANDS like foam.
Watch the process (read RCG :-) ) and clean off expanded foam.
When it's dry (take a couple of hours) carefully sand of and repaint.
(Acrylic paint, water based paint works very well, mix yourself)
I've broken wing fuselages etc. No problem just pick up all parts
and do as above. I'm no good at painting (too unpatient) so my
planes got scars ... but it's worth it. Some of my best planes
today has been repaired from severe crashes.
Beware the plane gets heavier for each repair ...
FLOEY is offline Find More Posts by FLOEY
Old Feb 12, 2013, 06:41 PM
quitcherbitchen is offline
Find More Posts by quitcherbitchen
Chop it, cut it, bash it
quitcherbitchen's Avatar
United States, CA, La Caņada Flintridge
Joined Jul 2011
Thanks for the pointers guys. I have been planning to cut the wing tips off for awhile. I damaged the tip about 1 centimeter broke off. I did the scale calculation and to make a "Hamp" I need to cut 2.7 centimeters off each end which lines up perfectly with the panel line for the folding wing tip.
The motor makes a click once a rotation, but I completely went through the motor and everything looks straight and no broken magnets. I blew the motor out with an air gun and lubed it and the click is less pronounced, but still there. I ran it up to full power and can't tell what is doing it. None of my other models have a noise manually rotating the prop. I thought for sure a magnet must have broke, but they all look even and are on tight. I guess just fly it.
quitcherbitchen is offline Find More Posts by quitcherbitchen
Old Feb 12, 2013, 09:39 PM
Joined Jul 2011
Well, the surgery went super fast and here is the AM6-3 model 23 Hamp. It will be interesting to see if it is faster and more maneuverable then stock. Stock is no slouch.
Old Feb 13, 2013, 03:35 PM
Joined Jul 2011
So I flew a battery thru at lunch. Broke the firewall on landing--AGAIN. Honestly, can't tell if the clip wing helped the speed, but it didn't hurt any. Felt like the same old bird. I have over a hundred flights on the normal wing so I think I would be able tell. Roll rate was the same. I flew in a very narrow baseball diamond so I couldn't float it around low, but at altitude it seem to be fine without any tip stall. My problem is this thing got even smaller in the air now with the wing clipped 30 centimeters.
Old Feb 13, 2013, 04:49 PM
Joined Dec 2009
... interesting qb,
I was anticipating the effectively increased wing-loading was going to make her real 'bitchen' to handle ..
Old Feb 13, 2013, 05:13 PM
Joined Jul 2011
Nope, docile as can be. If I fly it this weekend at my normal spot I can give a better evaluation.
Old Feb 16, 2013, 10:29 AM
Joined Jul 2011
The ailerons just looked too weird and not Hamp like so I trimmed them this morning and am very pleased with the results.
Old Feb 19, 2013, 12:14 AM
Joined Jul 2011
Flew four batteries through the "Hamp" today and honestly no bad habits. Flies great. Tried a GWS 8x3.8 prop and what a dog. I know Floey recommended it, but did I get something wrong. Mine still has a Stock 300 motor. Climb was slightly better then stock, but everything else was horrible. I also notice that my bearings after 100+ flights are slightly loose and that is where the ticking noise comes from.
Old Feb 19, 2013, 03:16 PM
FLOEY is offline
Norway
Joined Dec 2007
I use GWS 3 blade 8040 (Spitfire and Bf.109) they fly faster with 2 blade 8x4SF props.
On my Corsair F4U I use Haoye 2 blade 8x4 and it's pretty fast (non stock BL motor and 3S LiPo)
If You go for speed 2 blade 7x6 or 8x6 would do the trick. I believe but You get
less acceleration and climb with more pitch.
Old Feb 19, 2013, 03:28 PM
Joined Dec 2009
.. wing profiles look good qb.
I'll keep that in mind if I ever end up damaging my wing tips.
Have been lucky so far
... only slight wear is on the front-lower edge of the air-intake bulge, which is standing up prety well (since I reinforeced it internally with a close fitting blu-foam filler-piece on day one).
Joined Jul 2011
I am flying 2s stock motor. I'm going to stick to stock seems pretty good. I also think that the spinner can cause a harmonic vibration that wears out the bearings prematurely. My motor bearings are no longer tight or pressed into the motor. They will fall out if I remove the collet.
Old Feb 20, 2013, 04:49 AM
FLOEY is offline
Norway
Joined Dec 2007
I am flying 2s stock motor. ...
I use 3S 450mah minimum on fighter planes 25" else they fly like trainers
(or dogs if You like ). Exception my light P-40 who does not like the added
weight (I got two small 3S 350mah who fits for windy days)
Replace bearings, realively easy job requires some proper tools.
When that is done and motor are installed and runs properly again,
balance propeller with spinner on.
This is tricky ... patience VERY MUCH required ... I know!
Some thimes I've given up and flown without spinner for a while
until I've managed to get it done properly (my view).
I've never got it 100% because of (long list ...) but I balance
until vibrations and propeller sound are "minimal".
("minimal" = patience and time used up )
It would be preferable to balance the prop. spinner and motor bell
together without the static part of the motor. Then it would be possible
to get a 99,9% balanced system (I believe). I've not tried this ...
Old Feb 22, 2013, 12:07 AM
Brian2fly is offline
Find More Posts by Brian2fly
Joined Oct 2012
I lost my Zero last weekend. I was flying and then the plane stopped responding. CRASH! The aileron linkages were rubbing the receiver and pulled out one of the wires leading from the JST adapter to the receiver. Two weeks earlier I replaced the JST adapter because the aileron linkages cut through one of the wires. I should have relocated the receiver after the first time.
Disappointing, but I am optimistic that Horizon Hobby will give me a replacement. It seems like this is a known issue with this plane and lots of people have experienced this.
Has anyone else experienced this situation before? Did HH send a replacement?
Brian2fly is offline Find More Posts by Brian2fly
Old Feb 22, 2013, 01:08 AM
fusionsx00 is offline
Find More Posts by fusionsx00
United States, AZ, Mesa
Joined Sep 2010
i moved mine before it crashed, but i saw the wires were chafed.
i also clipped the sharp ends of the screws off.
fusionsx00 is offline Find More Posts by fusionsx00
Sold E-Flite P-40 warhawk 300 BNF Propnutz Aircraft - Electric - Airplanes (FS/W) 6 Dec 18, 2011 01:23 PM
Wanted UMX Extra 300 3D BNF by E-flite RD Gator Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 6 Dec 11, 2011 08:48 PM
Sold E-Flite umx extra 300 Bnf ian145 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Nov 14, 2011 04:18 PM
Sold E-Flite Ultimate 20-300 Bi Plane $220 Shipped BNF w/ everything perschek Aircraft - Electric - Airplanes (FS/W) 1 Nov 07, 2011 12:42 PM
Sold E-Flite UMX Extra 300 3D BNF - [$125] obo uberjay Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Oct 11, 2011 10:45 PM
