Old Dec 02, 2012, 09:35 PM
FLB is offline
FLB
Find More Posts by FLB
FLB
FLB's Avatar
Montreal-Toulouse
Joined Jul 2002
After all those videos, for the ones who never see Ray Hanna and his spitfire flying under a stone bridge (1988) ...
Video:
Spitfire under bridge (0 min 19 sec)
Or picture below.
FLB is offline Find More Posts by FLB
Old Dec 02, 2012, 10:41 PM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
Not a Spit, but a great flyover.
http://www.youtube.com/watch?NR=1&v=...0&feature=fvwp
Rn
A Rdnek is offline Find More Posts by A Rdnek
Old Dec 03, 2012, 07:06 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
B-1 flyover at UVA's Scott Stadium. (UVA beat Miami 41-40)
Video (30 seconds) taken on 11/10/12 by RCG member dlt2859.
http://www.facebook.com/photo.php?v=...type=3&theater
pugsam is offline Find More Posts by pugsam
Old Dec 05, 2012, 03:07 AM
Jerka is offline
Find More Posts by Jerka
Joined Aug 2008
Nice videos but lets get back to the UM Spitfire shall we?
What type of performance will you get when changing the standard motor to a Bravo SX motor and use high quality batteries? Is it worth the effort to do the swap?
I fly the UM P-51 with a nice performing standard motor (changed motor once), how would you say that a UM Spitfire with Bravo SX motor compares to a UM P-51 with a good performing standard motor?
Jerka is offline Find More Posts by Jerka
Old Dec 05, 2012, 11:05 AM
Oatmeal Savage is offline
Find More Posts by Oatmeal Savage
TripleThreatRC
Oatmeal Savage's Avatar
Canada, BC, Langley
Joined Mar 2010
Originally Posted by FLB View Post
Really nice demonstration and good pilot. I still don't know how to do rolling circle ... Did you do some modifications on your plane?
No, the plane was new out of the box. Just had to trim the elevator and it was good to go.
Oatmeal Savage is offline Find More Posts by Oatmeal Savage
Old Dec 05, 2012, 11:39 AM
valiantGLX is online now
Find More Posts by valiantGLX
Technomancer
valiantGLX's Avatar
Australia, SA, Burra
Joined Sep 2011
With the Bravo SX motor alone you should achieve a 25%-30% increase in static thrust. With the addition of a good battery you should get even more thrust again + longer flight times depending on the battery.
I dont own a Spitfire, but I am well read on the subject and aerodynamic principals aswell, so I can make a theoretical educated guess on the comparisons of the 2 platforms. However by all means dont take my words as gospel.
As the Spitfires heavier, it may nearly cancel out the added performance of the SX motor, but in saying that it should still slightly out perform a stock P-51 in vertical flight. Also as the Spitfire is heavier the stall speed will be a little higher, and landings will need to be attempted at a higher speed, but on the plus side the added weight should help to pierce the wind.
The spitfire has a better quality aileron servo, and I believe it is a long throw servo too, so rolls should be a bit more snappier when compared to the P-51.
The biggest difference is in the AS3X technology, making the Spitfire more stable with better flying characteristics in the wind.
If you got the money Id suggest building a P-51 out of replacement parts and kitting it out with the Spitfire electronics. This way you get the best of both worlds on a platform that takes better to upgrades. For example the spitfire battery sits right up the front in a specifically designed battery compartment, so not only is it harder to fit larger better quality batteries, it also greatly impacts the CG.
If you choose to build a P-51 out of replacement parts and kitt it out with the Spitfire electronics you can place everything exactly where you want it to achieve your desired CG with a larger better quality battery (currently in my mustang I have a 260mah 35-70c 1s nanotech battery that allows me to fly for 10 - 15 mins). During the coming winter months Im going to do the above mentioned and create a home brewed P-51 Mustang V2
EDIT:
Mustang
Weight: 34.6g
Wingspan: 401mm
Spitfire
Weight: 46.8g
Wingspan: 403mm
Thats a 12g difference on just about the same wingspan In addition the Spitfire wings look to have a skinnier chord adding to the wing loading too (if anyone has both planes please chime in with the actual chord measurements)
The above info only adds to my lust of creating a 'franken-stang', combining the p-51 airframe with the spitfire electronics
valiantGLX is online now Find More Posts by valiantGLX
Old Dec 05, 2012, 01:30 PM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
Maidened my spit the other day. Damn it looks awesome swooping in on a wide turn! I had an elevator issue with it - has anyone else experienced a delay in response when launching it? I tossed it out and i thought it was going to plow into the ground when finally it nosed up and gained some altitude - then it was fine. Did this twice. Are there any other reports of taking a split second to respond to radio commands?
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Dec 05, 2012, 01:38 PM
coreman is offline
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
airspeed maybe? Do you launch with your left or right hand?
coreman is offline Find More Posts by coreman
Old Dec 05, 2012, 03:03 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
right hand, and i'm right handed. I tossed it a good ways - it was probably 20 yards away from me, she has a pretty good glide for a little thing, and i had been on the sticks pulling up for (i would guess) around a second before it snapped up and from then it was fine. Odd behavior and I thought it a one-off until I brought it in for a landing and tried a second launch. I'll try again throwing it harder and see if that helps resolve it. Also as I'm writing this I'll check again for binding on the control rod, although they were free and working fine in preflight checks.
Old Dec 05, 2012, 03:43 PM
cmdl is online now
Find More Posts by cmdl
http://www.sgvhumane.org/
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
no, but i have the LG off now. i put half throttle and it plowed to the ground. i put full throttle and she was fine. no response delay though but i always have problems getting it to recognize the tx just before i start my flights. even with it held at a distance it sometimes refuses. gets annoying.
cmdl is online now Find More Posts by cmdl
Old Dec 05, 2012, 08:16 PM
Tarifn is offline
Find More Posts by Tarifn
Joined Nov 2012
Motor cuts out/stutters during flight why?
When flying my spit fire the motor will rapidly cut out on and off or as if it is pulsing or stuttering.
Does anybody know what might be causing this problem and have a solution?
I am using a hobby zone DSM2 transmitter that came with my champ?
The spit fire has no major crash damage.
My LHS was unable to duplicate this problem in the shop and had no clue?
Tarifn is offline Find More Posts by Tarifn
Old Dec 05, 2012, 08:37 PM
dbdukeboy is offline
Find More Posts by dbdukeboy
Newbe learning everyday!
dbdukeboy's Avatar
United States, OH, Parma Heights
Joined Aug 2012
You might need a better battery. I find that anything under 25c just doesn't cut it with the spit or even my t-28 with AS3X. Especially at full throttle.Im going to try some hyperions from rc babbell as soon as I get a few extra bucks. It's hard competing with Santa this time of year.
dbdukeboy is offline Find More Posts by dbdukeboy
Old Dec 05, 2012, 08:52 PM
TripleThreatRC
Canada, BC, Langley
Joined Mar 2010
+1 on the battery being the cause.
Old Dec 05, 2012, 08:59 PM
coreman is offline
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
yeah, sounds like you are hitting LVC. Are these "previously used" batteries? I had some Nanotech 160s from last year and they weren't good enough even though they fly the other stuff I have. but they also have been flown every week for probably 20 weeks last indoor season. I would expect new nanotechs would be fine. it really likes the Mini Aviation 190s I bought but they are brand new
Old Dec 05, 2012, 11:19 PM
Silverexpress is offline
Find More Posts by Silverexpress
Your customer
Silverexpress's Avatar
United States, MI, Berkley
Joined Dec 2009
Are you by any chance flying in freezing temps < 50 deg F (10 deg C)?
These 1 cell li-pos do not work too well in those types of temps.
Silverexpress is offline Find More Posts by Silverexpress
New Product E-flite UMX MiG 15 Ducted Fan Jet with AS3X Bowerz Micro Ready-to-Fly 186 Apr 13, 2016 10:12 AM
Article Horizon Hobby Blade mQX Micro Quad-Copter with AS3X RTF & BNF Review Michael Heer Multirotor Talk 32 Jan 30, 2016 06:51 PM
New Product E-Flite UMX Mig 15 with AS3X! Bowerz Scratchbuilt Indoor and Micro Models 4 Jan 16, 2012 07:02 PM
Discussion UMX S-Bach or Beast 3d (with AS3X)? The Spirit 3D Foamies 6 Jan 07, 2012 05:41 AM
Sold Eflite UMX Beast 3D BNF with AS3X Technology baddb1 Aircraft - Electric - Airplanes (FS/W) 3 Dec 19, 2011 05:42 AM
