Old Oct 10, 2012, 02:47 PM
when down=up, up=expensive
whichwaysup's Avatar
United States, VA, Roanoke
Joined Apr 2012
Could be wrong here, but I believe you'll have to open it up if you want to adjust it mechanically - before you do that, triple check that you've centered your trims, that you've initialized the Gyro the proper way, and that there is nothing else that you can do to avoid opening it!
Once opened, you'll have to adjust the pushrod that goes to the bellcrank. I can't remember from the Mustang and T 28 if there is a bend that will allow you to shorten/lengthen it, but i seem to remember that there is one.
whichwaysup is offline Find More Posts by whichwaysup
Old Oct 10, 2012, 04:31 PM
Joined Oct 2012
Originally Posted by mump View Post
Hi all,
last weekend I had the maiden flight with my UMX spitfire (got it from a local dealer, although it seems to be unavailable everywhere else in Germany...)
My spitfire always turns to the left, and the right aileron is hanging a bit.
Has anyone a good tip how to adjust mechanically the aierons to a central position?
Many thanks in advance!
mine did the same thing. i used the trim on my dx6i and now it flies like a charm btw. there are some spits on ebay.de. i couldnt find any local dealer who had it in germany so i got it from ebay.
masterfgee is offline Find More Posts by masterfgee
Old Oct 10, 2012, 05:00 PM
Joined Jun 2008
C G issues.....
OK, so I slapped my battery in and Maiden-ed this little guy. I could tell it was pretty tail heavy from the start. I input some down trim and this helped a little, but not near enough....Out of a turn it just wanted to climb and climb and climb.....It did handle the 5 - 8 mph wind pretty well.....So, I brought it in and decided to try it with the landing gear on. The gear is a little forward of the specified CG. Same issue...flew it for a while still trying to get a good feel. I had a fairly slow speed power-off crash into the ground. Absolutely no ding on the spinner, but it broke the left wing off in half!
So, I CAed it back on and looks OK.. So I decided to check my CG, and sure enough, it balances back on around 25-26 mm back from the leading edge. Not sure why so peoples fly OK. Like some others, any of you that have had your plane fly great right out of the box.....would really like to know what your CG is at!
aclinml is offline Find More Posts by aclinml
Old Oct 10, 2012, 05:38 PM
Joined Oct 2012
my CG is pretty much where it is shown in the manual. maybe a few mm towards the tail but not much (with battery and LG).
Old Oct 10, 2012, 06:43 PM
brushless55's Avatar
United States, CO, Boulder
Joined Nov 2011
Originally Posted by airpower View Post
Sorry!! Thought you meant battery, sorry, i have trouble with reading.
that's awesome bro!
I thought I got a quick reply and was like
brushless55 is offline Find More Posts by brushless55
Old Oct 10, 2012, 07:19 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The AS3X should allow for aft CG. Is it climbing power on but nosing over when gliding?
UNGN is offline Find More Posts by UNGN
Latest blog entry: AR6400 guillows Space Shuttle
Old Oct 10, 2012, 09:18 PM
Joined Jun 2008
Not nosing over at all...just pointing up with power on all the time....
Old Oct 10, 2012, 09:20 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
If its still glides flat, trim with down elevator to reduce the climb under power.
Old Oct 10, 2012, 10:06 PM
United States, NC, Charlotte
Joined Jan 2007
Flew a battery through CC before flying Spit. 7-10 MPH breeze to get good comparison.
CC flies fine a 1/2 throttle, Spit needs full throttle most of the time.
CC is over powered Spit is fine but could use a tad more for fighting wind.
Spit is still fun to fly just need to work a bit harder on sticks.
Tim
w4yn is offline Find More Posts by w4yn
Old Oct 11, 2012, 01:36 AM
"Kneel before Zod!"
turbovector's Avatar
Tacoma, WA. USA
Joined Dec 2003
Originally Posted by IndyMatt View Post
Thanks! Once it is here I will open her up and stick the new motor in. Hopefully get a flight report with the new motor before this next weekend. I need to get more of the newer Parkzone batteries as my older hyperions are triggering LVC way early.
Anxiously awaiting the new motor flight report.......
turbovector is offline Find More Posts by turbovector
Old Oct 11, 2012, 06:00 AM
Indianapolis, IN
Joined Oct 2010
Hoping it comes in today, If it does I can get it put in the bird and probably fly tomorrow night.
Any plane with climb going into a headwind, the extra wind speed over the wind generates more lift. This plane is a blast! I flew three batteries last night in some wind above 10mph with gusts above that. I will say to get this bird turned RUDDER is a must in this much wind. Tipping the wings with ailerons will allow the wind to push the bird over.
Easily my favorite 1S plane to date.
IndyMatt is offline Find More Posts by IndyMatt
Old Oct 11, 2012, 07:00 AM
Joined Aug 2012
1 s as3x ?
So after a week of dozens of great Spitfire flights I got to thinking...
How would the 1 S AS3X brick do in my Champ???
I removed the brick from the Spit.
Installed it in my Champ.
Checked the controll surfaces. (had to reverse the rubber)
Everything was set to go...so I thought.
I armed the ESC and checked the function of the AS3X and much to my surprise the gyro was reverse of what it should be.
In the Spit the brick is mounted on it's side, in the Champ I laid it down.
So the question is.
Is the AS3X system programed for how the board will be oriented in the plane???
BumpierDrake960 is offline Find More Posts by BumpierDrake960
Old Oct 11, 2012, 07:13 AM
Joined Jan 2007
So the question is.
Look at the instructions for the USB AS3X programmer, orientation does matter.
Tim
Old Oct 11, 2012, 07:36 AM
51st Shade of Grey
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Yes!
You will need a programing cable to set it up properly...
Easiest thing to do is to mount it as per the Spitfire. Have it vertical and swap the pushrod to the other side of the rudder. Reversing it could result in backwards AS3X commands...
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Maybe my fleet is too big...
Joined Aug 2012
Good thinking.
Thanks Tim
New Product E-flite UMX MiG 15 Ducted Fan Jet with AS3X Bowerz Micro RTF 137 May 17, 2013 06:59 PM
Article Horizon Hobby Blade mQX Micro Quad-Copter with AS3X RTF & BNF Review Michael Heer Multirotor Talk 30 Feb 22, 2013 08:47 AM
New Product E-Flite UMX Mig 15 with AS3X! Bowerz Indoor and Micro Models 4 Jan 16, 2012 07:02 PM
Discussion UMX S-Bach or Beast 3d (with AS3X)? The Spirit 3D Foamies 6 Jan 07, 2012 05:41 AM
Sold Eflite UMX Beast 3D BNF with AS3X Technology baddb1 Aircraft - Electric - Airplanes (FS/W) 3 Dec 19, 2011 05:42 AM
