You press the roller and release and it goes to "adjust list", If you press for >2sec and release it shortcuts to setup list, This is not necessary as you can just click it then scroll the last item on adjust list and click which takes you to setup list. second, The CC flies just fine indoors, even in small gyms, I fly mine in a single basketball court gym. There are many videos that show how slow and small of an area the CC can fly in. -Brian |
![]() First off - be sure that the plane is mechanically trimmed correctly, and be sure that it is not nose-heavy. (A 1-2mm shift in CG is very noticeable at this scale.) Use elevator to manage airspeed & use throttle to manage altitude. Use primarily rudder in the turns when flying slow, and be very gentle on the ailerons & elevator. (Of course, that's simply a given with most any plane.) See my CC handling checklist for details on proper trimming & balancing, along with tips on flying slow & flying with the flaps extended. Joel |
United States, MN, Minnetonka
Joined Feb 2013
-Brian |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Australia, QLD, Brisbane
Joined Aug 2012
Hello all,
I bought myself a CC today and well... I am very happy with how it looks and its scale but there was a very slight angle (i.e. not 90deg to the fuse on either side) in the vertical stab/rudder - it seems as if it has not been installed on the fuselage properly. Now I already own 2 UMX and 1 UMX heli so I am used to flying these things, and my corsair did for a while have issues with the rudder not tracking straight but I eventually ironed that out by about an hour of tweaking back and forth with the U bend. With the CC it seems that as I said it wasn't mated quite right onto the fuse - is there any reason why I cannot just straighten it by manipulating the joint/reinforcing with CA or is it meant to have some sort of deflection? I would assume not but I have seen planes with some sort of angle on the vertical stabilizer/rudder to counteract torque/p-factor so I am not sure if this intentional or not. Otherwise I am sure this bird will fly nicely, just waiting for the wind to bugger off first . I also did not realise it had lights which kind of took me by surprise when I first powered it up. Hehe.EDIT: OH and I also got some floats... really not sure if I will be using those too soon, and I'm guessing mine must be the newer version since it has the hole in the cockpit windscreen? |
Using the DX8 with the CC
I'm not sure if this has been covered by other posts so I'll post it here anyway.
The CC comes with the AR6400 set so that CH 6 is slaved off Ch 2(Aileron) to cater for people using DX4/5 Tx's. The AR 6400 can be reprogrammed so that Ch2 and Ch 6 operate independantly. This allows you to use the Tx to mix the two channels together using the 2 aileron servo wing mix. BIW. |
I get 7 min on 180mAh and 9+ on 240s. Quote:
Most importantly AS3X does NOT work on both aileron channels if you set the ch6 to not function as an internal "y"! The model will fly extremely poorly. Second the ESCs rating was increased from 4.9 to 5.9 amps Botton line DO NOT DO THIS!!! -Brian |
Using throttle-management & flying the plane like a Super Cub, I get 15+ minutes to the 80% discharge point with my TP 325 65c packs & 10+ minutes with my Hyp 240s. Joel |
Thanks Turbo. So this has to be done with a digital charger I assume since there is no way I can see what the battery is discharged to otherwise. Can you recommend a charger that doesn't need a separate power supply and is reasonably priced?
I might head to Hobbbytown USA today and see if they have some 325 packs in stock. |
Link The Multi4 runs on 12volts so a car battery is perfect. It also has adjustable charge rate or auto 1C,2C,or 3C rate charge. It is pretty much foolproof. It autodetects #of cells, and even can tell if the wrong chemistry is selected! Just be sure to get the right balance board as it charges through the balance taps. -Brian |
You're welcome! I'm always happy to help. As Brian mentioned - the Multi4 is an excellent charger. Revolextrix chargers are well-engineered, very well-built, extremely accurate, and reliable. They also sell a compact, lightweight 12V supply that will run it at home. There are many other low-cost 12V supplies that also work well. If you're set on a charger with built-in AC, I suggest the Thunder Power 610 AC/DC. It's also a well-engineered, well-built, extremely accurate & reliable charger. It comes with a balance-board that has Thunder Power balance connectors as well as the JST-XH balance connectors found on many other brand batteries from Align, Dynamite, E-flite, ParkZone and others. To charge the UMX packs, just pick up a UMX charge harness from RCbabbel, Glenn at RC-connectors, or HH. I highly recommend RCbabbel, as his workmanship and customer service are second-to-none. In fact, exemplary is a barely adequate description. While you're at it, check out his custom ultralight Hyperion & Thunder Power UMX packs. They're the highest-performing, longest-lasting, lightest-weight UMX packs available.If you plan to expand your electric fleet to include larger aircraft that use 2000 mAh or larger 3-4s packs, I suggest that you pick up a decent high-current charger so that you can take advantage of the fast charge rating (5c up to 12c) of most modern, high-quality LiPos. The chargers above will charge those packs, but it will take a long time, due to the chargers' low wattage limit. Joel |
| Thread Tools | |
| New Product E-Flite UMX Carbon Cub SS | fragje | Micro RTF | 7160 | Today 05:27 AM |
| Sold E-Flite UMX MIcro Extra 300 3D | aviation421 | Aircraft - Electric - Micro & Indoor Airplanes | 1 | Dec 12, 2011 02:27 PM |
| Sold E-Flite UMX Micro beast NIB (BNF model)+ 3 extra batteries $150 shipped. | RCGill | Aircraft - Electric - Micro & Indoor Airplanes | 4 | Apr 04, 2011 11:31 AM |
| Sold E-Flite UMX Micro beast NIB (BNF model) + 3 extra batteries $150 shipped | RCGill | Aircraft - Electric - Airplanes (FS/W) | 3 | Apr 04, 2011 11:30 AM |
| Sold E-Flite UMX Micro Beast BNF | EasyEP | Aircraft - Electric - Micro & Indoor Airplanes | 9 | Feb 17, 2011 07:28 PM |
