Old Feb 07, 2012, 10:16 AM
DaveG is offline
Find More Posts by DaveG
DaveG's Avatar
Houston, TX, US
Joined Jun 2000
Originally Posted by PeteSchug View Post
Pale Male. He resides in the high rent district on the upper east side of Manhattan. He does urban soaring almost every day. This shot taken with a 500 mm zoom on my Nikon D90.
Pete
That's neat. Sorry, no photos here, but I was at a local park yesterday on lunch break, watching some gulls riding thermals over some soccer fields. They weren't very high in the sky and I kept thinking it was perfect conditions for the ASK-21. The area was just the right size for quickly setting-up the hi start and launching away.
DaveG is offline Find More Posts by DaveG
Old Feb 07, 2012, 11:10 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Seems like this one would be a great candidate for piggbacking to altitude . Sure would not take a very large or powerful electric plane to hoist it .my 52" WS GP Electro Stik would not even know it has a hitch hiker on it. My past experience piggbacking is a lot easier / safer than towing but them I never claimed to be a master of towing either. I know a lot of tug and glider pilots make it look easy.
Now if the ASK-21 glider had on board GPS so it would circle over the release point so that one pilot to take it aloft,land the powered plane and then fly the glider ,what a wonderful it would be.
I know I spend way to much time flying all by myself. I have a great flying site with covered pit area,4 AMA type safety benches, picnic table lots of open area(hay field) to fly over and rarely does anyone else come to the field. Best part is that it is only 6 miles and 10 minutes from my house. Worse part is that I am the sole grass cutter and have to trailer my mower.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Feb 07, 2012, 12:03 PM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Charles
That's a fantastic idea!
Add that to the list HH.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Feb 07, 2012, 12:14 PM
interplanet is offline
Find More Posts by interplanet
interplanet's Avatar
Sheboygan Falls, WI
Joined Nov 2006
I still wish someone from HH could answer the question about a lipo cutoff, whether its a noise indicator or whatnot. Kind of a need to know thing for some of us thinking about preordering.
interplanet is offline Find More Posts by interplanet
Old Feb 07, 2012, 12:30 PM
PeteSchug's Avatar
Joined Apr 2004
My guess is that without a motor to run the battery will last a long, long time.
If there's room you can stick the 200 mAh battery in. 200 mAh at 7.2 v is 1440 mW which is a lot of mW's to drive four teeny tiny servos just a little at a time even if you do aerobatics on a ridge all the time.
I am not going to worry about it. I've flown my 1S J3 and Champ for really long periods of time WITH the motor running though not full throttle. The ASK-21 uses a 2S battery and no motor.
If they put an audio low voltage signal in you probably won't hear it anyway!
Edit: practical limits. My longest thermal flights have been around 45 minutes. Maybe I get tired quickly or I don't like getting a stiff neck, but my personal endurance is probably less than the ASK. I may have to get a lounge chair to do some serious testing.
Pete
Old Feb 07, 2012, 12:32 PM
Southern Pride
Want to learn how to thermal purchase a Ascent ( I have my original red one from years ago , converted to BL of course) and a copy of the Old Buzzard's Soaring book. Title may notbe exactly correct but is close.
If conditions are good enough then it is amazing what can be thermaled. Over 30 years ago I used to thermal a Gleen Spickler Quicky 500 on really good thermal days.It was build to mininum race weight and had a K & B .40 on it.
Charles
Old Feb 07, 2012, 12:36 PM
Southern Pride
Battery life could be determined to a great extend to how active the AX3X system is.
Still needs to be controlled on and off. HH personal stated there was no reason to turn it off as everything flys better with it on. As long as they maintail that stance I will most likely avoid anything with it in it. Guess I had bettere start looking at GP Micros.
Old Feb 07, 2012, 12:51 PM
PeteSchug's Avatar
Joined Apr 2004
Hey Charles.
I've been flying for almost fifty years. I think everyone misconstrues the use of gyros. They just extend the range of conditions under which you can fly.
I haven't yet flown any of the HH three axis systems but I've got hours on my 9 oz. pico Tiger Moth FPV that has a gyro in it. Stuck it there in the hope of better video and fly it under the most horrendous conditions you can imagine. Glued it back together several times when the wind smacked at low altitude. I can't see any reason to ever take the gyro out. It doesn't interfere with my control, but it does help steady the cam and make gusty conditions seem less gusty.
Pete
Old Feb 07, 2012, 12:57 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
You're making a mistake, a big mistake.
All the gyros do is counteract any sudden, commanded movement in the axis' they are on. In practice, that means you won't be tossed about in turbulence so much.
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Feb 07, 2012, 12:59 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Hey Charles.
Pete
Exactly. People get horribly confused about gyros, often thinking that the gyros do all the flying.
Old Feb 07, 2012, 01:07 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Originally Posted by ducatirdr View Post
I think micro rc gliders are a great idea. I saw this video and thought to myself about trying something like this.
Guy slope soaring off a building
This video had me think how cool it would be to have a smallest slope contest and oddest slope contest. With the right conditions you should be able to fly off some unusual lift sources.
Then there is artificial slopes like this....
http://www.sciencetoymaker.org/airSurfKit/index.htm
I think we're gona find lots an lots of places we never dreamed of to slope soar this little gem!!!! A smallest and or oddest slope soaring contest would be cool!!! All you need is a small knoll or a long tall building with relatively unobstructed space in front with wind blowing directly at face and you've got a mini slope. Or,,,, how bout a mini slope duration contest???
I once briefly held national record for slope duration in open class flying a 106in wingspan scale sailplane similar to the ask. I flew her for 12 hours 35 min in 2001 out on coast at Eureka Calif.
And as for you guys who Wana practice micro thermaling,, I'd suggest the Micro champ, it thermals surprising well!!! Which forbodes REALLY REALLY well for this new micro ASK 21!!! If I can thermal a champ for 45 min,, I should have no trouble getting thermal flights of over an hour with this much more streamlined and efficient sailplane.
Airman74 is offline Find More Posts by Airman74
Old Feb 07, 2012, 01:13 PM
Airman74 is offline
USA, CA, Chico
Joined Feb 2011
Or,,,,, how bout some micro dynamic slope soaring????? Don't know if this little guys wings could take it though!!!! For those of you not familiar with dynamic soaring , look it up on you tube.lots of videos there of people doing it. It's basically flying on the backside of a sharp edge ridge to attain incredible soaring speeds. I believe current world record is somewhere around 240mph with an RC sailplane!!! :-O
Old Feb 07, 2012, 01:19 PM
Vegas_flyer is offline
Find More Posts by Vegas_flyer
Vegas_flyer's Avatar
Joined Aug 2006
I think that is up to 487mph
http://www.rcspeeds.com/aircraftspeeds.aspx
Vegas_flyer is offline Find More Posts by Vegas_flyer
Old Feb 07, 2012, 02:07 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
Thermal and slope pilots don't need an indicator
airpower is offline Find More Posts by airpower
Old Feb 07, 2012, 02:11 PM
PeteSchug's Avatar
Joined Apr 2004
Way off. Spenser Listenby set a record of 468 the broke it with a flight of over 480. For small stuff at low speed SpeedsterDen does some neat flying on the back side of sand dunes in Denmark. He also has a video or two of DSing the drop off on the side of a road. Most of his slow speed DSing is with the Alula.
Listenby manufactures the Kinetic series but an all out DS plane fully equipped is at least a couple of thou and if you make a mistake the crash gives a new meaning to the word total.
Speeds are measured on the upslope against the wind because it's the only place they can be radared. The estimated airspeed on Listenby's fastest run was around 550 mph.
They also turn at about 50 to 70 g and they make a might roar. You can hear the change in noise as they cross the shear line.
If you're skeptical go check out the DS forum. These guys are for real.
Pete
Discussion Hobbyking ASK 21 2600mm Glider - good for first glider Charlescd Electric Sailplanes 27 Apr 26, 2012 12:47 AM
Question Electric Motor Choice for a Roedelmodell 4.2M ASK-21 Rudderman98 Scale Sailplanes 19 Jan 23, 2012 09:36 PM
Discussion Roedellmodell ASK-21 4.2M.....ELECTRIFIED! Rudderman98 Scale Sailplanes 9 Nov 15, 2011 02:41 PM
Discussion My ASK 21 80" wingspan has just arrived. sam-smith Electric Sailplanes 1 Nov 08, 2011 05:58 PM
Discussion Art-Tech ASK-21 rickhensley Electric Sailplanes 6 Aug 25, 2011 08:42 PM
