Old Feb 05, 2012, 01:23 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Originally Posted by airpower View Post
Hey, do any of you think i could use my stryker as a trainer to learn how to find thermals?
Not floaty enough in my book.... Maybe someone else had luck with it? Have to admit that when I fly my Stryker, I FLY my Stryker. That's about the only airplane in my UM fleet that I could use without a linear throttle.... It's either ON or OFF with that baby!!!
I think the best UM is still the Vapor (with 10% throttle to cancel prop drag) or the Extra 300 3D (again, a bit of throttle needed).
RealGambler is offline Find More Posts by RealGambler
Old Feb 05, 2012, 01:45 PM
microheli is offline
Find More Posts by microheli
microheli's Avatar
Joined Jul 2006
Yes but it glide very well when you in power OFF mode with a stopped prop. I had glide flights for some minutes.
microheli is offline Find More Posts by microheli
Old Feb 05, 2012, 02:11 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
RG,
I have all those planes, i just dont want to use the ASK for learning. I have flown gliders, done alot of slope soaring, done alot of thermaling in the sim, but ive never used a thermal in an actual flight, i was thinking of buying a champ for training(wanted one for a long time), but a 90 dollar trainer when i already have a stryker, vapor, extra, planes that would already be quite susceptible to thermals(i think).
But then again, im a really good pilot, how am i gonna crash the ask learning to thermal?
airpower is offline Find More Posts by airpower
Old Feb 05, 2012, 02:31 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
RG,
Always use the right tool for the job. Probably better to learn all the theory and then put it into practice with the ASK.
Gerry__ is offline Find More Posts by Gerry__
Old Feb 05, 2012, 02:50 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Thanks Gerry, theres a hill at my local park, so ill get an extra 30 ft from the high start. Ive heard of black asphalt streets generating lots of heat, are those good places for thermals?
Old Feb 05, 2012, 03:00 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
The countryside is probably the best place to start. Brown fields are good places and of course there will be birds taking advantage of any lift.
Massive subject, though, and the more you read up on it the better you'll do.
Old Feb 05, 2012, 03:10 PM
TurboRacer is offline
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
What about a small brushless motor powerplant on a stake in the ground - spinning a spool, an eye hook a couple feet away with the line going through it and out a couple hundred feet to the ASK..
Hit a button, brushless motor spins up and spool spins in at break-neck speeds, up and away
TurboRacer is offline Find More Posts by TurboRacer
Old Feb 05, 2012, 03:31 PM
Canada, QC
Joined Oct 2009
I know it does glide awesome, I've been flying Strykers for a long time!. You can keep in C version in the air for more than 30 minutes if all you do is go up, and gently glide down while riding some hot air, rinse and repeat. But I think you would need a massive thermal to gain altitude with a Stryker though. Staying at the same level for a little while seem possible, but since I was always way up when that happened, I could not bet money on it!
I agree that the right tool for the job is a glider, but trust me, a Vapor over a hot city (roofs, asphalt, etc) can be fun too. Hard to get the perfect day for it though, since if there's any real wind, the Vapor stay in the box!
Old Feb 05, 2012, 06:56 PM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
They're not bad, but parking lots are better. Even in the winter, on a sunny day, the asphalt heats up a lot more than the surrounding area.
MR2
minirips2 is offline Find More Posts by minirips2
Old Feb 06, 2012, 11:05 AM
mrodgers is offline
Find More Posts by mrodgers
United States, PA, Butler
Joined Jun 2006
I use to send my little Aero Ace over my rooftop to get it to soar up in the air far faster than it climbed on it's own.
I had an Aerobird Challenger I would circle above the house as well in the evenings. Also, I am all field behind my house with a lot of wind and a high treeline along the road in front. My Aerobird would cruise along that treeline forever off throttle.
mrodgers is offline Find More Posts by mrodgers
Old Feb 06, 2012, 12:52 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
Sounds interesting, I might try a bit of urban soaring myself.
Old Feb 07, 2012, 07:13 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Pale Male. He resides in the high rent district on the upper east side of Manhattan. He does urban soaring almost every day. This shot taken with a 500 mm zoom on my Nikon D90.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Feb 07, 2012, 07:42 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
I assume you mean the UMX Stryker, you've got to program it to full brake or else the prop just windmills which totally kills its floating abilities. But with full brake it does hang pretty well. The issue with it is its size, it's so tiny that you can't get it into boomer territory and still see it well.
Tres Wright is offline Find More Posts by Tres Wright
Old Feb 07, 2012, 08:08 AM
Canada, QC
Joined Oct 2009
I tried full brake, but the prop still create a drag. It's much better to simply give some throttle (something along 5%) which you know doesn't propulse the airplane but simply cancel the drag totally. And again, I would like to see a report of a Stryker gaining altidude with thermal (and 5% thottle). Definitively not the best one for practicing, though I agree, it does glide DOWN very well and slow.
Old Feb 07, 2012, 09:24 AM
Forney, TX
Joined Mar 2002
Personally I don't like to leave the prop turning, it slows it down too much. With the prop stopped it glides quicker and can zip around to try and find lift. If I find lift I give it some up elevator to hold it there. But more power to you if that's your preference Darned near anything will climb if you can find good lift, I've even had a Kinkade ornithopter get caught in a thermal and climb out, and those things drop like a rock when they're not flapping. And yes, I've had the Stryker climb in a thermal with no throttle as well. But not for long before I bailed into a spin, because it gets too small too fast. But the Stryker is obviously not a dedicated sailplane and isn't going to render 15 minute power off glides without unusually strong thermal activity present. The ASK-21 should be a lot better for that. Hope to find out soon
PS, not to make it sound like I take the Stryker out just for thermaling, that's not the case. I mostly fly it down low and do aerobatics with it, but for a break now and then I'll send it up high and play around to see how long I can keep it flying with no power. I do that with a bunch of my planes just for grins
Discussion Hobbyking ASK 21 2600mm Glider - good for first glider Charlescd Electric Sailplanes 27 Apr 26, 2012 12:47 AM
Question Electric Motor Choice for a Roedelmodell 4.2M ASK-21 Rudderman98 Scale Sailplanes 19 Jan 23, 2012 09:36 PM
Discussion Roedellmodell ASK-21 4.2M.....ELECTRIFIED! Rudderman98 Scale Sailplanes 9 Nov 15, 2011 02:41 PM
Discussion My ASK 21 80" wingspan has just arrived. sam-smith Electric Sailplanes 1 Nov 08, 2011 05:58 PM
Discussion Art-Tech ASK-21 rickhensley Electric Sailplanes 6 Aug 25, 2011 08:42 PM
