Old Feb 29, 2012, 07:22 AM
interplanet is offline
Find More Posts by interplanet
interplanet's Avatar
Sheboygan Falls, WI
Joined Nov 2006
Hobbyking sells a ask-21mi with a retracting motor. 82 inches for $89 from a us warehouse PNP
interplanet is offline Find More Posts by interplanet
Old Feb 29, 2012, 07:55 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Intended purpose?
To show a CC can tow it to alt?
To be towed and search for thermals?
To be shot up with a HS and search for thermals?
To set on a shelf and look cute?
Etc., etc.
HH has other great motorized gliders, the Ascent, the Radian and the Radian Pro to name a few. I converted the old Red Ascent to BL like many others did and I often get 60 min. plus flights off of a single 15 seconds motor run. It climbs between 600 and 700 feet in 15 seconds as measured with several different devices. It comsumes right at 50 mAh per climb and I fly it with a 500 to 800 mAh LiPlys which means even on a very bad constant sink day I can stay up for a very long time with mininum of 8 full climbs per charge possible.
Charles
Old Feb 29, 2012, 09:55 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
WAY, W A Y, bigger than I want.
Pete.
PeteSchug is offline Find More Posts by PeteSchug
Old Feb 29, 2012, 11:50 AM
microheli is offline
Find More Posts by microheli
microheli's Avatar
Joined Jul 2006
Originally Posted by turboparker View Post
All of that is taken into account in the guideline I posted. According to all of the e-power guidelines I've read, 50W/lb is the bare minimum required for sustained level flight with all but the most efficient RC airframes. That's not even talking about the ability to climb at all. With the Vapor system, you'd likely be well under 20W/lb. Plus, flight-speed would be very low with the Vapor prop. The Vapor tops-out at, what - maybe 4-5 MPH? The ASK-21's stall-speed is probably around 4-5 MPH.
Ok the bigger 8mm motor (Sukhoi) seems better for this.
I have make some reseach:
The ASK 21 MI with IAE R50-AA (41kW)
Weight: 1047 lb - 1543 lb
This make 26W/lb - 39W/lb
microheli is offline Find More Posts by microheli
Old Feb 29, 2012, 12:40 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
While its intended purpose may not be so strong, it's obviously a very niche product, but I love that about it, they aren't just doing safe things, they're making niche products like the Hyper Taxi and the ASK. Personally, I gave up flying anything larger than micro size a couple years ago, I got so much more fun out of flying a $100 bnf at the park whenever I wanted to, I didn't want to spend four times as much on an airplane I'd fly once a month. I've long been interested in soaring, and now with this ASK, I can explore urban soaring in a pure and beautiful way, anywhere I want.
BTW, normally the product videos Horizon makes for their products are ok, they show the plane in action very well. But the video for the ASK, AMAZING!!!!!
airpower is offline Find More Posts by airpower
Old Feb 29, 2012, 04:00 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
One thing is that many aspects about aircraft do not scale linearly (often larger is more efficient). 2 examples come to mind:
*full scale aircraft can fly with much higher wing loading than small models
*as one scales a full scale aircraft down to about foamy size, the "tail feathers" need to be larger than scale size to be effective (I remember this from the scratch-built foamies forum).
As far as I know, this is in part due to that even though the aircraft model is being scaled, the air that it is flying in stays the same size, so the air (nitrogen and oxygen) molecule to aircraft size is changing as one change the aircraft scale.
flying-llama is offline Find More Posts by flying-llama
Old Feb 29, 2012, 04:15 PM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
*as one scales a full scale aircraft down to about foamy size, the "tail feathers" need to be larger than scale size to be effective (remember this from the scratch-built foamies forum).
FL,
Yes - it's called Reynolds number. Essentially, the air becomes much more viscous as things are scaled-down. At this scale, Reynolds numbers are very low as compared to full-scale planes - which dramatically decreases the efficiency of flight.
Joel
turboparker is offline Find More Posts by turboparker
Old Mar 01, 2012, 07:20 AM
DaveG is offline
Find More Posts by DaveG
DaveG's Avatar
Houston, TX, US
Joined Jun 2000
Yes, I enjoy the video, too. I wonder what the music is playing for background? Very suitable for the video.
DaveG is offline Find More Posts by DaveG
Old Mar 01, 2012, 12:07 PM
Vbluguitar is offline
Find More Posts by Vbluguitar
Joined Dec 2010
Oh man, Now I need like 600 bucks to make this a father son duo. My 15 year old, 12 year old, and I saw this cub/ask duo (we all fly micros together) and we were all drooling like fools. But we only have the RTF xbox-like controllers, so we would have to buy 2 new radios and the aircraft. It will never happen. I have 6 kids and am self employed... Dream on.
Vbluguitar is offline Find More Posts by Vbluguitar
Old Mar 01, 2012, 01:03 PM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Awe man, I have 3 and I'm trying to deal with my "I want list", but 6 Good luck and I hope you'll be able to pick up at least one of the new micros coming out.
rcoconut is offline Find More Posts by rcoconut
Old Mar 01, 2012, 03:03 PM
microheli's Avatar
Joined Jul 2006
Yes i know, it's the Reynolds number effect like turboparker say.
Specially with the ultra micro models you can not play with the energy like the bigger planes. On the other side you can endlees dive and reach not the velocity which can destroy the airplane.
Old Mar 01, 2012, 04:26 PM
Roger Lombard is offline
Find More Posts by Roger Lombard
Confused? Who, me?
Roger Lombard's Avatar
United Kingdom, England, North York
Joined Jan 2005
Doh - deleted - wrong thread
Roger Lombard is offline Find More Posts by Roger Lombard
Old Mar 01, 2012, 10:22 PM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
I don't know if it would help you or not, but I have two of the parkzone/spektrum 4 channel transmitters I would be happy to give to you free of charge. Fathers and son's spending quality time together is priceless. I have priceless memories of my dad teaching me how to fly rc back in 1975.
sj3cub is offline Find More Posts by sj3cub
Old Mar 02, 2012, 06:31 AM
Conehead is offline
Find More Posts by Conehead
Flutter-Bys are fun
Conehead's Avatar
United States, MI, Honor
Joined Dec 2005
Remember there is a classified area here where pilots sell stuff. You can find a good transmitter here along with lots of other stuff. I have bought planes, rec, and other things here on RC Groups.
I know how you feel. I am retired and I want it all. I have always wanted a small sailplane. I saw one that Matt had made at E-Fest a few years ago that he used the parts from the Cessna 210 to build. It was so neat, a lot like this new ASK-21.
I want this one, the Carbon Cub with floats, so I can float fly and tow the ASK-21 up and the Mig and Spit.
So with the economy in the toilet, it is lucky that any business survive.
As guys upgrade their TX's, you will find a good used one here.
Conehead
Orrin Eldred
Conehead is offline Find More Posts by Conehead
Old Mar 02, 2012, 08:23 AM
Confused? Who, me?
Joined Jan 2005
Although they are smaller still than the HH ASK, if anyone wants a self propelled micro sailplane don't forget that Axion make a range of three, all with a power pod - Discus, ASH 31 and ASK 21.
Discussion Hobbyking ASK 21 2600mm Glider - good for first glider Charlescd Electric Sailplanes 27 Apr 26, 2012 12:47 AM
Question Electric Motor Choice for a Roedelmodell 4.2M ASK-21 Rudderman98 Scale Sailplanes 19 Jan 23, 2012 09:36 PM
Discussion Roedellmodell ASK-21 4.2M.....ELECTRIFIED! Rudderman98 Scale Sailplanes 9 Nov 15, 2011 02:41 PM
Discussion My ASK 21 80" wingspan has just arrived. sam-smith Electric Sailplanes 1 Nov 08, 2011 05:58 PM
Discussion Art-Tech ASK-21 rickhensley Electric Sailplanes 6 Aug 25, 2011 08:42 PM
